Old Dec 28, 2011, 05:14 PM
sdculp is offline
Find More Posts by sdculp
Joined Jan 2005
Park 250 vs Rimfire 250
Just when I started to get comfortable with motor specs, I started comparing the Park 250 with the Rimfire 250. The "250" numbers sort of imply sameness, but the Park seems to be basically a 50 watt motor while the Rimfire is 100 watts. Kv doesn't mean all that much to me--maybe it should. Is wattage the way to compare motors? Or what??
sdculp is offline Find More Posts by sdculp
Old Dec 28, 2011, 05:30 PM
BladeScraper is online now
Find More Posts by BladeScraper
Custom User Title
Joined Jun 2011
Rimfire have always been more powerful. Really, the wight is most important in my opinion, but then again, im no expert :/
-kpilot
BladeScraper is online now Find More Posts by BladeScraper
Old Dec 28, 2011, 06:07 PM
shultz is offline
Find More Posts by shultz
United States, NV, North Las Vegas
Joined Sep 2009
Rimfire motors are in general HIGHLY overrated... run that little 250 at the max 90w or burst of 120W it WILL smoke in short order
The park 250 is a good little motor...over priced IMHO but still a good little motor. you CAN run it to rated specs... it's smooth...quiet and will 3D a 6oz plane with ease. My E-flight L-4 at about 10oz has plenty of power on the park 250
Be careful of the motor wires...they don't like being flexed or vibration. I secure them with a little shoo goo to the stator/windings and a dab of hot glue secures the 3 leads some where to the fuse/ motor box ect... just do what ever it takes to keep the wires from moving around
John
shultz is offline Find More Posts by shultz
Old Dec 28, 2011, 06:08 PM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
IMO, Rimfire motors are somewhat over-rated for power. You can generally count on about 75 watts of "safe" power consumption per ounce of motor mass. The Rimfire 250 is .71 ounces, so that works out to a bit over 50 watts.
On the other hand... I see at the Tower Hobbies website, that the Rimfire 250 is rated for 90 watts continuous. So if you can prove that it fails at something less than 90 watts, they should send you a new one, right?
Wattage is only one measure of motor performance; kV is the other major parameter. The kV, combined with the supplied voltage (eg. 11 volts for 3S) determines the range of props you can use with it. Higher kV typically goes with smaller props, and vice versa.
rafe_b is offline Find More Posts by rafe_b
Old Dec 28, 2011, 06:16 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
I have a Rimfire 400 in my PT-19 from Electrifly and it does very well. IMHO, sized to the plane correctly, the Rimfire brand is just fine.
dkrhardy is offline Find More Posts by dkrhardy
Old Dec 28, 2011, 07:28 PM
Custom User Title
Joined Jun 2011
I have got a Rimfire 22M-1000. It is not on the size list, but here is a link:
http://www.aeromicro.com/catalog/gre...or_4885450.htm
I think it is about 370 size, but not sure.
I tried it on a Electrifly Pluma, and it was a bit too powerful, pulled out of a loop and wing broke off :/
With the Rimfire motors I got, I think they are GR8 motors!
Well, I have seen on e-fliterc.com the park 250 is a little, weaker? Lighter? The Rimfire motors seem to be good so far in my opinion. A little pricey, but then again, balanced out by great performance. I will try to fix my Pluma and post a video of it with the 22M-1000 and see how it is.
Old Dec 28, 2011, 09:01 PM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
Another vote for Rimfire specs being someone's pipedream.
The eflite 250 is merely OK but at least honest.
flydiver is offline Find More Posts by flydiver
Old Dec 28, 2011, 09:29 PM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
I'll throw you a curve ball. The Hobby King Park 250 is a great substitute for the E Flight Park 250, and only costs $10. We have run several, and the are very similar in weight, size, and performance.
http://www.hobbyking.com/hobbyking/s...dProduct=14399
aerolite
aerolite is offline Find More Posts by aerolite
Old Dec 28, 2011, 10:51 PM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, FL, Bonita Springs
Joined Oct 2010
I had two E-flight park 250 I was using is a 5 oz 3d foamy and it had barly enoph power to pull out of a hover. Both motores also only lasted a few months before burning up on me. I have sice discovered the Hacker A10-9L, it is cheaper than the E-flight and has a lot more power.
3Daddict is offline Find More Posts by 3Daddict
Old Dec 29, 2011, 09:13 AM
sdculp is offline
Joined Jan 2005
Thanks for all the info. I guess the "250" is kind of a guideline, but the bottom line is experience.
Old Dec 29, 2011, 09:37 AM
flydiver is offline
flydiver's Avatar
Joined Jan 2007
In a word...Yes.
What matters is KV, weight, and output (watts/amps) and you have to be somewhat suspicious of the output specs as a lot of companies take some liberties with that info.
Old Dec 29, 2011, 11:44 AM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
Originally Posted by flydiver View Post
In a word...Yes.
Actually, they list the input, and not the output.
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Dec 29, 2011, 12:14 PM
justindh is offline
Find More Posts by justindh
Cessna 25T clear for departure
justindh's Avatar
United States, TX, Houston
Joined Mar 2011
aerolite
I bought one of those (2050kv version) and want to use it with the supplied prop adapter. How would you recommend I do that?
I was able to remove the shaft but it won't stay in the other way around. Do I need to cut a slot for the c-clip and file a flat on the other side for lag screws?
I hope I didn't break the motor but if I did it was a cheap $10 lesson to ask questions before getting out the hammer...
justindh is offline Find More Posts by justindh
flydiver is offline
flydiver's Avatar
Joined Jan 2007
Correct.
Old Dec 29, 2011, 03:54 PM
aerolite is offline
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
I'm not familiar with which motor you are refering to. This is a park 250 substitute, and comes with a prop adapter already installed.
We are flying 5 oz depron foamies with this motor, and it has plenty of power for general flying and 3d. Hovers the planes well.
It doesn't have as much power as the Hacker A10-9L, but neither does the E-flight Park 250.
aerolite
For Sale (2) E-flite park 300 & (1) park 250 leif-mindy Aircraft - Electric - Power Systems (FS/W) 5 Apr 17, 2011 08:15 PM
Found Rimfire 250 / Rimfire 28-22-1380 SRM Aircraft - Electric - Power Systems (FS/W) 1 Mar 07, 2011 08:20 AM
Discussion Turnigy 2204-14T as a Replacement for Park 250 or Rimfire 250 ShokWaveRider Electric Plane Talk 2 Aug 12, 2010 07:26 PM
Wanted WTT rimfire 300 for a rimfire 250 or Hacker 9L scottiesoccer1 Aircraft - Electric - Power Systems (FS/W) 0 Aug 08, 2010 09:07 PM
Discussion Park 250 3 cell vs. 2 cell jhark37 Power Systems 4 Jun 13, 2008 07:53 PM
