Old Jan 21, 2013, 05:47 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
And only one turned? Why wouldn't the other?
(I'll give you a clue - see and avoid doesn't work at M0.8!)
Odysis is offline Find More Posts by Odysis
Old Jan 21, 2013, 05:57 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
ITS MONDAY! time for my SU35 to come out of hiding! its a holiday today so its coming UPS
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 21, 2013, 06:53 AM
SU-4ever is offline
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
I say +1 for Odysis.
You know that 2 aircraft are probably 9km+ high so that apparently agressive turn can actually be very smooth. Probably the pilots get bored and love to make sharper turns just for the thrill of it
SU-4ever is offline Find More Posts by SU-4ever
Old Jan 21, 2013, 07:47 AM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Only one acted because only the plane coming in from the side had visual, and neither knew it was actually occuring before that quite 'close' moment. So he probably finally saw them and went "holy crap!!" and veered away before even getting to talk to flight control again! eg Even if that process was only seconds... to say, maybe 10secs. Meanwhile the other plane was oblivious to anything at all - they would never see him coming at the 7 or 8 o'clock direction.
Thus why only one would ever deviate.
After the diversion, then they call it in.... "W.T.F ATC!!!?"
The ATC were not the ones calling the deviation. Otherwise it would have been seen sooner - because they see it on radar, which means it would be seen long before they were truly close - and then both would be told appropriate actions. (and the trail evidence shows that was not the case, seeing only one acted).
It didn't have to be 100ft away... it could be a lot further of course. Even 1000ft or more. It is still a 'close call' in aircraft terms. Even if they were on slightly different altitudes.... but they wouldn't have been because they would have both been called into the same corridor and altitude, otherwise they wouldn't have even been anywhere near each other at all.
The only other way would be if one (the approaching one most likely) was well out of the area it was even meant to be in.
PeterVRC is online now Find More Posts by PeterVRC
Old Jan 21, 2013, 09:27 AM
Joined Mar 2012
The closer inspection has begun!
VID00446 (4 min 4 sec)
Old Jan 21, 2013, 10:28 AM
FOX ONE! is offline
Find More Posts by FOX ONE!
Houston. .we have a problem.
FOX ONE!'s Avatar
United Kingdom, England
Joined Aug 2008
Some extremely BOLD assumptions being made about the contrails, and catastrophic events that were only narrowly avoided by one of the pilots, after he was visual with the other aircraft and had to take avoiding action! Maybe he was that shaken by the encounter, he died at the controls, as after the avoiding manouver, he never regained his original course?
Airliners on reciprocal tracks at high altitudes can cross over at vertical separations of 1000 feet. It's not a "close call", it's a normal occurrence.
As has already been mentioned, most TCAS systems give a climb or descent command to avoid collision (there are some more modern systems that give turns, but they aren't widely spread amongst operators), and after the avoiding manouver, the aircraft regains it's original flight level or track. This aircraft continued on it's new course, which would imply a course correction due to the following:
Airliners do not fly in straight lines between their departure and arrival points. Airways are not infinitely continuous. They start, end and diverge/converge, usually over a VOR. It's not unusual to see a contrail with a sudden "bend" in it, as the aircraft changes course, either as a planned part of the route, or as a heading change after a request to ATC to shorten the route or "cut a corner".
Looks like a normal day at work to me. I must see 20 or 30 of these type scenarios on each sector.
Besides, those contrails could easily be 5000 feet apart vertically. . . .
Just my humble opinion.
FOX ONE! is offline Find More Posts by FOX ONE!
Old Jan 21, 2013, 11:25 AM
IntheTubeDeep is offline
Find More Posts by IntheTubeDeep
ITTD you're Clear for Takeoff!
IntheTubeDeep's Avatar
United States, CA, San Diego
Joined Jan 2011
Yeah Peter I agree-- very well said!
IntheTubeDeep is offline Find More Posts by IntheTubeDeep
Old Jan 21, 2013, 11:28 AM
Joined Jan 2011
Just be fair here-- this pic was taken at high altitude-- and looking almost right at the plane, if this was seen at ground level I bet that trail would be a much smoother arc-- you just can't see from that perspective
Old Jan 21, 2013, 11:29 AM
Joined Jan 2011
Its about time your 35 'arrived' Gold !!
Old Jan 21, 2013, 11:36 AM
Joined Jan 2011
Could be the sun- it was in the south west and most likely the plane on right was right in the blind spot- just my thought. ATC DO make errors, maybe this was one of those incidents?
Old Jan 21, 2013, 11:38 AM
Joined Mar 2012
SU35 build video question of the day!-
VID00449 (0 min 34 sec)
Old Jan 21, 2013, 11:45 AM
Joined Jan 2011
SU35 build video question of the day!- http://www.youtube.com/watch?v=KAxt5...ature=youtu.be
Gold the ONLY parts glued on the Su35 are the tail cone, the nose cone, and the 2 fins under the vert stabs, the 2 part supplied epoxy will work fine on those parts, the servo covers and the 2 panel covers I recommend using a contact like adhesive so its easy to remove if needed
Old Jan 21, 2013, 11:51 AM
Joined Jan 2011
I have the same CS Evotite from HK-- its good, and this tube of glue(similar to contact) its great on parts mentioned like panel covers and servo covers which may need to be removed
Old Jan 21, 2013, 12:05 PM
Joined Mar 2012
VID00448 (0 min 52 sec)
Old Jan 21, 2013, 12:44 PM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Gold, you would place the glue on the top as that is the light side. You may want to put a line on the cones with a sharpee and spin the shaft and cones with nothing on it to make sure it is true. If the line always stops in the exact same spot there may be a heavy side on shaft/cones. I have that exact balancer and the shaft/cones were out of balance themselves.
DamonH is offline Find More Posts by DamonH
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
