Old Jun 02, 2012, 01:58 PM
Zoandar is offline
Find More Posts by Zoandar
Ohio
Joined Apr 2008
Originally Posted by MOfroggy View Post
"Another thought I had was to create some short "stilts" on each of the landing feet to extend the mQX up a bit higher off the ground, allowing more clearance under it when it lands."
What I did for landing "feet" is I took 4 of the cheap bamboo skewers you get at the $Store and put about 1" of shrink wrap on the pointed end and then put another piece of shrink wrap about 1/2" on top of that. If it is a little tight I sandpaper the outer shrink wrap at the end so that it is tapered and as far down as I need to to make a snug fit into the 4 holes on the bottom of the housing. If it is too loose I put a line of CA down the shrink wrap from top to bottom and spray it with some bonder and then carefully sand this down until I get a tight fit. This method works with carbon fiber rod too. Use a piece of CF that is too small and build up the business end with 1/8" shrink tubing until you get the fit you want. If fit right they stay in and are also easy to remove so you can get the MQx back in the box. Mine are 3.5" tall.
Interesting approach. I noticed those little holes just the other day and was wondering if they originally had some purpose on the mQX and later were unused when it was released.
If you had some CF rod that was just a little oversized, you could turn it with your fingers against a needle file and reduce its O.D. until it fit. I have done that to slightly taper the ends of the CF rod used with O-rings to mount heli canopies, so they slid in more easily. CF is really easy to file. Just don't inhale the dust.
Zoandar is offline Find More Posts by Zoandar
Old Jun 02, 2012, 02:39 PM
flying toaster is offline
Find More Posts by flying toaster
aka beerassassin
flying toaster's Avatar
Joined Dec 2009
thanks for the pics Zoandar! keep us posted with your progress!
flying toaster is offline Find More Posts by flying toaster
Old Jun 02, 2012, 11:23 PM
Zoandar is offline
Ohio
Joined Apr 2008
Here is my mQX with the Wing Cam in its foam block, mounted to the top of an alternate canopy I made out of a small margarine tub. The tub is cut down to a depth of 1.25".
I took it for a test flight in my living room (since it is midnight here) and it seemed to need to 'get its sea legs' for a few seconds, but once the gyro stabilized it flew pretty well after initially flopping around like a fish.
The rotors sound like angry hornets with this configuration, so it seems to be working much harder than usual to fly. But It seemed to have reasonable performance as far as the controls are concerned when it came to ascending and moving laterally. Once I get a chance to take it outside I'll know more about whether this will work. But it has been pretty windy and rainy here lately, so I might have to wait for better weather.
I made the cup depth sufficient to also try slinging it below the mQX and put the foam block inside the dish, at which time I would need to cut an access hole for the lens. I figure I could turn on the camera, then mount the canopy upward from the bottom.
The test video from the flight came out smooth, but I did forget to peel off the plastic film over the lens, so I won't bother posting it. However, there didn't seem to be any distortion or 'jello effect'.
Old Jun 03, 2012, 03:47 PM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
I think he spent a few dollars and the rest shipping (grinning)
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Jun 03, 2012, 09:44 PM
heli-yeah is offline
Find More Posts by heli-yeah
Flying Monkey
heli-yeah's Avatar
Lexington, KY
Joined Aug 2010
What TX are you using and what are your "settings" on it?
DX6i with endpoints set to 125% on ELE, and AIL. Rates at 85% on ELE, AIL, w/ 25% EXPO
heli-yeah is offline Find More Posts by heli-yeah
Old Jun 04, 2012, 07:23 AM
TJFINAN is offline
Find More Posts by TJFINAN
Joined Jan 2011
Thanks very much. This is more proof of concept I suppose than anything...I may have to go over to the aerial photography section and see if anybody has dug up a keychain-like camera that takes stills as opposed to video.
TJFINAN is offline Find More Posts by TJFINAN
Old Jun 04, 2012, 07:34 AM
BlueHavoc is offline
Find More Posts by BlueHavoc
Flying mostly micro's
BlueHavoc's Avatar
United States, WV, Vienna
Joined Mar 2007
MQX canopies
Hi guys, I wanted to make some canopies for my MQX because I don't care for the stock one. I'm no modeler and this was my first attempt at something like this so I hope they don't look too bad! The first one I made from the paper canopy design shared earlier on this thread.I modified it and contructed it out of neon yellow 2mm craft foam. The second one was just a simple dome canopy made from a Mcdonald's drink dome. it fits perfectly so I thought Why not?...lol
BlueHavoc is offline Find More Posts by BlueHavoc
Old Jun 04, 2012, 09:08 AM
Thetis is offline
Find More Posts by Thetis
Always, against the wind
Thetis's Avatar
United States, IL
Joined Oct 2011
Very nice effort. There is a thread dedicated to alternate canopies. Check it out if you haven't yet.
http://www.rcgroups.com/forums/showthread.php?t=1589171
Thetis is offline Find More Posts by Thetis
Old Jun 04, 2012, 09:17 AM
BlueHavoc's Avatar
Joined Mar 2007
Thanks! I will definitely check it out
Old Jun 04, 2012, 12:24 PM
kodak_jack is offline
Find More Posts by kodak_jack
kodak_jack's Avatar
Hilton (Rochester), NY
Joined Mar 2008
Blue, the thing that's really nice about the McDonald's top is it's clear so you can see the blue LED for binding, it's rounded so it doesn't catch - it just rolls, and it's pretty tough for what it is and what it costs! I think I'll stick to mine and not get too wrapped up in anything expensive. Your foam one is great, though.
kodak_jack is offline Find More Posts by kodak_jack
Old Jun 04, 2012, 02:48 PM
BlueHavoc's Avatar
Joined Mar 2007
Thanks! I like the simplicity of the dome also, it's fairly durable & like you said, free!
Old Jun 04, 2012, 05:34 PM
kodak_jack's Avatar
Joined Mar 2008
FWIW, the guy who always sells returned Eflite stuff had an MQX on Ebay yesterday and the only thing it says is it's BNF and without a battery. Not bad for the price he was getting!!
Old Jun 05, 2012, 03:15 AM
ReasonSwe is offline
Find More Posts by ReasonSwe
Capt. Dennis
ReasonSwe's Avatar
Sweden, Västerås
Joined Jan 2004
A little more beer would have helped vastly
no drinking and flying
Originally Posted by Scootatrash View Post
Are you making sure to turn on the DX6i first, wait 4 or 5 seconds, then turn on the MQX? I know for sure if you turn on the MQX first you lose the bind.
think its that way I go, first TX then mQX.
will try it again later, and wait for 5-6sec.. will record it, so you can see if Im doing it right. haha
ReasonSwe is offline Find More Posts by ReasonSwe
Old Jun 05, 2012, 03:36 AM
teramax is offline
Find More Posts by teramax
sorry, my english is bad
teramax's Avatar
Austria, Wien, Vienna
Joined Apr 2011
Rubber tubing glued in:
CF sticks can be pushed in and out for higher ground clearance
happy FPV Bug
thats my mQX mod
teramax is offline Find More Posts by teramax
Old Jun 05, 2012, 03:52 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Hi guys. Anyone know where I can get similar kits to this, as this guy doesn't ship to the UK: http://www.sf-design-solutions.com/
Brentford RC do one but it only has two 5mm LEDs and uses heavy wire.
Thanks in advance.
Gerry__ is offline Find More Posts by Gerry__
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
