This thread is privately moderated by DLGjunkyard, who may elect to delete unwanted replies.
Old Jan 05, 2012, 09:39 PM
Whisper Wings
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
What are you using for tooling? Also are you bulking with sand?
heliwill10 is offline Find More Posts by heliwill10
Old Jan 05, 2012, 10:11 PM
no place like cloud base
DLGjunkyard's Avatar
Canada, ON, Cambridge
Joined Apr 2010
The tool coat was my own mix of graphite powder,aluminum powder,west 403 filler.
I did the tool coat till green then two layers of 3/4 glass then progressively up to 5.8 oz clothe. After about 5 or 6 layers I threw sand in along the edges of the fuse and kept going with glass and more sand etc. The sand pushes resin to the surface and every so often I would sprinkle dry sand in and watch it soak up resin. The last layer of sand I mixed was just moist really knowing it would be fine
DLGjunkyard is offline Find More Posts by DLGjunkyard
Old Jan 06, 2012, 10:39 AM
Whisper Wings
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Here is what I'm going to try. It actually fairly reasonably priced.
http://www.adtechplastics.com/pc-45-...at-system.aspx
Are your kevlar pods still have some FG?
Old Jan 06, 2012, 10:44 AM
Whisper Wings
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
This for bulk:
http://www.adtechplastics.com/pc-52-...-compound.aspx
Two gallons of the stuff is 100$. Just called today for prices becuase I was afraid
Talking to the guy on the phone only a few layers behind the toolings of e glass is need and then some 7oz or so behind the dough.
Old Jan 06, 2012, 11:06 AM
Joined Apr 2010
The amount of tool coat is not much but do you use that resin for the entire mould? Tool coat is brittle to some degree.
Old Jan 06, 2012, 04:03 PM
Whisper Wings
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
The tool coat is something different then the epoxy. I understand this is the stuff Adam uses. Its much harder and lasts longer....
The dough, is the same as sand but it is much lighter weight. Which is somewhat a concern with my mold because it going to be so large and bulky.
Sold Carbon DLG pod sporter Aircraft - Sailplanes (FS/W) 1 Dec 11, 2011 08:54 AM
Sold Dlg pod [fibre glass] DLGjunkyard Aircraft - Sailplanes (FS/W) 1 Oct 29, 2011 09:45 AM
Sold Sporter SGII-ish DLG pod Wave Glider Aircraft - Sailplanes (FS/W) 0 Oct 17, 2011 08:14 PM
Build Log Micro DLG pod making process Rendy Hand Launch 42 Sep 16, 2007 12:48 AM
Build Log SG-II & Arrow pod hybrid mould done eitanro Hand Launch 14 Mar 04, 2007 04:39 AM
