Old Jan 08, 2013, 06:30 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
You've got a channel dedicated to the TV in yaw right. So that's one that can be sacrificed before the others.
Originally Posted by Whiskey Whiskey View Post
The 9th channel is used for the seperated ailerons to allow flaperons. I suppose I can plug in some V-tail mixers for full time tailerons. But that'd call for 4 V-tail mixers just to prevent the flap input from transfering to the tailerons.
Originally Posted by PeterVRC View Post
A chute ??.... I don't want to have to fold something up every flight! LOL.
Oh no worries there.... you can just run into something again
Maxthrottle is offline Find More Posts by Maxthrottle
Old Jan 08, 2013, 06:37 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
LOL.... lesson learnt on that one, so it won't happen again. Plus that was a take-off, hehe. (could have deployed a chute in the last seconds maybe....)
Slowing in grass for landings is no problem. Luckily the Su landing gear - even stock, but mine is much more robust than that now - doesn't seem to have any issue with grass. And not even a hint of wanting to 'angular roll' off its trike ever.
PeterVRC is offline Find More Posts by PeterVRC
Old Jan 08, 2013, 06:41 PM
High Orbit.....
Joined Jun 2009
Actually if you come in at 3.5kg you'd be 1kg over the original stress limit of these retracts. So I can't wait to see how that turns out for your. Get those brakes out to slow her right down.
Old Jan 08, 2013, 06:42 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Pete,
I was recommending a chute just incase you don't get up you can deploy it before u hit something again, to help slow Natalia down. I guess maybe for landings for the same reason, since she is packing some thighs on her. More of an emergency thing, but if your landing right u won't need it for landings with your LE slats , airbrake and all. Mine is mainly for landing on a shorter runway with a obstruction at the end.
v8truckin is offline Find More Posts by v8truckin
Old Jan 08, 2013, 06:54 PM
SU-4ever is offline
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
You could try this:
Ch1 to delta taileron
Ch2 to delta taileron
Ch3 Throttle
Ch4 to all kinds of rudders (Aero, TV, wheel, etc)
Ch5 to retracts
Ch6 to Flaperon 1
Ch7 to Flaperon 2
Ch8 to delta TV
Ch9 to delta TV
And Deltas don't need to be external, you can mix them from transmitter.
Maybe (Depending on transmitter) you need to use specific channels for flaperons (Like 1 & 6) but still can't get this same setup using program mixes on other channels.
Just a thought, up to you
Cheers!
Jandro.
SU-4ever is offline Find More Posts by SU-4ever
Old Jan 08, 2013, 07:08 PM
Whiskey Whiskey is offline
Find More Posts by Whiskey Whiskey
United States, CA, Fairfield
Joined Jul 2004
All valid points, I'm just pig-headed. I don't want to give up have the rudder and yaw vector on independent channels for my vector on/off switch. I don't use the rudder alonge much in-flight, but like I said, pig-headed.
Lol, if Pete keeps stuffing Natalia, she's gonna run for the fence again!
Whiskey Whiskey is offline Find More Posts by Whiskey Whiskey
Old Jan 08, 2013, 07:14 PM
av8ersteve is offline
Find More Posts by av8ersteve
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Would anyone like to share their preferred CG measurements? I'm really interested to see if anyone has found their ideal spot aft of the manufacturer's limitation.
I have wondered that myself.
av8ersteve is offline Find More Posts by av8ersteve
Old Jan 08, 2013, 07:16 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
155mm is mine
with a 5000mah & 5300mah lipo
Old Jan 08, 2013, 07:21 PM
PeterVRC is offline
Joined Nov 2006
I have five large aircraft using those "Medium" sized retracts. All over 3.0Kg.
They don't really quote specs, but it is something in the area of "Suitable for 2.5Kg" (or 2.7Kg) aircraft.
Like most things, specs are rubbish... only useful as a guide...
So I assess....test... see what happens....
I have not had one failure of any retract, though every one I have is metal trunion converted. They tear out of a plane long before they get any chance to fail!
So I am not worried over them one iota.... they will even do 4Kg fine.
Old Jan 08, 2013, 07:23 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
PeterVRC I hear you folks are cooking over there in OZ!
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 08, 2013, 07:34 PM
PeterVRC is offline
Joined Nov 2006
Not today here..... temperature wise
But some states have heat and fires. (not us)
Old Jan 08, 2013, 07:38 PM
dro56595@bigpo is offline
Find More Posts by dro56595@bigpo
dro56595@bigpo's Avatar
Australia, ACT, Symonston
Joined Aug 2008
Yeah, it's been a little warm here ...
http://www.news.com.au/national/home...-1226549906140
54C = 129F
I've spent some time working in those areas, but not any more!
dro56595@bigpo is offline Find More Posts by dro56595@bigpo
Old Jan 08, 2013, 07:54 PM
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Originally Posted by v8truckin View Post
155mm is mine
Thanks V8.
Old Jan 08, 2013, 09:00 PM
IntheTubeDeep is online now
Find More Posts by IntheTubeDeep
ITTD you're Clear for Takeoff!
IntheTubeDeep's Avatar
United States, CA, San Diego
Joined Jan 2011
155mm is mine
On my Su35 grey camo running 6s, I had 2 x 3s 5000s in series, weight came in at 800g total, I had them all the way forward against the retract bay, CG was at 150mm-- flew great!
IntheTubeDeep is online now Find More Posts by IntheTubeDeep
Old Jan 08, 2013, 09:01 PM
Joined Jan 2011
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 07:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 02:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 10:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 03:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 11:29 AM
