Old Apr 11, 2012, 06:07 PM
Always, against the wind
Thetis's Avatar
United States, IL
Joined Oct 2011
Originally Posted by vanzant View Post
I've wanted one of these for a while. They are either out of stock or I have no money or I just bought a new toy yesterday. It's always something. Finally, last night, I ordered a mQX BNF and a Spektrum DX6i. If I'm lucky, it will be here Friday or Saturday.
My only other RC is an mSR X. Looking forward trying the DX6i on it.
Good Times.
Welcome aboard, I am sure you will have many enjoyable flights!
Thetis is offline Find More Posts by Thetis
Old Apr 11, 2012, 09:37 PM
Seeker of Thermals
botulism's Avatar
United States, Mt, Kalispell
Joined Aug 2004
Originally Posted by pgoelz View Post
The battery connector wire pads are covered with silicon, so it would have to be scraped off. Not sure how big the pads are under the silicon.
They're covered with WHAT??? How can they be covered with silicon? I don't think I even know what silicon looks like, is it like sand (silica) ?
Oh, you must mean silicone ! As in silicone rubber! I get it now. <- for the humor impaired.
Greg
botulism is offline Find More Posts by botulism
Old Apr 12, 2012, 02:59 AM
I make quad pieces.
United States, WA
Joined Apr 2012
Headlight for my MQX
I found an old Laser pointer that also had a LED. Attached it to the mqx and was surprised at how bright it is. My droid camera did not like it much.
EBen63060 is offline Find More Posts by EBen63060
Old Apr 12, 2012, 07:08 AM
woodbury,ct
Joined Mar 2002
BNF - very sensitive to controls
Thanks to all of you for your inputs to my question. I understand a little better why it does what it does.
turboparker - you mentioned an "undocumented" method of activating preprogammed expo on the RTF tx. Would you elaborate further on this?
I have only the RTF tx to use for this machine. I also have a Futaba Skysport 6A, but that is on 72 mhz, not 2.4ghz. Hmm, maybe convert this to 2.4 ghz! Would that help?
pgoelz - you mentioned in one of your posts balancing the props. I don't see how this can be accomplished since the prop hub is not a consistent diameter all the way through.
Dave
a67ems is offline Find More Posts by a67ems
Old Apr 12, 2012, 07:27 AM
pgoelz's Avatar
United States, MI, Rochester Hills
Joined Oct 2000
Dave
If you use a 2mm rod, it will fit the smaller hole in the end of the prop snugly and allow the prop to be balanced. I have a magnetic balancer and made a 2mm steel rod for it a while ago, to balance small heli blades and tail blades. I find that 2mm is the right size for many small balancing tasks.
Paul
pgoelz is offline Find More Posts by pgoelz
Old Apr 12, 2012, 07:51 AM
Mtz
Mtz's Avatar
Romania, PH, Ploiesti
Joined Mar 2012
Why are you, people, using the laser pointer?
Mtz is offline Find More Posts by Mtz
Old Apr 12, 2012, 09:03 AM
Joined Feb 2005
To turn the mQX into a WMD.
matefrio is offline Find More Posts by matefrio
Old Apr 12, 2012, 09:08 AM
Did you commit aviation today?
turboparker's Avatar
East Bethel, MN USA
Joined Jul 2009
Dave
Dave,
The expo feature was discussed in one of the UM threads. Unfortunately, I don't remember which one. I suggest searching the UM fixed-wing & mCP X threads. From what I remember, the amount of expo was relatively small, so it won't make a big difference in feel. Maybe someone else will chime-in with the details.
Regarding your tx - there is no easy (or US-legal) means of converting it to Spektrum 2.4 GHz (remember - the various 2.4 GHz spread-spectrum systems are not compatible with each other). If you want to stay with Futaba, you'll need a module-based tx, such as the 10C. Otherwise, the DX6i would be a good choice for an entry-level programmable tx - if you plan to buy more Spektrum-equipped BNF/RTF aircraft.
Joel
turboparker is offline Find More Posts by turboparker
Old Apr 12, 2012, 09:13 AM
East Bethel, MN USA
Joined Jul 2009
Would that be a weapon of minor destruction?
Joel
Old Apr 12, 2012, 10:34 AM
docinfrance's Avatar
Joined Dec 2010
Finally there is a solution to the Mqx motors burning out.
http://www.ehirobo.com/shop/product_...ducts_id=11720
docinfrance is offline Find More Posts by docinfrance
Old Apr 12, 2012, 10:43 AM
Mtz
Mtz's Avatar
Joined Mar 2012
Good one! I think all that solution is big like the whole mQX motor.
We want bigger and you show us smaller?
enjoy,
Mtz
Old Apr 12, 2012, 10:48 AM
Joined Feb 2005
We have no idea how much the replacements are on that copter or how often the burn out. Also how much do the Tx cost?
Nice little bird but too many unknowns.
Old Apr 12, 2012, 11:40 AM
Sonic Rainbooms for all
airpower's Avatar
Joined May 2007
a67ems, put it in + mode, it will be a little smoother that way.
airpower is offline Find More Posts by airpower
Old Apr 12, 2012, 11:41 AM
Joined Dec 2010
There were a lot of unknowns with the mQX when it first hit the market.
It was only after time (and I'd bought one) that the motor problem became apparent, and NO I haven't killed a motor yet, but I'm careful. I keep my flights short and my motors lubed with a special NATO silicone free gun oil. No point me suggesting it, most people will never find it.
While the Walkera ladybird is an unknown it is the first viable alternative small quad out there.
http://www.oomodel.com/walkera-qr-la...r-p-62658.html
Price RTF (devo 2404d TX) $129.80 (vs $170 for the blade)
spare motor and arm set $6.40
4 prop set $3.36
Board $44.80
Battery $4.86
I'd say for price RTF is good and spares slightly cheaper then the mQX.
At least it gives a choice of mini quads now.
Old Apr 12, 2012, 02:57 PM
pgoelz's Avatar
Joined Oct 2000
Shirley, you jest!
I wouldn't pay a nickle for ANYTHING Walkera produced. I know some like their products, but I've been bitten before, won't do it again. It does, however, show that the quad market is heating up.
Paul
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
