This thread is privately moderated by mrforsyth, who may elect to delete unwanted replies.
Old Dec 27, 2011, 11:54 PM
So. Cal.
Trader Rating: 59
12V/24V 1150 Watt Power Supply!
"Feed your hungry chargers!"
Up for sale are combination 12/24 volt, 47 amp power supplies with total power output capability of 1150 watts. These supplies are made from two high quality HP server supplies that are permanently attached to one another and wired in series to provide 24 volt output. They also feature a 12 volt output to allow simultaneous operation of two chargers. They are also easily convertible to three 12 volt outputs within seconds by simply removing the convenient series jumper harness. All outputs have gold plated 4mm sockets to accept standard 4mm male banana plugs. Also have a 24 volt version with EC5 output for FMA PowerLab owners.
Compact (4.5” x 3” x 12”) and lightweight (<7 lbs) so it's highly portable. The base of the supply has been fitted with polyurethane feet to protect the surface of your workbench and provide excellent grip. DC return to chassis ground is internally isolated to provide maximum safety and allow operation from a single Y-power cord (included w/purchase).
Supplies have power factor correction with PF >.99. This means that you can easily operate your 1000 watt charger from a single 110V / 15A home circuit. They are full turnkey and ready to go. Simply plug your chargers into the 4mm sockets, plug in the power supply, and start charging. The fans are super quiet and load dependent so they're perfect for use in an indoor environment and provide optimum cooling for long term reliability.
These supplies can easily operate an iCharger 306B, 3010B, FMA PowerLab 6, PowerLab 8, etc., at 1000 watts of charge power.
What’s in the box:
  • High quality 12/24V, 1150 Watt Power Supply
  • 6’ high quality professional grade molded Y- Power cord (operate from single outlet)
  • Series jumper harness
  • Free mating 4mm banana plugs, if needed (enter number of plugs needed in PayPal Note box to receive free plugs)
  • Free technical support
  • 1 year warranty
  • World-class customer service
All supplies are fully tested at various load conditions and come with 1 year warranty.
Simply click on the "Order now!" link to place your order:
Price for 12/24 Volt Convertible Supply is $130 including USPS Priority shipping within the US or APO. ---> Sold out
Dual output (Dualie) 24 Volt Supply is $125 shipped. ---> Sold out
Standard 12V/24V (non-convertible) Supply is $125 shipped. ---> Sold out
24 Volt with EC5 output for FMA PowerLab chargers is $125 shipped. ---> Sold out
Single output 24 Volt Supply is $120 shipped. ---> Sold out
I can also do local pickup in the Los Angeles area.
International orders welcome! I have shipped several to Canada, Australia, UK, and Norway. PM me for additional shipping cost and payment instructions.
Simply click on the above links to order. PM me if you have any questions. Completed supplies in stock and ready for immediate shipment. Typical delivery times are 1 to 3 days. Custom wiring requests welcome as well.
***My power supplies now come fitted with heavy duty white PVC covering to protect from dirt, scratches, and the hot summer sun.*** Previous customers can PM me to obtain the PVC covering at a nominal cost.
Thanks!
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Dec 28, 2011, 12:05 AM
Northern IL
Joined Sep 2006
Trader Rating: 51
PM sent
skypan12 is offline Find More Posts by skypan12
Old Dec 28, 2011, 12:15 AM
Northern IL
Joined Sep 2006
Trader Rating: 51
Funds have been Sent for one of the 12/24V, This should feed my 2 PL8"s
Old Dec 28, 2011, 12:21 AM
So. Cal.
Trader Rating: 59
It'll feed two PL8's provided total charge output power does not exceed ~1000 watts.
Your PS is boxed up and will ship in the morning.
Mark
Old Dec 28, 2011, 12:24 AM
Northern IL
Joined Sep 2006
Trader Rating: 51
Sounds Good, yup aware of that.
Old Dec 31, 2011, 05:12 PM
United States, GA, Byron
Joined Feb 2011
Trader Rating: 9
PM sent
Scorpian is offline Find More Posts by Scorpian
Old Jan 08, 2012, 04:38 PM
Joined Feb 2011
Trader Rating: 9
Power Supply
Power supply works Great!!!
Randy
Old Jan 11, 2012, 07:58 AM
Joined Feb 2011
Trader Rating: 9
If you ganged 3 power supplies together could you get 36v?
Randy
Old Jan 11, 2012, 11:53 AM
So. Cal.
Trader Rating: 59
Hi Randy,
Yes, it is totally possible to add another power supply to increase available voltage and I have done exactly this on one custom request. As these supplies have output voltage of ~12.5V, total voltage for three in series would be ~37.5V. Since this is higher than most chargers will accept, one must check acceptable input voltage range for whatever device is to be powered by the supply.
Regards,
Mark
Old Jan 12, 2012, 11:00 AM
ProgressiveRC
write2dgray's Avatar
Seattle, WA
Joined Dec 2006
Trader Rating: 82
Nice job on your conversions Mark, very clean!
Cheers,
David
write2dgray is offline Find More Posts by write2dgray
Old Jan 13, 2012, 10:18 AM
So. Cal.
Trader Rating: 59
Thanks for the kind words, David! Hope all's well up your way!
Regards,
Mark
Old Jan 24, 2012, 11:43 PM
USA, CA, Huntington Beach
Joined Jun 2005
Trader Rating: 1
I will take two of the 12/24V supplies.
PM sent.
Gary
gbancrof is offline Find More Posts by gbancrof
Old Jan 29, 2012, 06:09 PM
Joined Jun 2005
Trader Rating: 1
Awesome power supplies Mark! Appreciate the fast shipping. Have been running them all weekend and they're perfect. Very clean job!
Thanks again.
Old Feb 01, 2012, 01:50 AM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Trader Rating: 50
Look very good...
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 17, 2012, 10:04 AM
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
Trader Rating: 8
have one of these and it works great.
DenverJayhawk is offline Find More Posts by DenverJayhawk
For Sale *Power Supplies* iCharger 306b + 24V 1000w 41a Power supply(2 12v in series) + box paulpeffly Aircraft - Electric - Batteries & Chargers (FS/W) 8 Jan 06, 2013 09:53 AM
For Sale *Power Supplies* iCharger 306b + 24V 1000w 41a Power supply(2 12v in series) + box paulpeffly Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 07, 2012 06:08 AM
For Sale *Power Supplies* iCharger 306b + 24V 1000w 41a Power supply(2 12v in series) + box paulpeffly Aircraft - Electric - Batteries & Chargers (FS/W) 0 Dec 21, 2011 01:16 PM
For Sale *Power Supplies* iCharger 306b + 24V 1000w 41a Power supply(2 12v in series) + box paulpeffly Aircraft - Electric - Helis (FS/W) 0 Dec 14, 2011 07:41 PM
