Old Jan 23, 2013, 06:59 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
I am not a spider specialist... but, Funnel Web or Tarantula (no trap door opening, that I can see, so I guess a Tarantula!)??
Could be a bird eating spider I guess...... or the VERY rare, model plane eating spider.....
PeterVRC is offline Find More Posts by PeterVRC
Old Jan 23, 2013, 07:02 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Funnel Web
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 23, 2013, 07:03 PM
PeterVRC is offline
Joined Nov 2006
Hmm... coming out of the ground should probably have been the big clue! LOL
Old Jan 23, 2013, 07:11 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Originally Posted by goldsworthy View Post
Sorry please excuse my ignorance! I guess I was just trying to contribute. I will keep my mouth shut! I will learn more that way. LOL
No ignorance at all. Don't take it to heart bro, your contributions are welcome. If you never said anything you would've thought otherwise.
v8truckin is offline Find More Posts by v8truckin
Old Jan 23, 2013, 09:20 PM
av8ersteve is offline
Find More Posts by av8ersteve
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
I try to just listen.
av8ersteve is offline Find More Posts by av8ersteve
Old Jan 23, 2013, 09:30 PM
mw46mw46 is offline
Find More Posts by mw46mw46
Hi, I am Michael from Taipei
Taiwan, 北市
Joined May 2012
Hi guys,
I recently maiden my Su-35, but failed. I found the thrust of left EDF is higher than the right at full throttle. All components are new except both of the ESC, which are used in different planes before. Could you pls suggest me how to adjust or synchronize them. BTW, I use JR DSX9II transmitter. Many thanks!
2012-0105 Su-35 Maiden Failed (0 min 47 sec)
mw46mw46 is offline Find More Posts by mw46mw46
Old Jan 23, 2013, 09:59 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
see if your esc's support a throttle calibration function and if so perform the function, otherwise you could put the esc's on seperate channels and adjust them seperatly......assuming you dont have a problem with either of the edf units
jcdfrd is offline Find More Posts by jcdfrd
Old Jan 23, 2013, 10:00 PM
PeterVRC is offline
Joined Nov 2006
For one idea, at least Calibrate the ESC's.
1) Set TX Throttle to max
2) Power the plane - ESCs will NOT start the motors, they will go into programming mode.
3) Wait just a little bit (10secs) and then move to zero throttle. The ESC's will leave programming mode.
They will have learnt the throttle ranges, from max possible to min possible, during that.
Most ESCs are in that "auto throttle range" mode as they come. But they can also be in a manual mode where they don't "learn" like that, but just use a set value range - which usually would work ok too, but could be amiss from one ESC to the other.
I don't know if we, or anyone, knows the programming method on Freewings (but I think you said they were other types anyway - so you might have a manual for those)
Old Jan 23, 2013, 11:46 PM
mw46mw46 is offline
Taiwan, 北市
Joined May 2012
JCD & Peter, thanks a lot.
Old Jan 24, 2013, 12:22 AM
IntheTubeDeep is online now
Find More Posts by IntheTubeDeep
ITTD you're Clear for Takeoff!
IntheTubeDeep's Avatar
United States, CA, San Diego
Joined Jan 2011
Originally Posted by mw46mw46 View Post
Hi guys,
http://youtu.be/0N2IJ5SO9bI
Ouchhhh, that sounded to me like a bad ESC, or terribly unbalanced fan blade, my grey camo Su35 had horribly unbalanced blades and spinners, go back in this thread and see my vid ;-)
IntheTubeDeep is online now Find More Posts by IntheTubeDeep
Old Jan 24, 2013, 12:24 AM
Joined Jan 2011
Hi guys,
Forgot to mention from the your first throttle up it sounded distressed, definitely was a MAJOR problem
Old Jan 24, 2013, 03:03 AM
PeterVRC is offline
Joined Nov 2006
Yeah !! I couldn't watch the video earlier.
There was something badly wrong on that first spin up!
Possibly blade contact... but more sounded like an ESC/motor problem. Seemed to be just on one.
Maybe even something loose in one fan/motor.
So you would need to run them one at a time, and SLOW first... build up if things sound ok.... to work out what it really is.
Ideally, taken out and done on the bench test unit. Plus CHECK IT FIRST for clear rotation, feeling right, things tight etc.
That short burst in the video wasn't enough to isolate it.
Old Jan 24, 2013, 07:34 AM
SU-4ever is offline
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Precisely the reason my Su is grounded.
SU-4ever is offline Find More Posts by SU-4ever
Old Jan 24, 2013, 07:41 AM
Joined Mar 2012
Watching that video depressed me! Such a great loss!. I also learned from it to take my time months if necessary to make sure everything is as close to 100% as humanly possible. I will check each and every componet and then check them again before taxi down the runway. Where do you get those motor bench test units?
Old Jan 24, 2013, 07:42 AM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Which one? ESC, Fan or Motor? I forgot what your current setup was.
Maxthrottle is offline Find More Posts by Maxthrottle
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
