Australia, SA, Two Wells
Joined Feb 2012
High Orbit.....
Joined Jun 2009
ITTD I not familiar with the Volt reader that you were using. Do you have an actual Watt meter. The other numbers may give a clue. Too you could be reaching the heat cutout but you may need to change the timing to lower.
But why are you surprised. This is what we warned pushing 4S this hard. It gets more finicky and harder to get it to settle. Even if you fix the timing, high amp=heat. Standard in an electrical panel, 100 amps would be specs to 2 AWG. So you get heat with 10. Its commonly used this way but you kind a need a heat gun to tell us if hot is concerning or just a heat generator of waisted mAh. |
High Orbit.....
Joined Jun 2009
There is no harm in even going to a 8mm connector so why do just enough? May as well standardize with a larger connector for a wider range of uses with all you systems. |
Australia, VIC, Melbourne
Joined Nov 2006
I skipped the "90A area connectors", because they are smack dead in the middle of a wide range of your typical uses for 6S/7S. Larger planes running 80A to 120A areas....
So you are better off picking your own 'standard', eg XT150, that can do anything across that whole range (80A - 120A, and more really) So I picked XT150 for all 6S & 7S uses. (Would be for 8S single battery also, but I have none for now) Under that I use HXT4mm for ALL 5S uses - which even in twins that can use towards 100A total I use battery pairs, thus only half the Amps per battery and its lead anyway And then XT60 for ALL 4S & 3S uses. |
United States, CA, San Diego
Joined Jan 2011
Joined Jan 2011
Joined Jan 2013
Does this model share the same thrust vectoring as the su-34. full 36 degrees mixed or just up down, left right?
I used to fly prop. This would be my first edf jet. Is that a good idea? Where can I buy the 3d sport model, hobbyking? A mixed between fly time and performance battery would be a 5000 mah 45c or something lighter? Sorry for the novice questions, thank you Amazing forum btw.. lots of info |
Joined Feb 2012
I think this as a first edf is a bad idea. I'd try something cheaper and easier to fly without vectoring to begin with maybe a t-45 or l-39. 5000mah would be fine for a sport battery not sure about 3d but still should be okay. I run a 4500mah but haven't tried much vectoring yet. I bought the 6s 3d version from hobby king. Good luck. |
United States, AZ, Tucson
Joined Mar 2012
High Orbit.....
Joined Jun 2009
ITTD I/We should add Pete's concern for the bench test heating up is still valid.
If/when I do run mine, I put the ESC and Battery aft of the EDF to maintain some form of cooling. That's why I said put a fan on it. Your setup is expected to run even hotter so.... |
Tube,
That long run up with no cooling on that high power 4s setup probably isn't helping. Then I see your running the XT90 connectors which may contribute to the bottle neck of current trying to pass. I know your adamant about using this setup, but u may continue to see heat as an issue. |
Joined Nov 2006
LOL... what is actually RUNNING in that video?
One motor/fan? Two? It sounds like NO fans.... but also not really like a motor alone. There is no sound of airflow/fan at all really. The volts are being maintained overly well by the looks.... suggesting not a lot of load. so: 1) Is there actually fans and airflow, lol. I would assume YES. (not sure why it can't really be heard) 2) Was the airflow steady, or pulsing like the sound seems to be doing? 3) Are there two motors running.... and are they doing exactly the same, as far as you can tell? 4) How much airflow (thrust) does it feel like.... little... a lot....? And compared to the feel of the RPM. I don't think it is any current supply problem. It would just run slower then. Not sound all weird like that. Dry solder joints (eg to motor) don't sound like that... and would not occur in two motors - very unlikely. I have never heard an ESC (especially if it is a pair) make a motor run like that (if it is them). But maybe you could have really out of whack Timing (thus the same set on both ESCs) and get that? I never have. The voltage holding good value suggests not much load (power draw from the batteries). I could imagine loose rotors ending up sounding like that...... A rotor slipping on the shaft adaptor, not totally loose, but fairly loose. Though I would expect you have checked all that anyway. (or in original assembly). |
running @ 25.00v * current 90 = 2250 wats. Since the beginning ( last Jan ) my su-35 was pulling: 25v * current 100 = 2500w. 90amp connector wont cut it, you need to increase it to a min 120a for safety. Last thing you want is to have a connector come off in flight. |
Joined Jan 2011
1) YES fans were pushing a lot of air, I was holding plane with one hand, it had a lot of thrust! 2) YES steady air flow until that pulsating drop in output 3) Yes 2 motors running seemed equal, and did the same when power dropped 4) YEs it felt like a lot of thrust to me- especially at high THR briefly I'm gonna check the fans this morning, I drilled hole in the shaft adapter so I could tighten the bolt holding the fan so I doubt it was loose fan, check out the vid I post in the next hour, might give more insight into whats going on |
| Thread Tools | |
| New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability | neversommer | Foamy EDFs | 593 | Jan 09, 2012 09:02 PM |
| Discussion LX F-35 Vs Freewing F-35 | Mmarshall | Foamy EDFs | 16 | Dec 27, 2011 03:40 PM |
| For Sale Freewing SU-34 stock battery - Brand New | JGuilty13 | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Nov 29, 2011 02:01 PM |
| For Sale Freewing SU-34 stock battery | JGuilty13 | Aircraft - Electric - Jets (FS/W) | 0 | Nov 29, 2011 10:29 AM |
| Wanted SU-34 Freewing | lw777pilot | Aircraft - Electric - Jets (FS/W) | 0 | Apr 30, 2011 03:29 AM |
