Paul |
Belgium, Walloon Region, Plombières
Joined Jul 2011
Returning to the subject of the mQX for a moment (ahem) I just went out back to practice flips. I had the keychain cam on the quad and suffice to say the additional weight really makes them interesting!
![]() There would have been a few nice scenes on chip I think but of course the stupid thing turned itself off right after takeoff so I have to do it again tomorrow. Whoever thought up the "user interface" of the 808 deserves a good quartering...
Oh. Is this the mQX thread? lol Sorry.
I have an 808 cam as well.. I think I am going to sell it though. the one I have seems to be pretty low quality and i don't love the extra weight on the mQX. I look forward to seeing your vid tomorrow though. Winds are supposed to be 8mph for about 2 minutes today so i am headed to the flying field with my pt-19 and mQX after work. No cams on me though. I can't wait. |
Joined Jul 2011
My wife just suggested I stop borrowing my friend's #11 all the time and get my own. How could I not obey?
![]() Not sure yet whether to get a #16 and strip it bare to lose the weight of the keyfob. Or go ahead and get this FPV setup http://fpvhobby.com/96-8ghz-micro-combo-set.html which is actually far lighter. Hmmm...
) I've been meaning to research FPV options with the mQX... |
Joined Jul 2011
![]() Quote:
- Mark
Regarding LiPo voltage - it is not terribly complicated. Detailed information on pretty much any battery chemistry is readily-available online from many reliable sources.
Open-circuit voltage on a fully-charged LiPo is 4.2V/cell, while nominal voltage under load is 3.7V/cell. Discharging below 3V will cause immediate cell damage. Terminating the discharge at the 80% point (as measured on a charger that displays the mAh required to recharge) will maximize performance & cycle life. For those who are powering gear that specifies an operating voltage range rather than cell-count, just do the math. If you're running unregulated 3s LiPo power, your gear needs to operate safely on 12.6V, as that's what it will see on a fresh pack before throttle is applied. Make sure that it can also operate reliably below 9V so that peak loads don't cause brown-outs. If it's a 1s app, make sure that your gear can operate safely & reliably from 4.2V down to about 2.8V. If you're using LiFePO4cells (A123) rather than LiPo, Open-circuit voltage is 3.6V/cell, while nominal voltage under load is 3.3V/cell. Max discharge is 2.8V/cell, so 1s gear needs to operate down to about 2.5V. Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Cedar Rapids, IA
Joined Aug 2010
+1 turbo
Also I don't care what the specs say a motor is not limited by voltage (unless over 100V depending on the wire) its based off the amps/watts (I.E. Prop size). So as long as you don't exceed the wattage rating of the motor then the number of cells don't matter. The board will run off of the 5V to 6V BEC of the ESC. So if the ESC can take it or you use a separate BEC your fine. |
Joined Jul 2011
Mate it to the DX6i and get only the video on the iPad, that would be awesome. |
Not to mention those ar drone II's are $299. At least they added Android support. But I'm like you. I don't want to control anything RC with my phone. I think the mQX is an interesting micro FPV platform. I flew mine outdoors at the flying field again yesterday and it was awesome. It really steals some thunder from my beloved pt-19.
I have the mostly 5.8ghz micro combo set from fpvhobby, at 17g, it has very minimal affect on flight, I had to geta dpcav.com cam as fpvhobby's was dead vid, mic worked, cam is on a spare canopy in front, Vtx in rear, battery velcroed in center, it's two trim clicks to hover. I should be getting the DVr in a couple of weeks.
I found spending time flying the mQX with fpv canopy and batt, gave me more understanding on weight changes. I'm going to get aio or fatsharks, the myvu's are ok, but not being able to change pupil to pupil distance is giving me headaches.... |
| Thread Tools | |
| Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i | nyaaah!! | Aircraft - Electric - Micro & Indoor Airplanes | 11 | Oct 06, 2011 11:21 AM |
| For Sale New Blade 400 RTF Will sell as BNF | papower | Aircraft - Electric - Helis (FS/W) | 8 | Aug 04, 2011 12:28 PM |
| Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X | ABADGTP | Aircraft - Electric - Helis (FS/W) | 0 | Jul 26, 2011 07:22 PM |
| Sold Blade MCX2 Like New RTF or BNF | tamiyafan1975 | Aircraft - Electric - Helis (FS/W) | 1 | Jul 14, 2011 03:39 PM |
| Sold Blade mCPX RTF or BNF (factory sealed new in box) | PatternFlyer | Aircraft - Electric - Helis (FS/W) | 5 | Mar 28, 2011 03:25 PM |
