Old Jan 17, 2012, 08:13 PM
Mmarshall is offline
Find More Posts by Mmarshall
Hey... watch this...
Mmarshall's Avatar
Herndon, Virginia, United States
Joined Feb 2003
Well fired mine up tonight... all worked for a few mins then one of the elevator servos died...Guess I will replace both just in case.
Bummer....
Working with a 7 channel receiver and trying to figure out how best to hook it all up.
I am thinking of Y cabling the Rudder with the side to side TV and running the the up/down TV on Aux1 and Aux2 which would give me roll TV.
If I do not go this route I could just Y cable the up/down TV that put side to side on Aux1 and Up/Down Y cable on Aux2.
I am not looking to be able to disable TV I want it on all the time.
OR I could just go but an 8 channel receiver.
How do you guys have them hooked up?
Mmarshall is offline Find More Posts by Mmarshall
Old Jan 17, 2012, 08:20 PM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
I'm running mine off of 6 Ch. I'm using a 7ch receiver but that only because I prefer satellite & run seperate bec off of a spare ch. I y'd rudder & tv yaw. Y'd tv pitch. I can turn it off and on but i just leave it on.
v8truckin is online now Find More Posts by v8truckin
Old Jan 17, 2012, 08:57 PM
merlinfan is offline
Find More Posts by merlinfan
Throttle Bender
merlinfan's Avatar
Joined Jun 2008
The elevator servos are scaring me, I wanted to get by with a 7 channel rx but now going to use my 9. I had really hoped that would be the first foamy EDF that was trouble free out of the box. (Not counting something simple with only 2 or 3 servos.)
merlinfan is offline Find More Posts by merlinfan
Old Jan 17, 2012, 09:08 PM
Mmarshall's Avatar
Joined Feb 2003
Well pulled the servo apart, wire to motor was broke off probably when it was assembled...solder was OK must of caught during assembly and was hanging on by threads (literally) so it worked for a few seconds.
5 Min fix with some new solder... Elevator servos actually do not look to bad in quality... close to an HS65MG.
V8 how is the roll rate?
I was thinking differential TV for elevator to help in high alpha... that would mean just Y the rudder to the TV.
Next up pull the fans and balance.
Also V8 my motors are the same as Mray... looks like you are the odd man out..
Old Jan 17, 2012, 09:22 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Actually I have the motors I got from co workers PNP from rc castle & the motors I got in PNP from rc castle I order by accident instead of the kit. They are both the same 2849 2300kv in the pic. So we're even. Plus BH still list 2200kv n rc lists 2300kv. Now that i recieves a secind pair of motors confirming the 2849 2300kv, it leaves me wondering what they shipped you guys. I have run motors in other planes with 50kv difference & it makes a difference from the lower kv to higher kv motor...
Roll rate is ahhh w/o rudder. I use rudder when u roll and its fine.
Old Jan 17, 2012, 09:50 PM
mray is offline
Find More Posts by mray
USA, AZ, Buckeye
Joined Feb 2010
I still have not heard from freewing...I emailed them yesterday regarding this motor issue. I will call Banana Hobby tomorrow. If need be I will go drive over to their place of business.
mray is offline Find More Posts by mray
Old Jan 17, 2012, 10:02 PM
genghiskt is offline
Find More Posts by genghiskt
genghiskt's Avatar
Joined Sep 2011
re
Originally Posted by v8truckin View Post
Well the post a page or few back contradicts what you say, freewing has upgraded to 2849 2300kv. That's the 1st I've heard of 2849 2200kv. The box shows 2839 2200kv.
http://static.rcgroups.net/forums/at...1photo%202.jpg
Well here are the pictures;
This what I got from Freewing.
genghiskt is offline Find More Posts by genghiskt
Old Jan 17, 2012, 10:05 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Okay, thanks! Now what the heck is going on...
Old Jan 17, 2012, 10:18 PM
genghiskt's Avatar
Joined Sep 2011
Re
From what I was told, the purple one are the old version and they are used in the first batch of production.
They upgraded the motor from second batch of production. I got SU-35 just before New Year from the factory.
First batch was out on the 12/12/2011.
Old Jan 17, 2012, 10:21 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Did you purchase that directly from freewing?
Old Jan 17, 2012, 10:23 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
okay now that is the same motor I have including measurements. Wonder why rc castle says it's a 2300kv motor & your box says 2200kv.
Old Jan 17, 2012, 10:25 PM
mray is offline
USA, AZ, Buckeye
Joined Feb 2010
Well how the heck do we get the old motors upgraded?
genghiskt's Avatar
Joined Sep 2011
For that, I'm not sure.
I just killed my ESC and retract! Dam it !! I was plug in the 6s, and the spark just killed those stuff !!
Old Jan 17, 2012, 10:43 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Might as well buy some 60-80a escs now. You probably gonna need em anyhow. As for the retracts...sorry that suxs!
Old Jan 18, 2012, 12:23 AM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
V8 do you have a watt meter to actually tell us the numbers that are actually passing through yours? Though you have changed some wiring and connectors.
Maxthrottle is offline Find More Posts by Maxthrottle
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
