Between my tx and crashed aircraft
Joined Mar 2006
http://en.wikipedia.org/wiki/Accelerometer "However, the proper acceleration measured by an accelerometer is not necessarily the coordinate acceleration (rate of change of velocity). Instead, it is the acceleration associated with the phenomenon of weight experienced by any test mass at rest in the frame of reference of the accelerometer device. For an example where these types of acceleration differ, an accelerometer will measure a value of g in the upward direction when remaining stationary on the ground, because masses on earth have weight m*g. By contrast, an accelerometer in gravitational free fall toward the center of the Earth will measure a value of zero because, even though its speed is increasing, it is at rest in a frame of reference in which objects are weightless. " As far as I can tell, this works with orientations that have to do with the earth's gravity (pitch and roll), so to speak. This will not work with orientation in the yaw direction (all directions experience the same "acceleration" from the earth's gravity). And in fact, for measuring yaw direction, multi-copters often use magnometers (compasses), not accelerometers. |
Semantics aside.... As I stated - with the mQX, orientation does not matter at all during initialization. The only thing that matters is that the bird remains motionless during the process. Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Joined Mar 2006
You can use as is, if you do not want to customize. Or if you do want to customize, all the code is available on the web (but you really better know what you are doing ).Looking at that source code gives me a sense of what may be stuffed into the program code for an AS3X controller (true, with some differences: most planes do not have compasses, and tip stall is not really a worry with heli's). |
United States, GA
Joined Jul 2007
You guys are driving me nuts....ordered my MQX today and can't wait. Been flying my yellow and blue S107G and S033G and it sounds like they'll go on the back burner when the MQX gets here. Gotta do the fuselage changes, too. Tell me the source of these things.
Sparky's site is at the following: http://parkflyerplastics.com/cart/in...ain_page=index. Please, please read the instructions and abide by them it makes a major difference in the rigidity of the pod to leave a small gluing ridge around the pod halves. Makes for a much stronger pod and easier to assemble. The instructions are offered on Sparks site. ed
Joined Feb 2012
A few posts up Stresscracked says that some of the connectors haven't been fully seated before the "RTV" has been dabbed on, I assume he is talking about the same white goop. |
Most people don't particularly care about accuracy in their writing and are more than comfortable with using ambiguous terminology. As long as they understand what they mean, they don't really care if anyone else understands it. Sometimes that is ok. When it is not ok is when someone is legitimately confused by this inaccuracy, and is not afraid to admit it, and is begging to have it clarified, and then instead of helping the person, people just use their confusion to attack them with under-handed insults. That is not cool. Nobody deserves to be treated that way.
Joined May 2007
Hi fs2flyer !
On my craft, the connectors could not be fully seated because the material had intruded into the mating surfaces. In order to seat fully, the "goop" needs removal. I made the posting in order to address an issue due to a possible intermittent contact. At these low voltages, poor contacts become significant. If your craft does not exhibit problems, I would not worry, because the connectors need something to prevent movement. A better solution than the "goop" would be a small section of shrinkwrap, used in the same manner as when securing servo extension connectors to prevent them from disconnecting. |
Point is - the accelerometer debate started a bunch of pages ago when some people were claiming all sorts of things about the mQX that were 100% wrong - such as the self-stabilizing myth, and that the bird had to be level during the initialization process. 1) We know that the mQX doesn't use accelerometers. 2) We know that it has absolutely zero self-stabilizing capability. 3) We all know that it can be initialized in any orientation. These are the facts. What do you hope to accomplish by continuing to argue semantics every time someone (quite correctly) uses the word 'accelerometer' in this thread? Joel |
Joined Mar 2006
In the multi-rotor copters, one typically uses accelerometers for measuring the roll & pitch orientations, and a magnometer (compass) for the yaw orientation. In looking at some of the multi-rotor copter flight controllers, they tend to refer to all possible sensors (and there are quite a few: I can recall gyros, accelerometers, magnometer, barometer, sonar, "gps") by the type of sensor and not by what they are "trying" to measure, which I think is, respectively: change in orientation, XY axis orientation, Z axis orientation, Z position (height), relative position of nearby obstacles, XY position. |
Toronto Canada
Joined Dec 2002
I discovered that if I quickly blipped the right stick, the heli would move a distance away, but would self-stabilize. I attributed this to pendulum behaviour with the majority of the mass of the copter under the thrust line. When the copter was flipped, it also managed to return to a level position with minimum input. A longer input and the release of the right stick would make the copter continue on the intended path. In the mSRX thread there has been considerable discussion of the behaviour of the AS3X system. In the mSRX heli, quick rudder input doesn't significantly affect the heading hold behaviour of the swash gyros. Longer rudder inputs (1/2 second), switch the swash gyros from heading hold mode to rate mode. My reason for mentioning this is that I am now curious to compare how the AS3X gyros behave in the MQX with quick stick inputs and longer control stick inputs. Is the sytem designed such that quick inputs leave the gyros in heading hold mode and longer inputs switch to rate mode? The only reason that I bring the matter up is because of the differences that I observed with the copter behaviour when using quick blip inputs and longer inputs. One test might be to connect a servo to the receiver output and examine its behaviour instead of using the ESC and motor. |
| Thread Tools | |
| Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i | nyaaah!! | Aircraft - Electric - Micro & Indoor Airplanes | 11 | Oct 06, 2011 11:21 AM |
| For Sale New Blade 400 RTF Will sell as BNF | papower | Aircraft - Electric - Helis (FS/W) | 8 | Aug 04, 2011 12:28 PM |
| Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X | ABADGTP | Aircraft - Electric - Helis (FS/W) | 0 | Jul 26, 2011 07:22 PM |
| Sold Blade MCX2 Like New RTF or BNF | tamiyafan1975 | Aircraft - Electric - Helis (FS/W) | 1 | Jul 14, 2011 03:39 PM |
| Sold Blade mCPX RTF or BNF (factory sealed new in box) | PatternFlyer | Aircraft - Electric - Helis (FS/W) | 5 | Mar 28, 2011 03:25 PM |
