This thread is privately moderated by Roswalt, who may elect to delete unwanted replies.
Old Dec 27, 2011, 10:30 AM
Roswalt is offline
Find More Posts by Roswalt
Trader Rating: 97
Capt, USAF
Roswalt's Avatar
United States, NV, Las Vegas
Joined Feb 2009
Trader Rating: 97
Sold
TX LPU: F-16 Thunderbird w/ Thrust Vectoring, BNF $100
This is an F-16 electric ducted fan jet aircraft. It is totally assembled, painted, and ready to fly. The only thing you will need to add is your own transmitter and battery. Here's a brief rundown:
-Full flying stabilators (Tail surfaces) with one servo each
-Long ailerons with one servo each
-Y-cables for each
-Full 360 degree thrust vectoring with scale exhaust nozzle - one servo per axis
-Steerable nose gear and rudder, linked with single servo
-Scale undercarriage including painted main gear doors and ventral fins
-Magnetic canopy for easy battery access
-Brushless motor and ESC
Receiver now included!
-Spektrum AR6100 receiver, 2.4ghz DSM2
Requires a standard size 2200mah 4-cell Lithium Polymer battery pack and Spektrum 2.4ghz-type transmitter.
This jet has been coated in water based polycrylic so that it will shine like the real thing. The gear doors were also redone for accuracy and better magnets were installed for the canopy. You receive two free shiny nickels added to the rear section of the jet for balance, alone with some dremel work to the battery bay so that you can seat your battery further back - The stock CG is nose-heavy, so you will not be having as much of a problem with this design. It's been flown twice with great results. Body is made of crash-resistant EPO foam, wingspan is about 30", length is 40".
Local pickup only, in San Antonio Texas. Thanks!
Roswalt is offline Find More Posts by Roswalt
Old Dec 27, 2011, 01:47 PM
porcia83 is offline
Find More Posts by porcia83
Trader Rating: 128
United States, CT, Hartford
Joined Jun 2009
Trader Rating: 128
Nice plane!
porcia83 is offline Find More Posts by porcia83
Old Dec 27, 2011, 04:46 PM
Roswalt is offline
Trader Rating: 97
Capt, USAF
Roswalt's Avatar
Joined Feb 2009
Trader Rating: 97
Thanks, I'm hoping it will go to a nice home where it won't be destroyed - It's one of the prettiest planes I've ever had in the fleet. It just doesn't see any air time thanks to the custom F-22 I put together.
It hangs on the wall doing display duty and makes great decorative art, but it is ready to launch!
Old Dec 27, 2011, 05:19 PM
smkn951 is offline
Find More Posts by smkn951
Trader Rating: 24
smkn951's Avatar
United States, HI, Kapolei
Joined Jan 2007
Trader Rating: 24
man i wish you were closer.......
smkn951 is offline Find More Posts by smkn951
Old Dec 27, 2011, 09:48 PM
Roswalt is offline
Trader Rating: 97
Capt, USAF
Roswalt's Avatar
Joined Feb 2009
Trader Rating: 97
Sold, thanks guys!
Discussion New Freewing 70 mm F-16 w/Thrust Vectoring chrisper27p Foamy EDFs 1170 Jun 16, 2016 01:10 PM
Discussion Need help wiring up Thrust Vectoring on f-16 Rone3 Foamy EDFs 10 Jan 07, 2012 01:42 PM
Help! Banana Hobby F 16 with Thrust Vectoring LelandWebb Foamy EDFs 2 May 08, 2011 11:33 AM
Discussion Banana Hobby model 2120 F 16 with thrust vectoring and bad servos LelandWebb Banana Hobby 0 Apr 01, 2011 01:42 PM
Discussion New Lander F-2B (F-16) with 360 degree thrust vectoring jpflyer Foamy EDFs 1 Mar 04, 2010 12:27 PM
