Old May 13, 2012, 09:23 PM
saskya is offline
Find More Posts by saskya
DR , EVIL
saskya's Avatar
Canada, QC, Montreal
Joined Apr 2012
Originally Posted by fred_dot_u View Post
There's a number of posts here and in other threads on the forum with suggestions where to purchase a reliable useful cam. Look in:
http://www.rcgroups.com/forums/showthread.php?t=1556994
for 101 pages of information to fill up your brain.
Ok going for that one is this ok or should get something else
http://www.ebay.com/itm/808-Car-Key-...ht_11650wt_786
saskya is offline Find More Posts by saskya
Old May 13, 2012, 09:58 PM
lostheli is offline
Find More Posts by lostheli
Registered Abuser
lostheli's Avatar
Joined Nov 2010
That's the best keychain cam out there, at this time.
lostheli is offline Find More Posts by lostheli
Old May 14, 2012, 10:47 AM
Scootatrash is offline
Find More Posts by Scootatrash
United States, RI
Joined Jan 2012
I hope so cause I just bought one. I hope it has a wider angle lens than the one I've been trying to use. I have this one here ...
http://www.amazon.com/Mini-DV-Worlds...7010243&sr=8-3
It's cheap, takes ok video, but is really not usable due to the narrow field of view.
Scootatrash is offline Find More Posts by Scootatrash
Old May 14, 2012, 11:15 AM
jgestner is offline
Find More Posts by jgestner
United States, WI, Merrill
Joined Jun 2011
Originally Posted by MJF View Post
Any video of the canopy upgrade from Park Flyer Plastics ...thinking of getting the MQX Interceptor canopy......any one tried this canopy yet ????
would love to see a vid of it....
Here is mine in post 21 and a youtube link from post #56 on the mQX alternate bodies and mods thread http://www.youtube.com/watch?feature...&v=dQ33ZVG4Ptc
I'm just using the top section both to save weight and to keep the original battery mount accessible. The Florescent Orange in front and Yellow in back help GREATLY! with orientation.
John in Merrill
jgestner is offline Find More Posts by jgestner
Old May 14, 2012, 03:51 PM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
like the idea, not to put the bottom on, it can catch air as you decend. I preferre to keep it open. or have a better designed botton, so we can attach the key cam. Very nice color scheme. I have yet to go get paint.
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old May 15, 2012, 12:46 AM
ecovato is offline
Find More Posts by ecovato
United States, CA, Glendale
Joined May 2012
I recommend getting the 808 #16. It is an awesome little camera, but I further recommend adapting the 808 #16 camera to run off of your receiver's 5VDC. Then you can remove the battery all together making it the plane lighter and ensuring that the recording lasts the entire flight. I did it on my plane and it works great. I got the adapter cable on ebay by searching "808 #16 receiver" -- got mine from this person: http://www.ebay.com/itm/808-16-DVR-R...#ht_500wt_1416
ecovato is offline Find More Posts by ecovato
Old May 15, 2012, 10:15 AM
MOfroggy is offline
Find More Posts by MOfroggy
East Texas
Joined Nov 2008
I need a little help. I fly my MQx with a DX6i. I have a DX5e that I want to give to my friend for when he gets his MQx. When I bind the DX5e to the MQx all I can get it to do is spin motors #2 and #4. I have the switches all set to normal (none reversed) and the throttle trim switch set all of the way to the bottom. Is there something I am doing wrong? I sure would appreciate some help.
MOfroggy is offline Find More Posts by MOfroggy
Old May 15, 2012, 03:09 PM
Zoandar is offline
Find More Posts by Zoandar
Ohio
Joined Apr 2008
Thanks for posting the link, but it looks like once the item is sold the link won't work. I tried it and it said the item had been removed. Can you provide additional information on the cable you got there?
Zoandar is offline Find More Posts by Zoandar
Old May 15, 2012, 03:38 PM
Zoandar is offline
Ohio
Joined Apr 2008
Have you guys noticed someone on eBay is asking $834 for this same camera?
Old May 15, 2012, 04:54 PM
Fearnow is offline
Find More Posts by Fearnow
Joined Mar 2012
Originally Posted by Username> View Post
I lost my v400 a Week or two ago and it was found lodged in a tree at about 50ft high.
As i'm a firefighter, I asked my watch manager if we could use the ladder lift to retrieve it.
It took a bit of talking to convince Him but we got it back.
Maybe you know a firefighter who could do the same?
The ladders on UK trucks reach to 84ft, but I don't know about US ones.
That's a great story. Go firefighters!
Fearnow is offline Find More Posts by Fearnow
Old May 15, 2012, 05:31 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Short answer: start adjusting the A, E, and/or R trims on the Tx so that all 4 motors spin-up evenly (the mQx manual hints at this, which surprised me a bit (using Tx trims for AS3X): it says to adjust the Tx trims to get an mQx into a stable hover).
I had a similar problem: I use a DSM2 module connected to a Hitec Tx.
With the A, E, R trims set to neutral, when I throttle up, 3 of the 4 motors would spin, but the front left motor would not (I am in X configuration).
As a result, as I throttle-up, my mQx would yaw and roll to the left.
To fix this, I first noticed that if I gave some right rudder and right aileron on the Tx as I throttle-up, I could bring the mQx into a hover.
So, I then added some right rudder and aileron trim on the Tx until my mQx could hover with very little A, E, R stick input.
flying-llama is offline Find More Posts by flying-llama
Old May 15, 2012, 05:42 PM
saskya is offline
DR , EVIL
saskya's Avatar
Joined Apr 2012
Item removed in ebay link do not work
Old May 15, 2012, 06:18 PM
Joined Oct 2006
http://www.ebay.com/itm/Mini-DVR-808...item2a1721820c
THis Link works
You ant service, that has a warranty, ttust me, if something goes wrong the team will gladely work with you, no moatter what, any other seller may not give you what tehse guys have, that said good luck. not sounding upset etc.. not to hard to find is it , Lol
you hve 27 days to view it
Old May 15, 2012, 06:31 PM
lostheli is offline
Registered Abuser
lostheli's Avatar
Joined Nov 2010
I think the dead link was for a cable. Like this http://www.ebay.com/itm/808-16-DVR-R...item231d4b396a
Or you can buy the cam and cable PLEASE DON"T BUY THIS! I was joking.
There are a few certain vendors that you should buy the #16 camera from and fishycomics' link points to one of them.
Old May 15, 2012, 08:34 PM
Zoandar is offline
Ohio
Joined Apr 2008
Or this one:
http://tinyurl.com/irridiumplateddiamondstudded
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
