Latest blog entry: Foamie Resurrection
The system compensates for the extra mass at the front to the point where you don't notice any difference, apart from needing a bit more power.
Joined Jun 2012
Not sure if there's a better place to put it, but my reasoning was on the leading edge the air is constantly pushing against it rather than trying to rip it off. It's very thin tape, so rubbed down hard I don't think it's harming the aerodynamics greatly. I'm open to suggestions as to improved ways of placing it though.
She flies like a charm without affecting any performance. No need to order from the net and wait![]() http://static.rcgroups.net/forums/at...52-31-TD-3.jpg |
watched some videos, in 1 vid the guy used some fine grit sandpaper to reduce weight on the heavy blade rather than adding weight to the light blade. I like the idea of reducing weight instead of adding it (even though I'm sure it's very minimal), and I have some fine 800 grit sandpaper lying around. I would do it to the underside of the blade, using a small piece with my finger so I don't get too close to the blade's edges... do you think this is a good idea on small mqx props? |
Between my tx and crashed aircraft
Joined Mar 2006
It weighs just under 1 gram and the flying has been fine (been doing flips and rolls in the wind using 125% rates on A, E and R). The orange paper matches the orange props in the rear, so "orange= heli tail" for me. |
I'm going to give it a shot tomorrow. I notice when I fly a buzzing sound... I'm no expert but to me that indicates some sort of vibration.
here's the vid I watched, pretty helpful. he balances a small prop... at 5:40 in he recommends doing this for small blades too:
I did a quick test by pushing the white gear down out of the way so the prop could spin freely like others have suggested here to balance the whole assembly. one blade dropped to the bottom just like in the vid... |
If you mean it is a waste of time to balance them, I disagree. All of mine were out of balance enough to require small pieces of tape. When balanced, they run much smoother and it makes a big difference to videos shot from the mQX.
If you mean it is a waste of time to sand vs. using tape, I agree. I just applied the tape to the underside of the blades and rubbed it down well. It shows no signs of coming off after months of use. The tip speed is not high enough to lift tape. Don't forget to check tracking (the height of one blade vs. the other) too. After a crash, the blades can get bent, but this can be easily fixed by just bending them back into position. Paul |
| Thread Tools | |
| Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i | nyaaah!! | Aircraft - Electric - Micro & Indoor Airplanes | 11 | Oct 06, 2011 11:21 AM |
| For Sale New Blade 400 RTF Will sell as BNF | papower | Aircraft - Electric - Helis (FS/W) | 8 | Aug 04, 2011 12:28 PM |
| Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X | ABADGTP | Aircraft - Electric - Helis (FS/W) | 0 | Jul 26, 2011 07:22 PM |
| Sold Blade MCX2 Like New RTF or BNF | tamiyafan1975 | Aircraft - Electric - Helis (FS/W) | 1 | Jul 14, 2011 03:39 PM |
| Sold Blade mCPX RTF or BNF (factory sealed new in box) | PatternFlyer | Aircraft - Electric - Helis (FS/W) | 5 | Mar 28, 2011 03:25 PM |
