Old Jan 24, 2013, 04:42 PM
Wargassm is offline
Find More Posts by Wargassm
Wargassm's Avatar
United States, CA, Lake Forest
Joined Nov 2010
Originally Posted by SU-4ever View Post
ESC Synchronization.
My stock ESCs died, replaced them by 70A cheap ones one with bec one without but same model and when powered up the fans turned at different RPMs. They even started turning at different stick positions. Then changed the ESC with BEC by the same model without BEC and put a separate BEC and tried again. Same issue. Then tried to fix it programming and no progress. Then somehow one of the ESCs and the external BEC fried on the ground. And now I'm still waiting to put a new order on a couple of neww ESCs and a different external BEC.
Stop buying cheap crap!!!
get castle creations and be done with it....
Wargassm is offline Find More Posts by Wargassm
Old Jan 24, 2013, 04:44 PM
Wargassm is offline
Wargassm's Avatar
Joined Nov 2010
Originally Posted by v8truckin View Post
No way jose I wouldn't use em. Those xt90 rated @ 90a , genuine ec5 are rated @ 120a continuous 160a peak & XT150 @ 250.
XT150 all the way!!!!!! use em on everything over 60amps.
Granted overkill but id rahter be safe than sorry.
I've lost 2 planes due to Deans connector failures, wont happen a third time..
Old Jan 24, 2013, 04:55 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
The SU35 beeps?
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 24, 2013, 05:00 PM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Originally Posted by goldsworthy View Post
The SU35 beeps?
not sure what that means, but if I had to take a guess...
Either your using the wrong cell lipo , your esc throttle isn't calibrated, or you need to adjust your throttle trim tabs till the esc engages then calibrate throttle.
v8truckin is online now Find More Posts by v8truckin
Old Jan 24, 2013, 05:13 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
All brushless motor electric models 'beep'. It is a normal ESC startup sequence.
Even the real Su beeps.....
PeterVRC is offline Find More Posts by PeterVRC
Old Jan 24, 2013, 05:55 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Yes true they all beep, but beeping is an indication of a certain or specific sequence ie. Startup sequence, program mode, receiver & radio not binding, wrong cell# etc. So Gold needs to clarify what he is doing when it beeps.
Old Jan 24, 2013, 05:58 PM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
I dont think he is saying his is beeping. I believe it was a question in response to PeterVRC saying esc's needed to be connected to motors because the motors do the beeping.
DamonH is offline Find More Posts by DamonH
Old Jan 24, 2013, 06:01 PM
PeterVRC is offline
Joined Nov 2006
And his Su is probably not in a 'beepable' state yet either. hehe
(Is AZ a beepable state?)
Old Jan 24, 2013, 06:24 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Gold, don't you normally hear the beep beep beeeee BEEP, when you start your quads. It should be very loud with four of them going off exposed.
You can program some ESC's to start silent but ESC default to a power up state and warnings announcement through the motors pulsed turn, once the ESC and Motor are powered up.
When you are programming the ESC the beeps you hear telling you the programming point as well as confirmation of selections.... the sound is produced from the motor being pulsed.
Some get carried away with this and play entire music pieces with the use of several motors and control board.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Jan 24, 2013, 06:43 PM
IWC is online now
IWC
Find More Posts by IWC
IWC
Joined Feb 2003
In post #6276, what EDF aircraft is taxing in?
IWC is online now Find More Posts by IWC
Old Jan 24, 2013, 06:51 PM
High Orbit.....
Joined Jun 2009
PM mw46mw46 to be sure. Its his field so he would likely know but looks like the HET or FlyFly Mirage.
Old Jan 24, 2013, 07:21 PM
SU-4ever is online now
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
That looks like FlyFLy Mirage
Su,
Just get some hobbywing escs never had a problem sync em
Thanks for the advice! I will consider it!
THATS ALOT OF STUFF TO GO BAD! I wonder how so many things could burn out at the same time?
I keep asking myself the same. I think it might have to do with bad soldering (High temperature damaging ESC / BEC electronics).
No, If I had to buy CC for every aircraft I have I'd as soon quit the hobby, don't have so much money. Though I agree this time I'm suffering the effects of a too much cheap election. I don't tend to have any kind of trouble with cheap stuff.
Will go to hobbywing Dlux or Redbrick next time.
Cheers!
SU-4ever is online now Find More Posts by SU-4ever
Old Jan 24, 2013, 07:41 PM
IntheTubeDeep is online now
Find More Posts by IntheTubeDeep
ITTD you're Clear for Takeoff!
IntheTubeDeep's Avatar
United States, CA, San Diego
Joined Jan 2011
Power Sys fault
Ok pilots, I tested my 4s set up in my Su35 with a Watts Up meter-- I fried the meter--it started smoking, maybe because its 14AWG and entire plane is 10AWG, anyway I tested again w/o, both times at around 1:40 I was at about 70% throttle and a few short burst at 90% the following happens as you'll see in vid- v were above 15 so I'm at a loss, ESCs, ARC motors?
ESCs: Cyclone 110A, Motors: ARC 28-58-1s, EDFs: CS12B 70mm fans, BATTS: CNHL 14.8 4s 50c 100c burst LiPos in parallel
Any ideas guys????
EDF (0 min 55 sec)
IntheTubeDeep is online now Find More Posts by IntheTubeDeep
Old Jan 24, 2013, 08:35 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Sounds to me like either a connector failing, cold solder or you battery is having problemos
Old Jan 24, 2013, 09:08 PM
Whiskey Whiskey is offline
Find More Posts by Whiskey Whiskey
United States, CA, Fairfield
Joined Jul 2004
If that isn't the issue, I suspect your ESC can't handle the amount of RPM that the motor is trying to turn at. If the pulsing sound is not what you were trying to get at, then disregard my message.
On second thought, there could be an ESC timing advance and/or PWM setting issue as well.
Whiskey Whiskey is offline Find More Posts by Whiskey Whiskey
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
