Old Jan 06, 2013, 04:27 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Dubro prop balancer
http://www.toysonics.com/dubro-499-t...-balancer.html
v8truckin is offline Find More Posts by v8truckin
Old Jan 06, 2013, 05:34 PM
IntheTubeDeep is online now
Find More Posts by IntheTubeDeep
ITTD you're Clear for Takeoff!
IntheTubeDeep's Avatar
United States, CA, San Diego
Joined Jan 2011
Su-35 AirBrake Mod pics
Here a re a few pics of the Airbrake mod, the full vid is uploading to YouTube now
IntheTubeDeep is online now Find More Posts by IntheTubeDeep
Old Jan 06, 2013, 05:39 PM
Joined Jan 2011
Airbrake mod pics
More pics
Old Jan 06, 2013, 06:08 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Looks great ITTD but how come you didn't make it wider like V8 suggested?
The panel lines on this SU-35 are different from the other variants, because it doesn't have a center air brake vs those that do (see pics below).
They side ahead of CG but are high enough to not induce pitch up or down too greatly. So you could have made it larger and more effective.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Jan 06, 2013, 07:04 PM
JTAnimal is offline
Find More Posts by JTAnimal
JTAnimal's Avatar
Joined Aug 2012
Still working on my kit. For the elevators, do you guys use a servo reverser? if so what is a good one to buy? I guess i could split them and run them on separate channels.
JTAnimal is offline Find More Posts by JTAnimal
Old Jan 06, 2013, 07:06 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
I guess that plastic model has the true scale airbrake?
When I visualise my Su (not here now) I can't imagine that I could fit the mechanism and servo in there with the battery too!
But maybe it would....
It looks like a fun thing to have.
PeterVRC is offline Find More Posts by PeterVRC
Old Jan 06, 2013, 07:28 PM
acesimmer is offline
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
Any reason why you did not place the aluminum brake rods inside the brake as opposed to the outside then having to patch? Seems to me it could be glassed in the inside then the hinge gap made slightly larger to off set the lower angle for opening. Great idea and implementation. I think that I will add this to mine.
acesimmer is offline Find More Posts by acesimmer
Old Jan 06, 2013, 07:32 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
I was wondering if any one here has navagational strobe lights on their SU35?
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 06, 2013, 07:53 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Gold,
Here ya go
http://www.rcgroups.com/forums/showp...postcount=3184
Old Jan 06, 2013, 08:10 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Ya that's why im working on another airbrake which is a lil wider, but im trying to figure out the trailing arm mech., which is actually the hydrolic arm which deploys the airbrake and supports it on the su27. The setup i have been messing with binds sometimes when it's lowered, but then again it doesn't need to be lowered till i land and could manually dislodge it once it lands, naaaah! Any ideas would be much appreciated.
Old Jan 06, 2013, 08:42 PM
Joined Jan 2011
Thanks--it came out sweet-- I chose to cut mainly for space, its tight as it is, also I thought I might be able to drill the core in without disrupting the surface but I couldn't do it! Anyway its all good, either method would work...
Old Jan 06, 2013, 08:43 PM
JTAnimal is offline
JTAnimal's Avatar
Joined Aug 2012
Hay guys, I'm really stuck on this elevator problem. I have never used a servo reverser but i guess that is my only option? I don't have any chanels i can use, to split the servos. Is this what everyone does with the elevator servos (use a reverser)? there wasn't any reverser on my first RTF model, maybe Freewing used a servo that was already reversed?
Old Jan 06, 2013, 08:44 PM
Joined Jan 2011
Full Air Brake Mod Vid
Here's the full vid in its entirety
Air Brake Mod Freewing Su-35 Full (7 min 51 sec)
Old Jan 06, 2013, 08:48 PM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Yes, when you get a version that already has the servos installed they use a reversed servo.
DamonH is offline Find More Posts by DamonH
Old Jan 06, 2013, 08:49 PM
Joined Jan 2011
Try this link
https://www.hobbyking.com/hobbyking/..._Reverser.html
Also this if you want to have option to control servo speed
https://www.hobbyking.com/hobbyking/...idProduct=8863
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
