Old Jan 14, 2012, 12:05 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
I'm flying solo! Maybe Monday.
v8truckin is offline Find More Posts by v8truckin
Old Jan 14, 2012, 12:20 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
CG:
From underneath the aft end of the wedge that separated the ESCs is 145mm aft of the wing root on the fuse.
or
You can also use as a reference the LE of the box hole opening, for 155mm, that feeds the Aileron wire from the wing. The line of that box hole opening also is in line with the wheel well of the mains for 155mm.
If you go to the beginning of the thread I posted the pic of the actual model, confirmed MAC and 35% AC to come to the same 145mm-155mm that factory arrived at. There can be other dynamics at play as you move to more unstable where the Strake and Stabs start adding lift properties which is why I further calculated NP and dynamic AC to come to Stable to Unstable being at 167mm. Beyond 167mm my guess is most would need gyros on high gain.
If you go to the thread tools at the top of this thread select show all attachments to see every picture everyone has posted. The first picture shows the CG calculated.
It worked for V8's flights and that even looked a bit nose heavy though its hard to read his entire setup. So sound about right.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Jan 14, 2012, 12:45 PM
Pepperpete is offline
Find More Posts by Pepperpete
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
OMG...I didn't know about being able to show all of the attachments in a thread. That is insane! You just made my life about a hundred times easier when I'm looking for specific pictures!!!
Originally Posted by Maxthrottle View Post
CG:
Already posted an easier way to locate CG is on the bottom. The two aft screws of the ESC vent that are also at the seam of the forward portion and cheat hole portion of the duct is the 150mm recommended CG point.
They gave 155mm for fliers who are looking for a little more 3D. But they are fairly conservative so one can go back further if they know how to set other surfaces including stab AoA. But as discussed what makes all the difference controlling slightly aft CG is finner surface control thru linkage setup and Expo.
Pepperpete is offline Find More Posts by Pepperpete
Old Jan 14, 2012, 12:52 PM
High Orbit.....
Joined Jun 2009
V8! Go balistic! Still curious if your static thrust differs much from dynamic.
Also have you checked if the thrust line is fine?
In the vertical full power and in a dive no power, no stick input for either does it pull to the belly or canopy? That's if you happen to notice while you're up there.
Ya the spring in the back of the track just drill a hole a little smaller than your spring, all silone adhesive and squeeze it in there. But I was looking to do that covered and add a shock bar trailing arm to replace the solid plastic bar they supply.
Have good flight.
Old Jan 14, 2012, 01:38 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
She goes verticle for about 150ft before wanting to stall. She's faster than a euro on a straight run. No roll rise or drop on vertical and dives, she slices through the air like hot knife in butter.
Old Jan 14, 2012, 02:04 PM
High Orbit.....
Joined Jun 2009
FYI on new motor
To: ***************
Subject: FREEWING SU-35 MOTOR INFORMATION
Date: Thu, 12 Jan 2012 17:26:04 +0800
DEAR MR ***********,
AFTER CHECKING WITH FREEWING , THEY INFORM THAT
THE NEWEST UPGRADE MOTOR FOR SU-35 IS 2849 2300KV
( BEFORE IS 2839 2200KV ) AND THE MOTOR DETAIL INFORMATION
IS AFS:
- Outside Diameter : 28mm
- Total Length : 49mm
- MOTOR SHAFT DIA : 4.0mm
- No. Of Stator Arms : 12
- No. Of Magnet Poles : 8
- Weight : 110g
- Kv : 2300 rpm / V
- Working Voltage : 14.8v - 22.2v
WITH FREEWING 70MM DUCTED FAN , THE STATIC THRUST IS
AROUND 1700 - 1800g AND DRAWING CURRENT IS AROUND
45A ( ACCORDING TO YOUR 6S 22.2V BATTERY POWER ). ATTACHED
IS THE PHOTO OF THE MOTOR. HOPE ABOVE INFORMATION
CAN HELP YOU.
************ to protect all parties.
HAVE A NICE DAY !
Old Jan 14, 2012, 02:19 PM
DamonH is online now
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Max,
Did they say when the new motor's will be fielded or are they already?
DamonH is online now Find More Posts by DamonH
Old Jan 14, 2012, 02:24 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Sweet! So the motors I have are 2300kv and look exactly like that.
Old Jan 14, 2012, 02:25 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Those are the motors rc castle is shipping, Damon. Someone said their PNP motors look different, guess where they order their plane from...?
Old Jan 14, 2012, 02:28 PM
DamonH's Avatar
Joined Oct 2011
Lol...I guess that answers my question. It will be interesting to see if BH PNP version has the upgraded motors. I guess I'll find out Wednesday when mine gets here .
Old Jan 14, 2012, 02:29 PM
DamonH's Avatar
Joined Oct 2011
those are the motors rc castle is shipping, damon. Someone said their pnp motors look different, guess where they order their plane from...?
lol....dang it! It's like you knew what I was going to say next.
Old Jan 14, 2012, 02:31 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
When I took my measurement earlier the can was 39mm & total length was 49mm. So now it make sense.
Old Jan 14, 2012, 02:35 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
delete
Last edited by v8truckin; Jan 14, 2012 at 04:40 PM. Reason: re-uploaded to youtube.
Old Jan 14, 2012, 02:40 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Sorry Damon, but that's another reason why I went the route I did for my plane. Hope they corrected it, if not I hope you call em out on it!
Old Jan 14, 2012, 02:52 PM
DamonH's Avatar
Joined Oct 2011
I'll know for sure Wednesday. Nice solo video job!
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
