Old Jan 18, 2012, 06:23 PM
SU-4ever is online now
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Originally Posted by Maxthrottle View Post
Shouldn't matter much since one end sits at CG. I'm guessing 70-81g.
If you descide to position them aft of the wing bar in the center channel the mean location is 100mm aft of CG-155mm so going to a 80amp ~120g ESC X 2 will go to her AUWaist line.
Well it actually matters but not for CG balance.
I'm deciding on alternative ESC and I want to keep weight down. Remember I'll be putting gyros, delta mixers and so on, and I want to know how much weight can I save with ESC replacement
Though I guess I'm gonna put twice as much weight in ESC wiring than in the Speed controller itself, still I prefer to have some reference number to compare.
Cheers!
SU-4ever is online now Find More Posts by SU-4ever
Old Jan 18, 2012, 06:39 PM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Su,
140g both esc's with wires.
v8truckin is online now Find More Posts by v8truckin
Old Jan 18, 2012, 07:59 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
The post I posted earlier today with the watt meter reads was of 2500kv cyclone, my bad...forgot about those being used.
Sustained (not peak)
2849 2300kv motors
Gens ace 4000mah 6s 25c
10awg (batt to esc)
13awg (esc to motors)
2940g (weight with batt)
2502g (static thrust)
81.60a
1760w
21.60v
5000mah 50c flightmax
8awg (battery to ec5)
10awg (ec5 to esc)
13awg (esc to motor)
3160g (weight with batt)
2609g (static thrust)
74.12a
1550w
21.09v
Old Jan 18, 2012, 08:30 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Wemos get spun just faster and faster and just keep putting out higher numbers. The primary cost is the bigger motors to turn them. Its only been the recent alloys that have taken one of Wemo's crown but they don't come close in weight or cost.
ExtremeRC.Com tested and available combos with a 70mm mini.
For 4S drivers I'd recommend;
HET 2W18 Typhoon motor:
4s2500mah: 14.64 Volts / 54.2 Amps / 795 Watts / 45,160rpm / 1.46kg thrust
For 6S drivers;
HET 2W25 Typhoon motor:
6s4000mah: 22.89 volts / 61.4 amps / 1407 watts / 53,700rpm / 2.1kg thrust
ARC2848-1 motor:
4s4400mah: 14.75v / 94.9A / 1400W / 52,440rpm / 2.02kg thrust
ARC2858-1 motor:
4s2600mah: 14.5v / 41.5A / 600W / 40,620rpm / 1.15kg thrust
*6s4000mah: 21.63v / 86.7A / 1877W / 56,460rpm / 2.5kg thrust / 360kmh EFFLUX!!
are these test per motor or dual motors?
Old Jan 18, 2012, 08:36 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
don't know how wargassm is getting cg at 150mm, with his 4900mah at the tailend of battery tray. I put a gens ace 4000mah 640g at the nose of the battery tray n can't cg @ 150mm, need to add weight or move forward. Flightmax 5000mah 850g 1/2" from nose of battery tray cg'd at 150mm. Wouldn't think those -60g make that big a difference on cg/battery location...guess so.
This is where my cg is at 150mm (below)
http://static.rcgroups.net/forums/at...the%20fuse.jpg
So I took a gens ace added weight to equal 800g, put a back of battery tray & still can't get a cg @ 150. Cg is @ 160-162mm with 800g.
Old Jan 18, 2012, 08:54 PM
merlinfan is offline
Find More Posts by merlinfan
Throttle Bender
merlinfan's Avatar
Joined Jun 2008
1+45 on chat with"Marrry". Lots of Q&A and then I was told a 17g elev servo white wire will ship in 4-7 days. Got email to confirm. Still thinking of 2 85mg Hitecs, look like a drop in fit. I really think this a nice plane might pull trigger on rc Castle one.....
merlinfan is offline Find More Posts by merlinfan
Old Jan 18, 2012, 08:56 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
U gonna ask about motors?
Old Jan 18, 2012, 08:57 PM
Wargassm is offline
Find More Posts by Wargassm
Wargassm's Avatar
United States, CA, Lake Forest
Joined Nov 2010
left my cable to connect my cell @ work, i took pics tonight.
the zippy Rhino 6s 4900ma is from hobbyking, deminsions are posted.
its a long battery as the picture will show.
Wargassm is offline Find More Posts by Wargassm
Old Jan 18, 2012, 08:58 PM
Wargassm is offline
Wargassm's Avatar
Joined Nov 2010
the ones i have are purple and black.
Old Jan 18, 2012, 09:03 PM
Wargassm is offline
Wargassm's Avatar
Joined Nov 2010
ok maybe my measurements are off, but only by a few mm. its balanced just infront of where the metal spar fits into the plane. when we measured it it was @ 150mm so we thought.
with gear down, the part of the foam next to the wheel, uneven part that is where I CG the jet. hmm ok ill go put it back togeather and re balance it the way i had it @ the field.
Old Jan 18, 2012, 09:10 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
just trying to figure out how I can squeeze a lighter battery in there. If she flying fine then leave her. Its more for my reference and maybe others. I guess I'm just gonna keep the 5000mah. Although your motors may have some to do with weight & cg.
Old Jan 18, 2012, 09:11 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
sorry wargassm,
that was ment for merlinfan.
Old Jan 18, 2012, 09:15 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
tried hs65mg on ailerons and they didn't fit.
Old Jan 18, 2012, 09:23 PM
Wargassm is offline
Wargassm's Avatar
Joined Nov 2010
Please hang with me as i try to explain without pictures where i CGH the SU-35.
bottom of the wing, where the servo wire comes out, small rectangular hole, not on the side but bottom face of the wing. another way to say it is the bolt holding the wheel to the strut, straight out from that. now with gear down its a mm back from that position, with gear up its on the front edge of that spot, maybe .5mm from it.
hope this helps. ill post pics tomorrow.
Old Jan 18, 2012, 09:38 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Yes, if you look at the link/attachment above the 155m is at the front edge of that rectangular slot you are talking about. Now my cg of 150mm is 5mm forward of that. I cg with gear up.
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
