Old Jan 15, 2013, 11:28 AM
DamonH is online now
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Originally Posted by jcdfrd View Post
yes that would work but you have two issues that are easily fixed, first is the batt is too big and heavy and second its a 3s pack or 12vdc so the bec will be a 5amp bec if you were to go to a 2s 800mah lipo or LiFe you would cut the weight down considerably and running at 7.4vdc or less with the LiFe you will have the full capacity of the cc bec at 7amps, less weight and more electrical headroom
Damon
you are correct a 1450 is a bit too big/heavy, go to around 800-1100mah and 2s and at least 10c
Thanks for the info! I've never used a rx batt so I just want to make sure I'm on the right track.
DamonH is online now Find More Posts by DamonH
Old Jan 15, 2013, 12:33 PM
merlinfan is offline
Find More Posts by merlinfan
Throttle Bender
merlinfan's Avatar
Joined Jun 2008
BEC = Battery Elimination Circuitry. It's not a BEC anymore if you are using a separate batt to power it.
merlinfan is offline Find More Posts by merlinfan
Old Jan 15, 2013, 01:14 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
correct, if your not using it to eliminate a batt then its just a voltage regulator. actually in this case using a separate batt its a UCEC (Universal Crash Elimination Circuit) lol!!! no really thats what it is
jcdfrd is offline Find More Posts by jcdfrd
Old Jan 15, 2013, 01:50 PM
SU-4ever is offline
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Originally Posted by Odysis View Post
I do like my 16 channel, sub $200 radio
What, where, when?
How come...?
SU-4ever is offline Find More Posts by SU-4ever
Old Jan 15, 2013, 01:55 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
So, can I use someting like what is in this provided photo to hook up the Castle BEC?
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 15, 2013, 02:11 PM
IntheTubeDeep is offline
Find More Posts by IntheTubeDeep
ITTD you're Clear for Takeoff!
IntheTubeDeep's Avatar
United States, CA, San Diego
Joined Jan 2011
Originally Posted by PeterVRC View Post
Oh yeah! I forgot the Y'ed elevator! DOH.
5) Elevators linked
= 7 channels
I split mine all to individual channels from the start (but I always do that anyway).
Goldsworthy, see if you can find someone to help mod the T9X to flash it to ER9X.
The stock T9X software is pretty well the WORST in the world (really!)... but the ER9X firmware (you reflash the TX to run that) is pretty well the BEST in the world! (Also really!)
So it is well worth doing! However you have to get it done!
Peter I just did the FrSky mod to my 9X, how do I flash your above mentioned best in class firmware to my 9X? I have NO idea how thats done!!
IntheTubeDeep is offline Find More Posts by IntheTubeDeep
Old Jan 15, 2013, 02:24 PM
DamonH's Avatar
Joined Oct 2011
In theory...yes, if you are using deans connectors on your flight battery and esc's than this would work to hook up your bec. I don't know that I would stick with deans though...just my 2 cents.
Old Jan 15, 2013, 02:27 PM
Joined Mar 2012
Do they make a pre made wire and plug such as the one in the photo with the better conectors?
Old Jan 15, 2013, 02:29 PM
DamonH's Avatar
Joined Oct 2011
Not that I have seen...or I would have some...lol. Maybe someone else knows of some...
Old Jan 15, 2013, 02:43 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
not that I know of either, but I did make one for my bec when I soldered my connector and forgot to solder my bec as well into the connector. So I took 1 male & 1 female EC4 (4s setup) with 2" of 12gauge wire between em and solder em with my bec, I could remove my bec if I wanted, but thays not why I did it. Now it hooks up in between my battery and esc. However I prefer to solder the bec directly into my connect, just had a brain fart.
v8truckin is offline Find More Posts by v8truckin
Old Jan 15, 2013, 03:40 PM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
ITTD, you need to make a slight internal TX mod - soldering on about 6 wires (use a common flat cable strip of the 6 wires is easy) to the main PCB, so that you have a connector out of the TX to connect to a USBASP programmer ($5).
Programmer - can use its supplied lead to make the TX internal wiring.
http://www.hobbyking.com/hobbyking/s...occessors.html
This is not my TX internal pic below (but is my 16ch modded TX) - I use the flat ribbon cable piece from the ATmega USB programmer and it goes to a DB9 connector at the top front of the TX. Another piece of that flat ribbon cable, which still then has the 10pin header block on it, has the other DB9 fitted to it so the TX can connect to the programmer.
I also attached a PDF someone made up for how to do it all....
PeterVRC is online now Find More Posts by PeterVRC
Old Jan 15, 2013, 05:00 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Originally Posted by SU-4ever View Post
What, where, when?
How come...?
It's the same setup as Pete's. 9X with two 8ch FrSky transmitters, and ER9X firmware. It sends 8ch per Tx, so 16 in total over two seperate radio links.
Mix that with Pete's left and right avionics bus setup, and you can have completely reduntant RF links. Did I mention telemetry, audio, haptic (vibration)...
It's a bit more DIY than the brand name radios, but it's also just as capable. When the 'big boys' come out with a cool feature, it only takes a week or so to reprogram the firmware to match it.
Odysis is offline Find More Posts by Odysis
Old Jan 15, 2013, 05:05 PM
Joined Mar 2012
HEY! my wife came home in a good mood today! I figured why not give it a try!. I asked her if I could order a foam airplane from China. She said "its made of cheep foam?" I said yes dear its foam. She said ok go ahead and order one!. Looks like the SU35 will soon be out of hiding!
Old Jan 15, 2013, 05:10 PM
DamonH's Avatar
Joined Oct 2011
LOL...cheap foam....Nice!
Old Jan 15, 2013, 05:11 PM
av8ersteve is offline
Find More Posts by av8ersteve
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Do I need a BEC? On my gas heli's, I have the rx battery (1100mah) plugged into an on-off switch. The other end of the switch is plugged into the receiver batt channel. Can I do this and unplug the red wire going into the throttle channel? I also want to run my servo's at least at 6v.
av8ersteve is offline Find More Posts by av8ersteve
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
