United States, CA, San Diego
Joined Jan 2011
New Spinner from X-Flight Su35
Pilots I just received my spinners from X-flight, I found 2 un-used 4mm shaft adapters in my endless stack of boxes holding RC stuff, I'm gonna test in a few minutes see if the vibration disappears, Here is Link for the Spinners:
http://www.x-flight.com.hk/?p=6&id=182&lang=en |
United States, AZ, Tucson
Joined Mar 2012
6S 4400 mah 65c-130c NanoTech New never used
$85 shipped Priority Mail http://www.rcgroups.com/forums/showthread.php?t=1820360 |
High Orbit.....
Joined Jun 2009
esr ir meter for lipos and Lipoly Objective Performance Database threads. The Battery Comparison Test: X amp Nominal Constand load that you just linked to, is the simplest compare chart. Clearly its not all about the C rating. They both describe a few things that change current thinking on Lipos and what they can deliver. All three of the threads are starting to recognize that no mater what C rating a lipo may have, the resistance (IR), for even the best ones out there do little better than 3 mOhm. From the studies a new formula to measure our batteries emerges; Max Amp draw = Square Root of (6xCapacity/IR) Ref magic formula When used its starting to present a different picture on the type of performance that we can expect from any lipo, and as they go through their life cycle, that we should be measuring them more accurately by checking the building increase in IR that is developed from pushing the battery beyond nominal loading. The marketing cheat from manufacturers is that the C ratings and performance may be some what accurate in the beginning. How they are made can greatly change how they can maintain such with each consecutive use. Many are having issues with lipos in the EDF world, because we are simply running them harder than they are designed to. The harder we run them the shorter the life cycle. But pilots really only know by getting the actual IR of your battery as you use it and applying it in the magic formula above. So my take away is this explains why the marketed C ratings don't seem to match battery performance, and that it is whom ever has the better lipo formula. The Higher C rating for most do better because they reduce the IR to the current limit, but also maintain the Lithium Polymer and electrolyte integrity longer with each charge. Which again matches the complete difference you found with 45C Nano vs 65C Nano's. It implies the formula's are different enough that one drops off in performance more quickly. This all also reflects why some lower C rated may last for a time, but in the EDF application, can and does overstress most lower C rated batteries because their IR is higher while some manufacturers change the ingredient enough to have a shorter life cycle. So we have to start looking to databases of performance range to get a better picture to compare one battery manufacturers recipe over another's and Efliers will need to add a good IR meter to their box of tools. For what its worth.... it makes for an interesting read. |
High Orbit.....
Joined Jun 2009
Let us know which ones you get to see if they ring true on your applications as well. Thanks jcd.... |
High Orbit.....
Joined Jun 2009
It went up to 9* today with heavy winds and rain to wash away the 2' of snow we just got. Temps are already diving for the next 2 days..... So ya.... don't want to hear about it Just cheer me up with some good flight videos
Joined Jan 2011
, I'm running CC 10A BEC so I doubt its current-- my servo tester it all worked fine... I'll re-check it all
Joined Jan 2011
Re Test CS12B with New adapters & spinners
Ok here is the quick test, all seemed good, no vibrations!
High Orbit.....
Joined Jun 2009
If a motor shaft bends on one side and because your throttle control is off one throttle channel, you can't limp back on a single motor. |
| Thread Tools | |
| New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability | neversommer | Foamy EDFs | 593 | Jan 09, 2012 09:02 PM |
| Discussion LX F-35 Vs Freewing F-35 | Mmarshall | Foamy EDFs | 16 | Dec 27, 2011 03:40 PM |
| For Sale Freewing SU-34 stock battery - Brand New | JGuilty13 | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Nov 29, 2011 02:01 PM |
| For Sale Freewing SU-34 stock battery | JGuilty13 | Aircraft - Electric - Jets (FS/W) | 0 | Nov 29, 2011 10:29 AM |
| Wanted SU-34 Freewing | lw777pilot | Aircraft - Electric - Jets (FS/W) | 0 | Apr 30, 2011 03:29 AM |
