Old Dec 27, 2011, 04:53 AM
Ldm is online now
Ldm
Find More Posts by Ldm
Ldm
Ldm's Avatar
United States, PA, Conestoga
Joined Jun 2006
Power suggestions please -FW D9 Dora
So far with the frame , including the existing Robart heavy scale wheels its at 6.4 pounds that has the servos calculated along with a radio flight pack, receiver and 4 servos. Rudder , Elvator , 2 flaps , and current set up 1-alerons (internal belcrank).
If you figure
1)1lbs to 1.5 for the retracts depending on the brand (i am going eletric )
2)monster 110 is 17 oz
3)esc =3 oz
I think i am about 9.3 ready to go with no -lipos calculated , biggest weight gain is the motor .
If I go with a 60 size or 90 size motor , obviously I will lose weight but dont know the power needed yet .
The plane was designed around a 60 to 90 2 stroke , typically = 110 or 120 4 stroke
Would love to get away with less motor =less batterys but I dont really think I have a choice and I figure the Monster 110 = a 120 4 stroke .
The plane is a wood frame Dave Platt 64" Dora , I picked it up at $130 totally built never flown . I will bash it to more scale and a better paint scheme .
Need help on the Motor if you feel the 110 is over kill and esc and battery set up please ,
Thanks for any suggestions
Ldm is online now Find More Posts by Ldm
Old Dec 27, 2011, 10:48 AM
FieldofDreamsFlyer is offline
Find More Posts by FieldofDreamsFlyer
Field of Dreams Flyer
FieldofDreamsFlyer's Avatar
United States, CA, LA
Joined Sep 2004
Problem with having a plane with a long nose you have to be careful of it being nose heavy. This nice plane should do fine with a 60 size motor on 6s for scale flight. Or maybe a 90 on 6 or 8s. 110 is a over kill.
FieldofDreamsFlyer is offline Find More Posts by FieldofDreamsFlyer
Old Dec 27, 2011, 11:52 AM
Ldm is online now
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
Thanks Twiz , that is my concern , I am thinking 90 because it was designed around a 60 2 stroke .
I can always go 2-4cell packs if needed but space is at a premium in the nose . I removed the tank and looking at my best hatch options unless I chose to remove the wing . The plane was build so well that removing the wings is literally a 3 min process
Old Dec 27, 2011, 01:53 PM
Ldm is online now
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
You know Twix , its 14.8 oz for the 60 size vs 17oz for the 110 , so I am going with the 110 turning a 16-10 3 balde or a larger 2 blade . I figure I can go half throttle if needed but will have great power when needed .
I move the batterys into the fuse back further if needed , now to find a three bladed spinner is the real challenge , Skyshark onlt has two bladed FW spinners
Old Dec 27, 2011, 02:01 PM
Joined Sep 2004
I think from skyshark you can get the spinner without cutouts you might what to ask
Old Dec 27, 2011, 02:22 PM
Joined Sep 2004
Try this place they could make you one
http://www.genebarton.com/
Old Dec 27, 2011, 04:43 PM
Ldm is online now
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
Thanks Twiz , always a help !!!
Old Dec 27, 2011, 05:06 PM
V2rider is offline
Find More Posts by V2rider
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
Then again you could go with the power 90 on a 6s 5000ma pack and save over a half pound in weight,(over an 8s 5000ma set) and still run an APC 15.75x13x3 for about 8 minutes give or take. Pitch speed about 79mph
V2rider is offline Find More Posts by V2rider
Old Dec 27, 2011, 09:04 PM
Ldm is online now
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
V2, thanks great advice , Power 90 , that is eflight correct ? I know Monster /Hobby Parts does not have a 90 size motor .
I like the idea of one single pack , i like the run time your suggesting , and prop size .
If I cant find or dont want to spend the super dollars on a custom spinner do you have a suggestion on a good two blade prop on the power 90 ?
Old Dec 28, 2011, 08:46 AM
V2rider is offline
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
Not sure on a 2 blader for the 90. I'm in the same search mode for a 3 blade spinner for my Kyosho FW-190. Thinking of heading to Hobby Hanger in Chantilly to see what they have. What diam would you need for yours? I'll check for you while I'm there. The stocker Kyosho spinner won't let me use a 14x9x3 MAs without notching the prop. I don't think I want to do that on a 1000 watt system.
Old Dec 28, 2011, 11:29 AM
Ldm is online now
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
Thanks I will settle for anything from 2.5 to 3" as long as the FW shape is correct .
I noticed some Pitt style spinners that are close but again not in the correct size
Old Dec 28, 2011, 11:35 AM
Joined Sep 2004
Kyosho does make a 3 blade spinner . Theres in option in the spinner to make it 2 or 3 blade because my friend has the Kyosho Spitfire and P-40 and using a Master Airscrew 3 blade and hes using a 60 size motor on 5s spinning a 15in 3 blade.
Old Dec 28, 2011, 12:52 PM
TripleW is online now
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
And don't forget the EMP 15x8 three blade.
I'm running it with a MP 60 on 6s.
http://www.valuehobby.com/emp-neodym...ar-prop-5.html
TripleW is online now Find More Posts by TripleW
Discussion Top Flite FW-190 D9 Dora andernamen Fuel Warbirds 5 Apr 09, 2016 10:55 PM
Discussion Help with Jemco Fw-190 D9 baldguy Scale Kit/Scratch Built 0 Nov 16, 2011 07:56 PM
Found FW-190 D9 kit (Top flite, Pica or Platt) Ken Lapointe Aircraft - Fuel - Airplanes (FS/W) 5 Apr 01, 2011 12:23 PM
Discussion Alfa Fw-190 D9 Dora sperry Electric Warbirds 22 Jun 19, 2007 01:25 PM
Video Fw-190-D9 "Dora" Maiden Flight Hans-Joachim Electric Plane Talk 0 Jan 07, 2007 11:58 AM
