Old Dec 27, 2011, 06:55 PM
JimMcWhorter is offline
Find More Posts by JimMcWhorter
JimMcWhorter's Avatar
United States, VA, Chantilly
Joined Apr 2011
Real Flight Airport Editor - 3D (Not Photo Realistic)
I am starting this thread in hopes of getting some help buidling airports in Real Flight 6.
I downloaded the PDF manual - really not much help. Has anyone created a tutorial on how to make a new airport (not photorealistic) or remember where one is on RCG?
Please help if you can ....
JimMcWhorter is offline Find More Posts by JimMcWhorter
Old Dec 27, 2011, 06:57 PM
Joined Apr 2011
My Initial Attempt - 3D Airport - Skyview
I have a new field partially built but need to learn how to add a hill to a runway.
The other problem I figure out is why trees don't show up. In the Environment > Edit mode I have trees lining the road. When I choose File > Exit To Simulatorthe trees are not there. In the View>Scenery I have selected All.
How do I make it so if I run into a building or a fence that it causes damage to the airplane or heli?
What settings/specifications makes Painted Canyon a sorta island in the sky (you can literaly fly out of the simulation into nothingness) and Flight School endless - you can literally fly any direction for hours and RF will keep generating scenary?
If I knew how - I would gladly upload Skyview Airpark so you could see what I've done and where I want to go with this
Old Dec 27, 2011, 07:04 PM
Joined Apr 2011
Lake Anna Aiport (7W4) Bumpass Virginia
What is the magic switch that allows you to draw something to actual dimensions? When I insert a runway and set the length - RF automatically sets the width.
Example: http://www.airnav.com/airport/7W4
The Bumpass Airport (7W4) runway at Lake Anna in VA is 2,558' long by 50' wide. Put 2,558' into the runway length parameter and RF makes the width 366' - wide enough to land the space shuttle.
How do I make RF accept manual input of width and length?
Old Dec 27, 2011, 07:08 PM
jeffpn is offline
Find More Posts by jeffpn
Joined Mar 2011
You would do better to join the RF forums and ask there. There are lots of people who will help you. If they give you a rough time, tell them you're with me.
http://www.knifeedge.com/forums/
jeffpn is offline Find More Posts by jeffpn
Old Dec 28, 2011, 06:37 AM
Joined Apr 2011
What a great suggestion! I see that you are a frequent poster on Designing Airports - Tips and Tricks hosted by 12oclockhigh. I sent you a PM via knifeedge.com/forums. In the PM I explained that the current thread had little or no 3D airport creation information. To that end and your suggestion, I created a new thread on knifeedge.com/forums called Designing Aiports in 3D (Not Photo Realistic)" This thread is dedicated to 3D aiports only.
Thanks - see you on KnifeEdge ...
Old Dec 28, 2011, 06:42 AM
Joined Apr 2011
Closing the Thread ......
If interested in creating airports in REAL FLIGHT - please go to:
Then go to:
Knife Edge Forums> RealFlight - Designer's Corner> RealFlight 6 - Designer's Corner
For Photo Realistic Fields - see 12oclockhigh's Designing Airports - Tips and Tricks
For 3D Fields - see my thread Designing Aiports in 3D (Not Photo Realistic
Best of luck!
Discussion Flying at a (full scale, not real) airport spacecase Aerial Photography 3 Feb 20, 2011 10:21 AM
Poll Photo realistic or pure 3d fields ? skirtz Simulators 10 Apr 20, 2008 06:13 PM
Real Flight V-22 (Is It Realistic?) Talon Driver Simulators 4 Apr 15, 2004 07:54 AM
