Old Jun 05, 2012, 04:42 AM
fred_dot_u is offline
Find More Posts by fred_dot_u
Joined Apr 2008
Gerry, there's a couple places referenced in this message:
http://www.rcgroups.com/forums/showt...6#post20820760
including an eBay seller that ships to the UK.
fred_dot_u is offline Find More Posts by fred_dot_u
Old Jun 05, 2012, 05:01 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Hi Fed, your link is linking to your above massage.
Anyway, I'm heartened to know that they are available here.
Gerry__ is offline Find More Posts by Gerry__
Old Jun 05, 2012, 07:23 AM
Joined Apr 2008
When I click on the link, it opens to the message I would expect to open. It's on page 236 of this forum, message 3535
Old Jun 05, 2012, 07:33 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Hi Fed, I think we have different pagification set, but I found it via post#.
Much obliged to you.
Old Jun 05, 2012, 07:48 AM
stablehover is offline
Find More Posts by stablehover
Joined Mar 2011
Originally Posted by Gerry__ View Post
Hi guys. Anyone know where I can get similar kits to this, as this guy doesn't ship to the UK: http://www.sf-design-solutions.com/
Brentford RC do one but it only has two 5mm LEDs and uses heavy wire.
Thanks in advance.
I used some lights from a parkzone airplane. It had a red and two green lights. It was very light. You have to use a battery from the vapor airplane to power it but it looks great and was relatively inexpensive. I used a heated drill bit to make the holes in canopy. Should be easy to source that from HH UK. I was not trying to get real technical just fooling around. It looks great at night the lights are really bright and weighs very little.
stablehover is offline Find More Posts by stablehover
Old Jun 05, 2012, 07:34 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Originally Posted by ReasonSwe View Post
think its that way I go, first TX then mQX.
will try it again later, and wait for 5-6sec.. will record it, so you can see if Im doing it right. haha
May be helpful: I turn on the Tx, wait, then turn on the mQx.
I still often get the mQx's blue light flashing instead of solid on.
It turns out if I unplug the mQx battery and then turn on the mQx again,
it will often work (never lost the bind). Sometimes I have to try a couple of times of power cycling the mQx to get a solid blue mQx light.
I have yet to need to rebind.
One possibility: when I connect the mQx battery, it is actually bouncing on, off, on.
And the blinking blue mQx light is to indicate that it had lost power (some of my other DSM2 Rx's sometimes do this).
flying-llama is offline Find More Posts by flying-llama
Old Jun 06, 2012, 01:57 AM
flying toaster is offline
Find More Posts by flying toaster
aka beerassassin
flying toaster's Avatar
Joined Dec 2009
I was bored tonight so I decided to shave off the battery cradle using my dremel and sandpaper in order to attach some velcro:
now my other batteries that were sliding around in the cradle stay snug, and I can center them easily:
I am also hoping this will make it easy to attach the wing cam without requiring any further modifications in order to provide enough ground clearance:
let me know what you guys think! as long as it's good
jk!
flying toaster is offline Find More Posts by flying toaster
Old Jun 06, 2012, 03:18 AM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
Picked up an MQx a couple weeks back. Managed to competently fly it around after 5 minutes! Wha??? I can't hover my 450 Trex nor any CP, but this quad can scoot around and hovers like .. well you all know this.
So after 4 flights, I FPV'd it, of course!
And sure enough, I am hooked! Just ordered a HT-FPV frame with Naza and all the fixins, plus also ordered a LotusRC quad.
now I dunno why, but my SD card in my grounds station got corrupted halfway through the flight. So I couldn't edit the video .. but luckiiy Vimeo uploaded it. You MUST go ahead 40 seconds before the maiden flight begins...
Blade mQX FPV flight (2 min 23 sec)
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Jun 06, 2012, 03:51 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Adding LEDs to ping-pong balls
I found this interesting site with info about lighting up ping-pong balls with defused LEDs: http://www.uchobby.com/index.php/200...-led-diffuser/
Old Jun 06, 2012, 04:25 AM
starscream4002 is offline
Find More Posts by starscream4002
starscream4002's Avatar
Tabriz, Iran
Joined Sep 2008
You can find lots of stuff like that here:
instructables.com
awesome website!
SS
starscream4002 is offline Find More Posts by starscream4002
Old Jun 06, 2012, 08:37 AM
Sixinarow is online now
Find More Posts by Sixinarow
Addicted
United States, CO, Parker
Joined Dec 2011
BCsaltchucker, which FPV setup are you using?
Sixinarow is online now Find More Posts by Sixinarow
Old Jun 06, 2012, 12:36 PM
fly by night
Joined Sep 2011
FPVHOBBY.com video equipment. 200mW 5.8 vTx, 3g camera, and a 300mah nanotech 1S battery. I glued a $1 jelly lens to get wider perspective, but it is plastic and decreases the image quality a bit. I stick this combo on a few different planes. (also have more serious equipment on my larger planks)
Old Jun 06, 2012, 12:47 PM
Scootatrash is offline
Find More Posts by Scootatrash
United States, RI
Joined Jan 2012
Very cool .... what do you use for veiwing?
Scootatrash is offline Find More Posts by Scootatrash
Old Jun 06, 2012, 01:30 PM
Romans is offline
Find More Posts by Romans
Romans's Avatar
Joined Jun 2012
great thread,
While its relevant, Im selling mine for 115 shipped if anyone's interested at getting a good deal.
http://www.rcgroups.com/forums/showthread.php?t=1666753
Romans is offline Find More Posts by Romans
Old Jun 06, 2012, 01:45 PM
SDSURFnGLIDE is offline
Find More Posts by SDSURFnGLIDE
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
United States, CA, San Diego
Joined Apr 2011
So this may be a little off topic, but does anyone know if the control board can be used for anything else other than flying the mqx?
I ask this because i was wondering if i could somehow use it as a gimbal controler...much like you would use a KK board or something?? I dont even know how i would begin to do this, but it was an interesting thought...I dont really fly my mqx anymore since i started flying larger quads and more recently hexa..
SDSURFnGLIDE is offline Find More Posts by SDSURFnGLIDE
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
