Old Jan 26, 2013, 08:17 PM
IntheTubeDeep is online now
Find More Posts by IntheTubeDeep
ITTD you're Clear for Takeoff!
IntheTubeDeep's Avatar
United States, CA, San Diego
Joined Jan 2011
EDF Retest with Trouble Maker on the Leaf Blower
Hey Pilots, I just retested the Su on same 4s set up, this time with the TM cooling the ESCs with a gas Leaf Blower! Roughly 2 minutes at 80% THR NO Funny Business-- it seemed to function normally, vid will be up in 25 minutes, will try one more additional test tomorrow
IntheTubeDeep is online now Find More Posts by IntheTubeDeep
Old Jan 26, 2013, 08:22 PM
davemilw07 is offline
Find More Posts by davemilw07
Joined Jul 2007
Originally Posted by PeterVRC View Post
I haven't read anything about OpenLRS (of use), but as far as I see the 9XR is the same processor/design etc as the 9X anyway.
ER9X has some DSM2/X stuff for it.... it is just the data stream format.
OpenLRS I don't know... possibly the same chance it can be done, unless the speeds are too high to process?
But the main thing is keeping an eye on those communities (OpenBlahBlah etc....) to see what it does of use, and which TXes they implement it on. But so far it seems 9X, 9XR, pretty well the same thing.
I would get a Sky9X board for a 9X (or 9XR if they can work in both) - plus keep an eye on stuff they are doing.
I was on the verge of buying that Sky9X board, but now need to sit and watch just a bit more to see what is going on overall. The modded 9Xes are all doing everything I need anyway... EXCEPT model memory, seeing most of mine are very complex and EAT memory per model. Changing the processor to a 128 would fix that, but changing that chip would be fun! Though it seems people are doing that ok. Or getting the Sky9X board also solves that (it has far more memory anyway).
I just bought 3 TXes to solve that (prob $60ea once all modded up)... LOL. A bonus is that I have spares to use then and there (not that I ever have needed one)..... and can let other people fly my planes with me sometimes too! (not the same plane of course LOL)
Agreed, the 9XR and Open LRS is so new that there's not much info available about it right now (Well, at least I don't know much about it!!!). The Open LRS Technology is designed for the FPV guys, and therefore has OOS range, but not likely I'd ever go there (But you never know...........).
I might pull the trigger on it out of curiosity (it's only 50 bucks), just because it would be fun to learn about and utilize someday..... Meanwhile, I'll also pick up a 9X to get things going, as it's already a mature product, and would be a much better option than my Futaba 7C which has limited mixes and programmability. I'll probably need to contact you with questions about updating and modding the Tx, if you don't mind?
Thanks for your input!
Regards, Dave
BTW, I've done surface mount IC soldering before, and it's NOT a trivial procedure..... You need really good soldering equipment, an illuminated desk magnifier, good eyes and a steady hand. But yes, it can be done!
davemilw07 is offline Find More Posts by davemilw07
Old Jan 26, 2013, 08:48 PM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Perfect...hopefully you have it worked out now.
DamonH is offline Find More Posts by DamonH
Old Jan 26, 2013, 08:52 PM
Joined Jan 2011
4s Test #4 CS12B 70mm fans, ARC 28581s, CP110A ESCs
We'll see-- I'll give it one more test tomorrow- I ran it for approx 2 minutes at 75-80%, no funny business occured, this may have been the culprit: the adapter I made to hook up the watts Up meter: current may have bottlenecked as 2 x 4s batts in parallel fed into one XT90
Old Jan 26, 2013, 08:54 PM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
Ahhhhhh....could have been.
Old Jan 26, 2013, 10:40 PM
Joined Jan 2011
Ok here is the vid of TM and the Leaf Blower same 4s Set up, it did NOT do anything strange as before, one more test tomorrow, I think the total run time was about 2 minutes at about 80%
EDF/ARC/ESC Test 4 Trouble Maker on the Leaf Blower (2 min 19 sec)
Old Jan 26, 2013, 11:47 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
That video is so wrong in so many ways. The things we do for this hobby. How do we get videos posted to the front page
Maxthrottle is offline Find More Posts by Maxthrottle
Old Jan 26, 2013, 11:50 PM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
LOL....what a production!
Old Jan 27, 2013, 12:43 AM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
But they still sound terrible.....
Not the problem reason as before, just sound poorly balanced.
I am not sure if it can be just resonance, or the twin interaction (harmonics), but I don't get that sort of sound in my twins.
It would be best to hear/see one run at a time. But it sounds like mainly one fan mainly.
So you are saying it all happened because of the heat of the ESC's?
And the prior connector reason is unchanged and thus working fine enough (at least there, or for now)?
"Bad bad boy! Never use 4S again!!!"
Pray to the Volts.....
PeterVRC is offline Find More Posts by PeterVRC
Old Jan 27, 2013, 02:41 AM
Joined Jan 2011
Are you sure the terrible sound wan't the 2 stroke leaf blower or me screaming at the TM to hold the blower nozzle on the ESCs and not the cat!? Yeah me and my 4s dreams... haha I think the R fans may out of balance I did feel some vibration on the right side, will check that out . As for the problem in vids 1, 2, possible the watts up meter adapter (XT90-6mm bottleneck) combined with the heat and no cooling, and throw in an unbalanced fan to boot. I just bought the 70 twin F22, that is getting 6s
Old Jan 27, 2013, 02:43 AM
Joined Jan 2011
I gotta set up my SONY SR7 on the tripod, its just crazy to do all that and video with one hand!!
Old Jan 27, 2013, 02:47 AM
Joined Jan 2011
You have no idea ha trying to keep the TM focused to cool the ESCs was a killer!!
Old Jan 27, 2013, 11:14 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
The pre build inspection begins!
VID00457 (0 min 29 sec)
VID00458 (0 min 26 sec)
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 27, 2013, 12:16 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Yaaaa buddy TM doing the usually...causing Trouble! That made me laugh my a$$ off.
v8truckin is offline Find More Posts by v8truckin
Old Jan 27, 2013, 01:51 PM
Joined Jan 2011
A shame I didn't have my camcorder recording the whole 'event' it was classic TM!
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
