Old Jan 18, 2012, 09:42 PM
Wargassm is offline
Find More Posts by Wargassm
Wargassm's Avatar
United States, CA, Lake Forest
Joined Nov 2010
Originally Posted by v8truckin View Post
Well the post a page or few back contradicts what you say, freewing has upgraded to 2849 2300kv. That's the 1st I've heard of 2849 2200kv. The box shows 2839 2200kv.
http://static.rcgroups.net/forums/at...1photo%202.jpg
so i guess the black and purple motors are 2300kv?
Wargassm is offline Find More Posts by Wargassm
Old Jan 18, 2012, 10:01 PM
merlinfan is offline
Find More Posts by merlinfan
Throttle Bender
merlinfan's Avatar
Joined Jun 2008
U gonna ask about motors?
They wouldn't have a clue as to the KV of those motors.
merlinfan is offline Find More Posts by merlinfan
Old Jan 18, 2012, 10:02 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Rc castle says the black and gold are 2300kv, but someone posted pics of those motors showing 2200kv on the box. Black and purple are still 2200kv 1st run motors. Until BH says or proves otherwise.
v8truckin is offline Find More Posts by v8truckin
Old Jan 18, 2012, 10:03 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
lol! Ya I bet!
Old Jan 18, 2012, 10:54 PM
DamonH is online now
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
I received my BH plane today and have a couple of questions. First, I know there was initially some confusion as to which way the ESC bay panel was supposed to face. Which way was determined to be correct? Also, does anyone see an issue with the servo wires running through ESC bay and the proximity of them to the ESC's with the heat they will generate?
My motors are the purple can ones as well.
DamonH is online now Find More Posts by DamonH
Old Jan 18, 2012, 11:42 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
esc vent/duct should have slots facing forward do direct air in rather than out.
Old Jan 19, 2012, 01:56 AM
Antaeus is offline
Find More Posts by Antaeus
Antaeus's Avatar
United States, CA, Irvine
Joined Oct 2001
New addition to my fleet.
Thanks to Wargassm. I picked up one of each color scheme at AMA 2012.
First flight was last Saturday. Tried 3 different batteries. 5000 Sky Lipo, 4000 Gens Ace, and 4500 Genesis. I am flying 155mm to 160mm CG.
Genesis from BH has the most kick amongst the 3 packs.
Balanced the fans and they are quiet comparing to HETs and RCL fans.
SU35 is faster than the LX Mig29 with HET powerplants. I think the STOCK powerplants are very good for the money. I would not upgrade them.
Antaeus is offline Find More Posts by Antaeus
Old Jan 19, 2012, 05:30 AM
kydawg1 is offline
Find More Posts by kydawg1
"Aircraftus Fragmentum"
kydawg1's Avatar
United States, MI, Detroit
Joined Mar 2007
Nice looking AIR FORCE there.
kydawg1 is offline Find More Posts by kydawg1
Old Jan 19, 2012, 06:05 AM
SU-4ever is offline
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Yeah, nice airforce indeed!
Su,
140g both esc's with wires.
V8, was that with the extra cables or ESCs alone?
If you can't weight them without the soldered wires, can someone else do?
DamonH and Antaeus, you seem to have your planes still out from the box (Antaeus, you mention you bought two airframes maybe the second one is yet to build) so could you weight the ESC alone as they come raw with the kit?
Thanks!
SU-4ever is offline Find More Posts by SU-4ever
Old Jan 19, 2012, 08:02 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
That was with the motor wires & battery wire. You can not remove em unless you clip em off.
Old Jan 19, 2012, 09:34 AM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
don't know how wargassm is getting cg at 150mm, with his 4900mah at the tailend of battery tray. I put a gens ace 4000mah 640g at the nose of the battery tray n can't cg @ 150mm, need to add weight or move forward. Flightmax 5000mah 850g 1/2" from nose of battery tray cg'd at 150mm. Wouldn't think those -60g make that big a difference on cg/battery location...guess so.
This is where my cg is at 150mm (below)
http://static.rcgroups.net/forums/at...the%20fuse.jpg
So I took a gens ace added weight to equal 800g, put a back of battery tray & still can't get a cg @ 150. Cg is @ 160-162mm with 800g.
are these test per motor or dual motors?
All of these numbers are a single EDF Fan/Motor setup. They are not exaggerated numbers because if you search Het 2W25 and Wemo across RCG many get around the same numbers putting these together themselves.
Mark from ExtremeRC is just much better at it putting together very good PnP drive setups so I get what I can from him if I just want it to work without me tinkering.
The Wemo/2W25 weighs only 187g, 12g more than factory but put out at least 1.8 kilos even with bad setups at 60amps.
The appeal to me is I can roll back on the throttles to a combined 3Kg and be burning less amps than the factory setup that still can't even get to 3Kg.
Thats why I picked it. And notes he used 25C batteries. These are just light and efficient.
Mark was surprised that the new CS fans and his secret motor actually also put out 2kg each at 60amps. Generally it needs more watts and my only reason for not choosing his was he only sells them with the alloy housing and the AUW on them are 225g. So using them would add 76g in the tail but now with more clarification on which batteries you used and where you placed them I realized I actually could have gone for them if I really wanted that turbine sound.
I posted the 155mm CG reference point. Do we all agree that that is the 155mm CG?
If so its not a matter of just getting batteries around a certain weight but where you place them relative to CG makes a big difference.
I'm not sure again your understanding re batt weights because moving CG ref point forward 155mm to 150mm, you would need even more battery weight not less. If you moved to 145mm you'd have to move that 842g battery forward to the bulk head. Balancing CG further foward is a more stable nose heavy setup and will need more weight to balance.
10mm (155mm-145mm) makes all the difference at CG and that is closer to the planes neutral. The battery tray is some 200mm-250mm at the strap forward of CG-155mm so ever little gram can exert a lot more force. A lighter battery full forward can exert the same force and a heavier 15mm back.
But if you don't include V8 like you reported, having a separate BEC and Battery and where you positioned it, or anything else you may have added or removed, it can look very different but is actually bang on.
To get consistent clear estimates, you need to be using the same reference point. You both seem to be using the pic I posted. From there you need accurate battery weights and then where you placed the battery in the tray.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Jan 19, 2012, 10:01 AM
HardAbz is offline
Find More Posts by HardAbz
HardAbz's Avatar
Texas
Joined Jul 2001
I received my Su-35 from BH yesterday, as well! Black and purple 2200kv motors, 3D version.
HardAbz is offline Find More Posts by HardAbz
Old Jan 19, 2012, 10:06 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
I'm not using a separate rx battery, just a separate bec & and satellite receiver.
Old Jan 19, 2012, 10:15 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
I understand the battery weight and where to move em around according to cg. I'm trying to keep my cg @ 150mm. I know I can go to a lighter battery if I use a 155mm cg, but id prefer to keep it @ 150mm. Just personal preference. I just don't understand how some are getting 4000-4400mah balanced @ 150-155mm. Just asking.
Old Jan 19, 2012, 10:19 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
I trust your specs on the wemo. Just wondering if that with single or dual specs. Since those are similar to the CS 10 blade I'll just stick with the CS, if & when they arrive. Thanks Max!
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
