Old Mar 07, 2012, 03:34 PM
Thetis is offline
Find More Posts by Thetis
Always, against the wind
Thetis's Avatar
United States, IL
Joined Oct 2011
Originally Posted by Sparky Paul View Post
Keyfob (CMOS) camera shutter activity..
Paul, really impressive !
Thetis is offline Find More Posts by Thetis
Old Mar 07, 2012, 04:12 PM
pgoelz is offline
Find More Posts by pgoelz
pgoelz's Avatar
United States, MI, Rochester Hills
Joined Oct 2000
Originally Posted by egaus View Post
WD40 in the top or bottom (pinion side) for best mileage?
e
WD-40 is too thin to be a good bearing lube so I would only use it on the top so it wicks into the brush area. And I am not representing it as the best solution.... just one that works for me and is readily available. There are likely better lubes out there for brushes but A) I don't have any and B) unless they are very thin like WD-40, it may not be possible to get any into the motor unless you have the version with holes in the end bell.
FWIW, my RF motor that began to fail very early on and was treated a couple times with WD-40 continues to run perfectly. In the mean time, my LR motor (that also showed early signs of failing and was WD-40 treated as well) began to run with consistently lower power than the other motors, causing a left lean on liftoff. It was also causing more than the usual instability when recovering from an upset. I finally replaced it with the motor HH sent me when the RF motor began to fail and all is well once again.
The next CW motor that fails will get replaced with a CCW motor just for grins. Anyone else tried that?
Paul
pgoelz is offline Find More Posts by pgoelz
Old Mar 07, 2012, 05:55 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by pgoelz View Post
Looks good! You can eliminate most, if not all, of the vibration-induced rolling shutter (Jello wiggle) effect by carefully balancing all four props. I put each prop on a prop balancer and balance with a piece of clear Scotch tape on the under side. Makes for real smooth video.
Paul
+1
I did the same after watching my first Jello-filled mQX on-board video. Worked like a charm.
Joel
turboparker is offline Find More Posts by turboparker
Old Mar 07, 2012, 07:56 PM
Thetis is offline
Thetis's Avatar
United States, IL
Joined Oct 2011
+1
WD-40 works fine for me so far.
Old Mar 07, 2012, 08:04 PM
rcpilot23 is online now
Find More Posts by rcpilot23
rcpilot23's Avatar
Perth, Western Australia
Joined Feb 2007
I have one prop that is harder to spin than the other 3 but then after while it spins freely again. weird.
The quad flys fine and im doing lots of flips and rolls
rcpilot23 is online now Find More Posts by rcpilot23
Old Mar 07, 2012, 08:10 PM
stablehover is offline
Find More Posts by stablehover
Joined Mar 2011
I used Deox-it available at Radio Shack on two motors that had failed. One fly's perfectly now and other is in the trash can. My motors had holes in the endbell and I just let it rip, drained used a little air and aways she went. Both failures were on CW and HH replaced both, those failed also. HH knows something is going on kid on the phone said it could be a board issue. That was on my second call. It was like talking to my teenage kids so I just let it go. I am on my fourth motor on CW so something is up for sure. The motors that fail run at a higher temp and show odd signs on spool-up and spool-down. Way to much fun to quit now.
stablehover is offline Find More Posts by stablehover
Old Mar 07, 2012, 08:17 PM
Toywizard is offline
Find More Posts by Toywizard
Toywizard's Avatar
Groton NH USA
Joined Feb 2002
Originally Posted by jedoug View Post
Here is some video of my MQX from a recent indoor fly in we had.
http://www.youtube.com/watch?v=WV9Hx...b1FAAAAAAAACAA
Jedoug
What are you using for a camera? Your video looks a heck of a lot better than what I am getting off of a keychain cam.
Toywizard is offline Find More Posts by Toywizard
Old Mar 07, 2012, 08:21 PM
TheOne420 is offline
Find More Posts by TheOne420
Chad
TheOne420's Avatar
United States, CA, Cathedral City
Joined Dec 2010
well I got my order of FET's in today and the one i got is working great as a direct replacement for the one i fried. so now i need some motors and a few more booms and I will have me a very nice little spider quad for a keychain cam
TheOne420 is offline Find More Posts by TheOne420
Old Mar 07, 2012, 08:36 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Originally Posted by Toywizard View Post
Jedoug
I like to post at least a jpg of the camera(s) on my planes in my videos...
Sparky Paul is offline Find More Posts by Sparky Paul
Old Mar 07, 2012, 08:54 PM
Toywizard's Avatar
Groton NH USA
Joined Feb 2002
" I like to post at least a jpg of the camera(s) on my planes in my videos..".
This keychain cam on the left(I got 2) leaves a lot to be desired.
The second one I got a couple of years ago. Back then it was expensive but its cheap today.
It takes "good enough" videos in the air and have used it tons of times. I was hoping to get a key chain cam that would come close so I could mount it easier.. Notice I split my
visual aid and mounted them on the motor cages.
Old Mar 07, 2012, 08:59 PM
Monstermanhbf is offline
Find More Posts by Monstermanhbf
I Always Fly Inverted
Monstermanhbf's Avatar
United States, PA, Springdale
Joined Aug 2004
The DICE Cam works pretty good!
Not my video but a friend of mine on his MQX
Dice Cam on MQX Quad (2 min 39 sec)
Monstermanhbf is offline Find More Posts by Monstermanhbf
Old Mar 07, 2012, 09:07 PM
Toywizard's Avatar
Groton NH USA
Joined Feb 2002
Dice Cam
oh ya
Nice quality for the size. Price is great too. What does it weigh? does anyone know?
Old Mar 07, 2012, 09:33 PM
Joined Jul 2009
On-board video
Here's an indoor clip I shot with my old #3 cam mounted under the belly with Velcro:
Blade mQX indoors - on-board video (4 min 4 sec)
Joel
Old Mar 08, 2012, 05:28 AM
Eric the Red is offline
Find More Posts by Eric the Red
United Kingdom, Southend-on-Sea
Joined Jan 2012
You boys in the USA are lucky -no BNFs available in England yet (mine's on order) only RTF
Eric the Red is offline Find More Posts by Eric the Red
Old Mar 08, 2012, 05:31 AM
scotsoft is offline
Find More Posts by scotsoft
Master Of My Universe
scotsoft's Avatar
Newcastle, UK
Joined Jul 2010
You should have tried Scotland in that case
http://www.marionvillemodels.com/rc-..._EFLH7500.html
scotsoft is offline Find More Posts by scotsoft
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
