Old Mar 28, 2012, 01:29 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Originally Posted by kodak_jack View Post
In many cases, two bladed props on quads are replaced with 3 bladed ones. Has anybody tried this on this quad?
I saw a description, either here or more likely over at Helifreaks. As I recall, the poster was "Heli-yeah!"
It was pretty messy, as the 3 blade props (like most non-mQx specific props) do not have a hole on the stem for a screw.
The mounting procedure that I read involved a number of extra parts and creating a screw thread on the top of the inside of the CF propeller shaft.
flying-llama is offline Find More Posts by flying-llama
Old Mar 28, 2012, 01:58 PM
kodak_jack is offline
Find More Posts by kodak_jack
kodak_jack's Avatar
Hilton (Rochester), NY
Joined Mar 2008
Yikes! Threading a CF rod?!!!!!! I think I'll pass.
kodak_jack is offline Find More Posts by kodak_jack
Old Mar 28, 2012, 02:03 PM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Agreed who wants a Carbon splinter that will last you a life time
Kris... is offline Find More Posts by Kris...
Old Mar 28, 2012, 06:54 PM
Thetis is offline
Find More Posts by Thetis
Always, against the wind
Thetis's Avatar
United States, IL
Joined Oct 2011
Micro burst ?
i was flying/hovering her @ around 25-30 feet high with 50% throttle and all of a sudden I saw her coming straight down without me cutting the throttle. I increased the throttle to 80% but still was coming faster down. She gradually gained height before reaching 10 feet from the ground. There was a very slight breeze and no leaf movement, clear skies and around 82F. That was a close call. May be a small micro burst? Has anybody else expereined such a situation?
Thetis is offline Find More Posts by Thetis
Old Mar 28, 2012, 07:01 PM
kodak_jack's Avatar
Joined Mar 2008
As we are prone to say in industry, it was FM ( Magic).
Old Mar 29, 2012, 12:35 AM
turboparker is offline
Find More Posts by turboparker
I'd rather be flying!
turboparker's Avatar
Joined Jul 2009
I've experienced something similar on occasion. It is an aerodynamic phenomenon specific to rotorcraft, called 'settling with power'. It can happen when hovering out of ground effect without maintaining precise altitude control, and while making downwind or steep, powered approaches when the airspeed drops to nearly zero.
The bird starts descending in its own rotorwash. The descent-rate increases rapidly. The rotor partially stalls. The pilot adds power, but the descent-rate continues to increase. The rotor-stall spreads outward from the hub, which further increases the sink-rate. The rotor(s) start to make the stalled-prop sound - like the sound an airplane's prop makes during a power-on tailslide. If left unchecked, this can rapidly progress to vortex ring state. Cyclic control may be dramatically reduced or lost. The rotorcraft may pitch & roll as it decends. On multi-rotor craft, one or more rotors will usually stall before the others, which causes lateral stability problems. The rotor states are in constant flux. The aircraft sort of flutters on the way down, as the controller fights to keep the bird upright.
Most high-performance RC rotorcraft have enough power on tap to muscle their way out of the situation on thrust alone - provided that it is not allowed to progress to vortex ring state. The quickest way out is to gain forward airspeed as soon as the first symptoms are detected.
http://en.wikipedia.org/wiki/Vortex_ring_state
Joel
turboparker is offline Find More Posts by turboparker
Old Mar 29, 2012, 12:39 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
Thanks for sharing Joel
Old Mar 29, 2012, 08:53 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
New micro quad
Looks like there is another micro quad just come on the market.
CLICK
Old Mar 29, 2012, 09:38 AM
Thetis is offline
Thetis's Avatar
United States, IL
Joined Oct 2011
Thanks very much Joel for the explanation. Always getting older but wiser
Old Mar 29, 2012, 09:40 AM
Thetis is offline
Thetis's Avatar
United States, IL
Joined Oct 2011
CLICK
Very nice find. I like the + orientation color. Very competitive to Q. Thanks for sharing.
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
CLICK
That looks like a rebadged Walkera UFO8#. That means the UFO#8 is no longer current. Walkera rebadges "old" technology to Buzz Flyer, Banana Hobby, Exceed and others. I had one, nothing special performance-wise. Kind of flies like an HBFP. Quad control boards and multiple axis gyros have improved a lot since this bird was introduced.
Balr14 is offline Find More Posts by Balr14
Old Mar 29, 2012, 09:51 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
I think you could be right never noticed this one before as i dont look at the Walkera stuff
Old Mar 29, 2012, 10:51 AM
matefrio is online now
Find More Posts by matefrio
Joined Feb 2005
Got my MQX late Feb. 2012. Two black top motors went out this month. I don't think I've used it excessively or treated it badly. Here's what Horizon has said:
Thank you for contacting Horizon Hobby's Product Support Department.
These are brushed motors. They will need replacing. As the brushed motor is used the internal bushes will ewear down. When this happens it will get a loss of rpm, motor might get hot and shut down. This is normal it is not a defect in the motors. We replaced it donce as a courtesy. You will have to replace the motors out -of-pocket.
The motors are on backorder. When the come into stock they will be shipped to you at no charge
matefrio is online now Find More Posts by matefrio
Old Mar 29, 2012, 10:55 AM
Thetis is offline
Thetis's Avatar
United States, IL
Joined Oct 2011
Thanks Balr14. Already is out of my must check list. Any info regarding the Parkzone Quad?
Old Mar 29, 2012, 10:58 AM
kodak_jack's Avatar
Joined Mar 2008
Materfrio, in one sentence it says you will have to pay for them out of pocket and in the next it says they will ship the motors to you at no charge. Shouldn't the third grader writing that be in class?
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
