Old Jun 18, 2012, 10:56 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Originally Posted by beerassassin View Post
I did a quick test by pushing the white gear down out of the way so the prop could spin freely like others have suggested here to balance the whole assembly. one blade dropped to the bottom just like in the vid...
Just add a bit of tape. Sanding is the proverbial sledgehammer on such small props.
Gerry__ is offline Find More Posts by Gerry__
Old Jun 18, 2012, 12:43 PM
flying toaster is offline
Find More Posts by flying toaster
aka beerassassin
flying toaster's Avatar
Joined Dec 2009
ahh gotcha
flying toaster is offline Find More Posts by flying toaster
Old Jun 18, 2012, 02:09 PM
fred_dot_u is offline
Find More Posts by fred_dot_u
Joined Apr 2008
I took my mQx out a couple nights ago, nice light 0-3 mph winds for some circuit flying and head-in practice in my front yard and street. While hovering above the front lawn, I had a visitor appear, dart around the 'copter a few times and zip away. For a total of four visits, the hummingbird flew formation with me in hover before he vanished. Sadly, no video, since my flying is usually unremarkable, but that night was amazing!
fred_dot_u is offline Find More Posts by fred_dot_u
Old Jun 18, 2012, 02:14 PM
Scootatrash is offline
Find More Posts by Scootatrash
United States, RI
Joined Jan 2012
I had a big hawk swoop down and try to grab the MQX as I flew it in my backyard once . It landed in a tree in my neighbor's yard and watched me flying for almost 15 minutes. I tried to coax it out by flying within 6 feet of where it was, but it just watched. When my lipos were dead and the MQX was grounded, it took off.
Scootatrash is offline Find More Posts by Scootatrash
Old Jun 18, 2012, 02:46 PM
Joined Apr 2008
Holy smokes, batman! I suppose it's lucky for you that the bird decided it wasn't a tasty snack. We have hawks and eagles in this area and I had an eagle land with lunch in our back yard. My wife spooked it a bit and it flew away with its kitty snack in talons, leaving behind tufts of hair. I'd hate to see pieces of mQx at the base of a tree!
Last edited by fred_dot_u; Jun 18, 2012 at 03:12 PM. Reason: removal of inappropriate apostrophe
Old Jun 18, 2012, 02:51 PM
United States, RI
Joined Jan 2012
Oh man! A "kitty snack"? My wife would freak.
I wonder if an eagle would go after a flying cat like the Orville-Copter posted earlier in this thread.
Old Jun 18, 2012, 03:14 PM
Joined Apr 2008
If I ever finish my MK Okto XL, I'll have to consider a flying squirrel costume for it. I probably should arm the copter with some form of protective weaponry before flying it around raptors.
Old Jun 18, 2012, 03:50 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Originally Posted by pgoelz View Post
Don't forget to check tracking (the height of one blade vs. the other) too. After a crash, the blades can get bent, but this can be easily fixed by just bending them back into position.
This has happened to me.
I find that adding heat (I use a trim cover iron for Monokote, etc., but I remember using hot water on plastic frames of glasses)
makes it easier to bend and more importantly let one bend repeatedly without breaking (I did this to a GWS slow-fly prop many many times).
flying-llama is offline Find More Posts by flying-llama
Old Jun 18, 2012, 04:56 PM
aka beerassassin
Joined Dec 2009
I decided to try the sanding method anyways and I am quite happy with the results!
I used 600 grit sandpaper that I cut into tiny pieces. it took a decent amount of sanding and checking before the blades leveled out, so it was easy to get a nice balance without ever having to go back and forth between sides. it required a decent amount of pressure, and a fine white powder would appear. since the markings are so fine it’s not really noticeable aesthetically, and I like the idea of reducing weight on the blades rather than adding. took me about an hour total, so it takes a bit longer than adding tape I'm guessing.
as noted earlier, I noticed the heavy blade was always the one with the A/B letter on it (although I still checked each one), which made it easy to know what side to work on without marking the blade
I attached a pic I took after doing two blades, so you can see how much material came off. I went back and sanded the orange blade a bit more after I took the pic
Old Jun 18, 2012, 05:05 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Congratulations, you saved 0.002g and it only took an hour of your life.
Old Jun 18, 2012, 06:16 PM
aka beerassassin
Joined Dec 2009
I pride myself on attention to detail, it has served me well in life.
Old Jun 19, 2012, 04:46 AM
ReasonSwe is offline
Find More Posts by ReasonSwe
Capt. Dennis
ReasonSwe's Avatar
Sweden, Västerås
Joined Jan 2004
yesterday I filmed over our rc-shortcourse track.. and crasched in to a banked curve......and ofcause a 2wd Slash came and run me over. haha
but the mQX took the beating and flew away.
had my mini-cam on, so it´s on tape.
20120618HallonmQX (5 min 34 sec)
need to buy new blades soon, and my canpoy is starting to get some war damage
lovley thing to fly, even my wife wants one...
ReasonSwe is offline Find More Posts by ReasonSwe
Old Jun 19, 2012, 08:02 AM
vanzant is offline
Find More Posts by vanzant
Joined Mar 2012
Battlebots!
vanzant is offline Find More Posts by vanzant
Old Jun 20, 2012, 10:01 PM
turboparker is offline
Find More Posts by turboparker
I'd rather be flying!
turboparker's Avatar
Joined Jul 2009
On-board video
Here's a clip I shot this evening with the #16 cam mounted under the belly. Just some slow flying around my north yard & backyard. I've flown with my old #3 cam a few times, but this is the first time I've flown with the #16. I did notice that it's a bit easier to get into vortex ring state with the heavier cam. I balanced the props, but there's still a bit of harmonic vibration. Be sure to watch in 720p.
What do y'all think?
Eflite mQX on-board video - 808 #16 cam (4 min 55 sec)
Joel
turboparker is offline Find More Posts by turboparker
Old Jun 21, 2012, 02:19 AM
Impailer is offline
Find More Posts by Impailer
FLY IY, BREAK IT, FIX IT,
Hampshire, United Kingdom
Joined Jun 2005
Joel
I think I am jealous of your backyard, but I am glad I don't have to mow it......
Impailer is offline Find More Posts by Impailer
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
