Old Jan 11, 2013, 04:55 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Originally Posted by PeterVRC View Post
Also.... see if you have a way to check/calibrate that Lipo "tester" you used.
I have four different ones like that and they are all flakey in their accuracy. Use all four and you have four different sets of numbers!!
The FRsky FLVS-01 is very accurate - at least mine seems to be. So the other four are half useless rubbish really! (all those look similar design to your pic)
So I only use those as a very quick rough check to see if a battery is used/charged or not. Ignoring the exact cell voltage reported.
I didnt think to use it but I got one of those on my un used NAZA (its good to have a rich wife!) . I will take a look at the readings useing that instead.
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 11, 2013, 04:57 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Yeah check that.
Can still also be the charge, and/or breaking in, too.
PeterVRC is offline Find More Posts by PeterVRC
Old Jan 11, 2013, 05:00 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Also check and make sure your charger is also calibrated. I know I had to calibrate one of mine that was over then under charging lipos.
v8truckin is offline Find More Posts by v8truckin
Old Jan 11, 2013, 05:02 PM
PeterVRC is offline
Joined Nov 2006
Hmmm... the airbrake driven by the Ram is also a possibilty....
Seeing I have the open cavity area after the hatch now. Though a messy 'crossover' of fuselage stuff feeding into removable (hatch) stuff. So maybe not so useful....
Or the Ram drive servo MIGHT fit under the rear end of the hatch - there is room there.
A bit of pondering to do....
Old Jan 11, 2013, 07:36 PM
av8ersteve is offline
Find More Posts by av8ersteve
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Anyone use this programmer before? Is there one better suited for around the same price? I need something to reverse one of my elevators. Thanks
http://www.horizonhobby.com/products...ester-HRC44425
av8ersteve is offline Find More Posts by av8ersteve
Old Jan 11, 2013, 08:12 PM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
I have that one and it works great. I'm assuming you have Hitec servos?
DamonH is offline Find More Posts by DamonH
Old Jan 11, 2013, 08:25 PM
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Yes. Thanks DamonH
Old Jan 11, 2013, 08:32 PM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
Yes. Thanks DamonH
Which ones do you have?
Old Jan 11, 2013, 09:06 PM
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Right now just the HS-5085MG's. Planning on more as soon as I find a good fit for the wings. I'm also thinking of using all Hitec in my Elan project so I'm looking for a decent programmer. The only thing holding me back from flying the SU is switching the direction of one elevator. I would rather do that than adding a reverser.
Old Jan 11, 2013, 09:52 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
The only place I've seen that one cheaper is EBay for $6 less. I just did a quick check on Tower, Servocity, Troybuilt, robotshop, Esprit etc. they are all $70.
You may search around to see if anyone still sells the older HFP20 but the HFP-25 is the better investments because is services a wider range of Hitecs newer servos.
You don't have to use digitals on everything. An analogue 65 or equal should do for the wings.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Jan 11, 2013, 10:01 PM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
Just wanted to make sure you had the digitals because I believe they are the only ones you can program for reverse direction with the programmer.
Old Jan 11, 2013, 10:03 PM
High Orbit.....
Joined Jun 2009
Originally Posted by SU-4ever View Post
Hey, my new Sukhoi has arrived at last!
Oh wait, that's not a Su-35...
How come you didn't go for the SBACH instead of the 29? ... Oh wait... SU4Ever if its not an SU you don't fly it
I have an SBACH clone but will switch up to the Seabart 50E once I crash it.
Old Jan 12, 2013, 03:29 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Delete
Old Jan 12, 2013, 03:32 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Always wondered why they called him SU, lol!
Old Jan 12, 2013, 03:33 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
and how would you know it can be calibrated?
I have a couple and they also give different reads on volatge per cell
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
