Latest blog entry: UM Stryker
I'm pretty sure I've seen it listed somewhere before as a suggestion from HH if you are having difficulty binding. I'm not sure the logic but I tried it because nothing else was working.
On my first mQx flight I had d/r set to 75% on low for all axis with step 2 and 3 set to 100% and 125%. I was amazed at how responsive it was at 75%, so much so that it only needed slight stick movements to fly circuits. I did turn them all up to 125% for a minute to test, and I was more amazed. Today I hope to find a nice big grassy field to test this out more. |
Belgium, Walloon Region, Plombières
Joined Jul 2011
No offense but I wish people would just be clear about expo, dual rate, and travel adjust on the DX6i.
Travel adjust (also called servo endpoint adjustment) can be set anywhere between 0 and 125% and determines the total travel of a servo. Or in the case of the mQX, the total range of adjustment in a channel. Dual rate can be set anywhere between 0 and 100% independently for high and low and determines a relative value of how much of the servo travel is being used for the position. D/r cannot be more than 100%. Thus for example if servo travel is set at 125% and d/r is set at 50% the total available travel is 62.5% of what the servo is capable of. Lastly, expo determines the shape of the curve between 0 and full travel. A value of 0 means it is a straight line (directly proportional). The higher the value the more bowl-shaped the curve is, meaning the initial travel movement has the least effect. It serves to "dumb down" the sticks near their 0% position and make them exponentially more effective towards full deflection. It does not change how far a servo travels, it only determines how it responds to stick movement. If you want to determine how effective a servo is, use travel adjust. If you want to have two different settings of that, use dual rate with two different values. If you want to adjust how harsh a servo reacts to your stick movement use expo. That's it. |
Joined Apr 2008
4x4rc, that's very well put. I've also noted in other forums comments made by people who use negative exponential travel, so they have extreme sensitivity near the center of the stick movement, slowing near the limits. It makes little sense to me to have such a configuration, but apparently those who use it are satisfied with the results.
Because the mQx and other multi-rotor aircraft do not have physical servos, can one set the travel adjust beyond 100 percent and effect a genuine difference? I would think that 100 percent is the electronic limit of the action for that channel and it would be impossible to go beyond that. |
Just acquired one of these little guys tonight, used but in perfect order. Bound to my DX8, set all rates at 40% and put two batteries through it, in my living room and kitchen area.
I am an RC Plane guy, but this looks fun. Had a ball with it already. Looking forward to the indoor gym session I'm going to in 10 days time. |
Ohio
Joined Apr 2008
4x4rc, thanks for the clarification. Over the winter, while not using the DX6i, I have a tendency to muddle the D/R and Expo definitions in my mind. Before I got the mQX the only indoor helis I had use their own OEM transmitters with no programability. Now the mQX will allow me to fly something year round with the DX6i, so hopefully those terms will remain clear to me.
I, too, would like to know if increasing travel adjust beyond 100% on the mQX is really doing anything. Perhaps it is, based upon how the controller interprets the incoming commands from the TX, but it isn't like being able to measure a servo arm travel. I am wondering if an optical tachometer used on one of the motor shafts could measure the actual result of setting travel beyond 100%? If the props were removed this could easily be tested on a bench. The tiny motor shaft diameter might be an issue though. Might have to make a flywheel of some sort (or maybe a spare prop shaft gear?) and color half of it black in order to have enough reflective surface to get an accurate measurement. Or, if the chassis could be held down well enough, perhaps remove 3 props and listen to the sound of the running prop and compare 100% to 150% to see if the pitch sound is higher. |
Joined Jul 2011
zoandar: You could also measure the total current at the JST plug or use an optical tach to measure rpm with the props on.
I don't know if the 125% endpoint adjustment is ignored or not, though I agree with jasime2501 that the mQX definitely becomes quicker to react. Probably just because full travel is reached sooner and then maintained. As an example I find flipping performance of the mQX to be about the same with both EPAs, though it is a lot more skittish to fly on 125%. |
Ohio
Joined Apr 2008
One of the things mentioned on pages 22-23 of the DX6i manual is that either accidentally or intentionally powering it on the TX with the trainer switch engaged unbinds the TX. They said it was discovered that some folks using TX trays were having this happen by the switch bumping the tray when powering on. Apparently it is an instantaneous result. I know I have had to re-bind my HBFP and Blade 400 now and then. Not a lot though. But it seems pretty easy to accidentally unbind the TX. I wonder if that could also happen in conjunction with the presence of a lot of nearby metal when powering up the TX? |
Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
The mQx manual says:
I haven't experienced the bind issue at all with my early run mQX unit. I have a dx7s. I've bound it three times in total but only because I bound it in advanced mode first then + mode to try it out and then back to X. I'm assuming all of the folks having bind issues are following the binding instructions from the mQX manual and not the radio manual? It does have a sort of nonstandard bind method.
enjoy, Mtz |
| Thread Tools | |
| Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i | nyaaah!! | Aircraft - Electric - Micro & Indoor Airplanes | 11 | Oct 06, 2011 11:21 AM |
| For Sale New Blade 400 RTF Will sell as BNF | papower | Aircraft - Electric - Helis (FS/W) | 8 | Aug 04, 2011 12:28 PM |
| Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X | ABADGTP | Aircraft - Electric - Helis (FS/W) | 0 | Jul 26, 2011 07:22 PM |
| Sold Blade MCX2 Like New RTF or BNF | tamiyafan1975 | Aircraft - Electric - Helis (FS/W) | 1 | Jul 14, 2011 03:39 PM |
| Sold Blade mCPX RTF or BNF (factory sealed new in box) | PatternFlyer | Aircraft - Electric - Helis (FS/W) | 5 | Mar 28, 2011 03:25 PM |
