Old Jan 04, 2013, 06:53 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Originally Posted by jk671 View Post
OK V8,
You and a few others are gonna place your approval on this landing. Enjoy the video...
http://youtu.be/I3wtecKSEtI
So, did ya ever figure out what caused that brown out?
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 04, 2013, 08:57 AM
jk671 is offline
Find More Posts by jk671
John
jk671's Avatar
United States, NV, Las Vegas
Joined Mar 2011
Originally Posted by dro56595@bigpo View Post
Much smoother on the elevator on that landing. I noticed that during your practice approaches you were getting the feel of the flare. It's a tricky animal! That practice is paying off. Keep it up!
Cheers,
Dan.
ha ha... that wasn't really a practice run... i accidentally forgot to put my retracts down... i clicked the switch when the alarm went off... but then a few seconds later i couldn't remember if i had done it... autoreflex kind of thing... so i clicked the switch again... started making my approach... as she came in i was like.. oh crap and my mind was trying to do two things at once... throttle up and gear down.... but on the way back i kept reminding myself what i needed to do...
jk671 is offline Find More Posts by jk671
Old Jan 04, 2013, 09:01 AM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
usually what causes my brown outs is the direction of my antenna... also.. there are a few places on that field where i get "interfefence" but its all good... it only happens for a split second... my motors will cut off and then spool back up
Old Jan 04, 2013, 09:02 AM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
[QUOTE=PAPE;23706862]
OK V8,
you mentioned on the video you had a brown out. I see you use a 9x radio but what receivers are you using?
i am using the stock 9x 8channel receiver
Old Jan 04, 2013, 09:19 AM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Yes much much better landing. Now just to repeat it and not have any other issue like the brown out happen, that way you can fly calmly. I always make a lower level pass once my retracts have been switched just to make sure they are deployed, sometimes one doesn't cycle correctly or one can bind, so atleast you ain't coming in blind and can get that retract down. That's also why I preach to give yourself ample time for a few go around, ppl often run their batteries down to the last few Mah, but I prefer to give ample go around time x2.
v8truckin is offline Find More Posts by v8truckin
Old Jan 04, 2013, 09:55 AM
Joined Mar 2012
I can not wait to get my hands on this jet! I still am compiling the extra stuff I will need to buy so I can order all at once. How many use the Eagle tree stability device? Is it good to use with this jet?
Old Jan 04, 2013, 10:59 AM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
... your approval on this landing. Enjoy the video...
That's more like how you were always flying it before. Much nicer even under three events, Brown out, roller skates not down and trying really really hard for a smooth landing..... You look like ur back to drive'r like a tiger.... definitely not a plumber.
Try a longer "approach" to "final", that is when perpendicular to the runway, slow it down further out till you can feel that you have both speed and descent dialled in thinking in you mind even on approach that you're about to flare and touch down. You can also judge if you have a decent descent rate on the approach angle.
Hold that in the last turn from approach to final and you'll find your energy, direction etc in better control with out the need to cut the throttle early from being too far down leg and have that sudden drop just before the flare.
No more ripping the Dunlops off now I'll be out of practice over the winter so I'm sure my first few will look worse in the spring.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Jan 04, 2013, 11:19 AM
SU-4ever is offline
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Nice landing Jk!
Though it seems to me from the looks of it in the video you have it trimmed way too much nose heavy, like you have to be always pulling on the elevator to keep her straight.
I'd try seting a more aft CG and retrim, but, up to you, if you feel comfortable just keep it that way
SU-4ever is offline Find More Posts by SU-4ever
Old Jan 04, 2013, 04:13 PM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
More footage for you guys to enjoy!!!
Freewing Su-35 70mm edf jet great flight with awkward landing (7 min 12 sec)
Old Jan 04, 2013, 04:47 PM
High Orbit.....
Joined Jun 2009
Think it was just posted about doing gear passes!
I was going to ask what was up why it took so long for the Nose gear to retract.
That actually may be the reason for your brown out. The gear or the sequencer are failing and may be loading the system stuck in an engaged position. The timing of the nose gear is well pass the amps stall cut out so either something is happened with the gear board or the sequencer is failing.
I'd check it over to see if theres a loose fault or something else. And sequence the gear with the gear facing the ground. It all is easy on it cycling with gravity doing half the work. But your pulling Gs and the gear has to lift itself so there may be some clues there too!
Are you glad you're coming down so much smoother You would have joined the broken nose club had you come down as hard as you were before.
Old Jan 04, 2013, 05:22 PM
Joined Mar 2012
I know this thread is dealer exempt so I wont look for my answer here. Someone please PM me as to the most reliable dealer for this plane. I am looking for both fast shipping and fair price. a little customer service would be nice as well. Thanks for your opinions
Old Jan 04, 2013, 05:23 PM
dro56595@bigpo is offline
Find More Posts by dro56595@bigpo
dro56595@bigpo's Avatar
Australia, ACT, Symonston
Joined Aug 2008
Nice use of the fixed camera for those fast passes. A couple were rather close to the deck! Glad to see you're having fun with it. Hope to get mine out for some fun soon too. I just have a few yard jobs to finish
Why is it that when you've got a few weeks holiday, you are required to landscape the yard? Am really sick of digging and hauling sleepers in this Aussie heat wave we're having!
dro56595@bigpo is offline Find More Posts by dro56595@bigpo
Old Jan 04, 2013, 05:25 PM
Joined Mar 2012
I was also looking at this added BEC I wonder if a small service battery used with this would come in handy. I am thinking of the smaller battery so this could also add a little weight.http://www.hobbyking.com/hobbyking/s...er_System.html
Old Jan 04, 2013, 05:37 PM
Joined Aug 2008
I'm just flying this one stock PnF from Hobby King. All good so far, except for some ESC overheat during hi-power/lo-speed TV action.
On my other twin EDF, I used a 5v UBEC from one (of the two) 6s batteries. Worked fine for years.
Old Jan 04, 2013, 06:14 PM
av8ersteve is offline
Find More Posts by av8ersteve
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Hey guy's, I hate to bother but I just got back from the hobby shop to compare servos and they are all out of digitals. I know I have read in hear some where what works but I can't seem to find it. What Hitec, JR, or Spectrum digital servo will fit for the elevators? I just want to order, and get them on the way. Thanks.
av8ersteve is offline Find More Posts by av8ersteve
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
