Old Jan 18, 2012, 08:10 AM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Originally Posted by Maxthrottle View Post
V8 do you have a watt meter to actually tell us the numbers that are actually passing through yours? Though you have changed some wiring and connectors.
I have this 1
http://www.hobbyking.com/hobbyking/s...dProduct=10080
v8truckin is online now Find More Posts by v8truckin
Old Jan 18, 2012, 09:12 AM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Yes ... Yes V8.... That is what a watt meter looks like Not shopping for any as I have several.
I was more on the, "have you put your investment to use and read the numbers that are passing through this setup". If you did could you share? With the larger battery I would have used it to figure out. Your amp/hrs to confirm reasonable flight time.
When anyone gets theirs and does a test run up could they post what numbers they are getting from their setup.
Sustained (peak isn't useful):
Motor/Fan
Connectors and wire used
Battery (brand, mAh, C, Weight),
Volts, Amps, Watts
Maxthrottle is offline Find More Posts by Maxthrottle
Old Jan 18, 2012, 10:10 AM
mray is offline
Find More Posts by mray
USA, AZ, Buckeye
Joined Feb 2010
I have an eagletree and will do some testing over the next few days....it will be with the purple can motors of course.
mray is offline Find More Posts by mray
Old Jan 18, 2012, 10:50 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Motor/Fan
Volts, Amps, Watts
Just making sure you knew what 1 looked like, since I posted those #'s earlier in the thread, with you guessed it a WATT Meter. Lol! Did not post sustained, posted peak.
2849 2200kv
4000mah gens ace 25c 6s
10awg (battery to esc)
13awg (esc to motor)
93a
2200w
21.34v
Will test the 5000mah flightmax 50c when I get home.
Old Jan 18, 2012, 01:12 PM
Wargassm is offline
Find More Posts by Wargassm
Wargassm's Avatar
United States, CA, Lake Forest
Joined Nov 2010
Originally Posted by v8truckin View Post
I think he does n i was just gonna ask him the same to confirm his motors.
WARGASSM
black not sure ill look tonight.
Wargassm is offline Find More Posts by Wargassm
Old Jan 18, 2012, 01:13 PM
Wargassm is offline
Wargassm's Avatar
Joined Nov 2010
Originally Posted by mray View Post
Thanks V8....sorry to make you summarize but the reason I asked is because I purchased an SU-35 from BH at the AMA show. I specifically looked to make sure the one I purchase was a "3D" version and not the standard version. It appears the difference is the standard is a 4S vs the 3D being the 6S. Is it possible those who thought they purchased the 6s actually got the standard 4S model?
I will try and pull the plane in my kit and take pics of the motor and ESC's. Box label shows this unit coming with a 2200kv motor.
no issues this IS the PNP 2200KV motors, not 4S setup.
Old Jan 18, 2012, 01:48 PM
SU-4ever is offline
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Can anyone tell the weight of stock 55A ESC's ?
It actually is very important and no one has given this information yet.
Thanks in advance!
SU-4ever is offline Find More Posts by SU-4ever
Old Jan 18, 2012, 02:04 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
I'll weight em when I get home, if someone hasn't done it by then.
Old Jan 18, 2012, 02:55 PM
Wargassm is offline
Wargassm's Avatar
Joined Nov 2010
Originally Posted by Mmarshall View Post
Well fired mine up tonight... all worked for a few mins then one of the elevator servos died...Guess I will replace both just in case.
Bummer....
Working with a 7 channel receiver and trying to figure out how best to hook it all up.
I am thinking of Y cabling the Rudder with the side to side TV and running the the up/down TV on Aux1 and Aux2 which would give me roll TV.
If I do not go this route I could just Y cable the up/down TV that put side to side on Aux1 and Up/Down Y cable on Aux2.
I am not looking to be able to disable TV I want it on all the time.
OR I could just go but an 8 channel receiver.
How do you guys have them hooked up?
TV Y-harness into Rudder / nose wheel steering.
Elevator on position #2sw, elevator and alieron on pos #3. So i can turn it off, elevator only or go full aileron and elevator.
Old Jan 18, 2012, 03:12 PM
Wargassm is offline
Wargassm's Avatar
Joined Nov 2010
So we are adding more battery than needed to balance. Especially if Wars Rhino 4900mAh 6S is 730g pushed way back? War, what your battery weight?
This helps. The CG has a 10mm range and its near neutral. The further out, say forward 250mm forward in the battery tray, the more the weight has an effect to counter balance. Moving it 1/2" or 13mm could mean you could use lighter batteries or stay with these batteries and not worry about heavier motors; to some degree.
My Rhino is 792 grams. 6s 4900ma. The Genace i will fly it on next weight 752grams.
Old Jan 18, 2012, 03:14 PM
Wargassm is offline
Wargassm's Avatar
Joined Nov 2010
Seems his Rhino 4900mah is longer than the 5000mah Flightmax im using
ill measure it out tonight and upload pics.
Old Jan 18, 2012, 04:11 PM
High Orbit.....
Joined Jun 2009
Thanks in advance!
Shouldn't matter much since one end sits at CG. I'm guessing 70-81g.
If you descide to position them aft of the wing bar in the center channel the mean location is 100mm aft of CG-155mm so going to a 80amp ~120g ESC X 2 will go to her AUWaist line.
Old Jan 18, 2012, 04:27 PM
High Orbit.....
Joined Jun 2009
Wow they're not as light as advertised (HK says 730g) but the extra 60g can help but adds less force than V8, especially if you mounted it, "way back in the tray".
The length of the battery just prevents it from moving it further forward if you had to, but you moved it back.
What's more important is where you positioned the center of the battery in the tray; distance from CG.
Are you on purple power or gold there may be a weight difference between the Fan/Motor combo's. I could see purple power being lighter needing less battery up front or same battery moved back.
V8 has a RX battery and he never said where he mounted it or how much it weighed. That could be a reason for the differences.
I just mounted the BEC/RX batt and Satellite in the nose gear bacy all nice and snug and it really counter balances. So I may be putting mine way back in the tray also.
Old Jan 18, 2012, 04:38 PM
Wargassm is offline
Wargassm's Avatar
Joined Nov 2010
V8, are you using the same battery manufacture to fly with?
I'm going to resolder some connectors to work with 3s deans bats. i hope it will work ( pics tomorrow )
Has anyone picked up one of the Genesis batteries from Banana hobby? tested them in this plane? or in another plane?
if it doesn't rain this weekend and i get my replacement wheel, ill fly it on a Rhino ( 25c ), the genace ( 30C ) then Genesis ( 55C ) and Thunderpower ( 45C and 65C ) to compare.
Odd, BH is saying use a 25C bat, what C raiting are you using?
Old Jan 18, 2012, 05:34 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
No I'm using 5000mah 50c flightmax
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
