Old Jun 12, 2012, 09:21 PM
Scootatrash is offline
Find More Posts by Scootatrash
United States, RI
Joined Jan 2012
Originally Posted by flying-llama View Post
As far as I know:
if it has a "RoHS" marking (and it seems most electronics boards do these days), then lead-free solder was used to put it together.
Lead-free solder and leaded solder (like 60/40 rosin-core solder) are supposed to make an unusable mess when mixed, so it is best to use lead-free solder when dealing with an "RoHS" board (I have both types of solder).
From experience, I believe this is correct. In fact, you'd be best off not even using the same soldering iron that has been tinned with the leaded solder, when working lead-free solder joints.
Scootatrash is offline Find More Posts by Scootatrash
Old Jun 13, 2012, 12:06 AM
exita is offline
Find More Posts by exita
exita's Avatar
Joined Apr 2009
I've added a white led under the canopy (attached to the main frame)
this thing is sooo bright
Blade MQX at Night (1 min 38 sec)
exita is offline Find More Posts by exita
Old Jun 13, 2012, 08:41 AM
Mac Smith is offline
Find More Posts by Mac Smith
Mac Smith's Avatar
Germany, HE, Frankfurt
Joined Jun 2012
Originally Posted by Brandigan View Post
Is this of any interest to anyone?
Cable-tie feet extenders are good for softening landings and also allow 'driving' along hard floors, with minimal friction.
Great idea actually.
Also, I'll be sure to check out your camera mount.
Here's some pics of mine.
It looks like it's having as much fun as I have flying it.
It's modded a bit with extended, solid struts and an alternative battery mount.
Work in progress, though, as I want to redo the battery mount and the whole wiring with proper silicone leads and I don't like the straws covering the struts anymore and look for a more elegant solution. LEDs are a must, too, of course.
Mac Smith is offline Find More Posts by Mac Smith
Old Jun 13, 2012, 09:04 AM
Mac Smith's Avatar
Joined Jun 2012
Originally Posted by pgoelz View Post
Still wondering what those outputs are REALLY for. Maybe there is a hidden programming step that changs the flash sequence??
Paul
My guess is that those were originally planned for LEDs at some stage of developement, but this one channel is "defective by design" in the CPU and to difficult/costly/time consuming to fix before release, so all LED lighting was scraped this time around and may resurface in a "Night MXQ" or MQX2.
Supporting clues:
- I've yet to see someone getting all 4 LED outputs to work
- the holes at the unerside of the motor covers look like 3mm LED mounts to me
Old Jun 13, 2012, 10:42 AM
Jim_Marconnet is offline
Find More Posts by Jim_Marconnet
Fly long and land softly
Jim_Marconnet's Avatar
Madison, Alabama USA
Joined Oct 2005
Where to use the Orange Blades
When I bought my mQX, I bought a set of the Orange blades for higher visibility. Now which blades, the white ones or the black ones, should I replace with the Orange ones?
I'm assuming someone has experimented with different colors and can save me the difficulty of extensively field-testing it!
Jim
Jim_Marconnet is offline Find More Posts by Jim_Marconnet
Old Jun 13, 2012, 11:36 AM
TheOne420 is offline
Find More Posts by TheOne420
Chad
TheOne420's Avatar
United States, CA, Cathedral City
Joined Dec 2010
Jim
well the idea of the orange blades is so you know what direction it is flying. so in that case it doesnt really matter where they are placed as long as you know where they are.
i have replaced my white blades with the orange ones (i fly in x configuration) and they almost glow in the sunlight.
but you could put one white one orange tohelp with left right orientation as well. you could but them both in the rear. the idea is that you know what side is witch do to the color of the blades. just make sure the prop you replace is going the same direction as the one you remove(clockwise or counterclockwise.)
so just put them on and have fun at a further distance.
TheOne420 is offline Find More Posts by TheOne420
Old Jun 13, 2012, 12:04 PM
exita is offline
exita's Avatar
Joined Apr 2009
The orange props are great. You can realy see them clearly in the sun. I have 4 sets coming in the mail.
Old Jun 13, 2012, 12:52 PM
Thetis is offline
Find More Posts by Thetis
Always, against the wind
Thetis's Avatar
United States, IL
Joined Oct 2011
Jim
As other posters said it is up to you. This is my orientation setup.
Thetis is offline Find More Posts by Thetis
Old Jun 13, 2012, 01:00 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Jim
I use one black, one white and two orange blades.
Balr14 is offline Find More Posts by Balr14
Old Jun 13, 2012, 04:20 PM
Chad
TheOne420's Avatar
Joined Dec 2010
well i was doing my normal searching on the net and I came across this little guy
http://www.banggood.com/Wholesale-Wl...f-p-46172.html
it will be in stock on june 20th and if you take a good look at the pictures and the video it really looks like a MQX clone the motor mounts and covers are the same as the mqx as well as the props. they dont show a pic of the board but for the price i might just have to buy it and give it a try.
if anyone else buys one please let me know the results.
Old Jun 13, 2012, 04:27 PM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
You can find more infos about the "clone" on this thread : http://www.rcgroups.com/forums/showthread.php?t=1658847
mystman is offline Find More Posts by mystman
Old Jun 13, 2012, 04:35 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Orange props are definitely the easiest for me to see.
Indoors: I find white easier to see than black.
Outdoors: white is slightly easier to see than black for me (even with clouds as a background), but not by much.
I ended up with this prop color scheme (to evenly use up all the black and white props that I have):
My front props sometimes get bent from crashes (I then do some unbending with heat).
flying-llama is offline Find More Posts by flying-llama
Old Jun 13, 2012, 04:37 PM
Joined Mar 2006
Great looking canopy!
But does it bite its tongue when it crashes?
Old Jun 13, 2012, 05:33 PM
TomQ is offline
Find More Posts by TomQ
Joined Mar 2012
Jim
I think it partly depends on where you fly. My backyard is lined with dark trees. I lose sight of the black blades easily so I run orange and white. If you are flying with a clear sky background you may prefer to keep the black blades instead.
I find the orange to be easier to see so I fly them up front. Having matching colored bodies helps my old eyes and brain with orientation as well.
TomQ is offline Find More Posts by TomQ
Old Jun 13, 2012, 05:41 PM
kodak_jack is offline
Find More Posts by kodak_jack
kodak_jack's Avatar
Hilton (Rochester), NY
Joined Mar 2008
Talk about confusing. They name it after one quad and copy another one. The Ladybird (you know, the one that looks like a ladyBUG) would have been nice to get at that price as an indoor lousy weather quad. The real Ladybird requires you to buy the $50 transmitter. Hey, maybe they'll clone the Ladybird for $40!!!!!!!!!
kodak_jack is offline Find More Posts by kodak_jack
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
