Australia, VIC, Melbourne
Joined Nov 2006
4S... all those numbers look scarey.....
The original design had a 4S version (if they ever made them?) but that is only done to allow a low power setup.... and much more sensible to move to 6S for the higher power version, because 4S at those power levels is an 'Amp hungry monster'. Even the 6S setups are causing some battery grief for some people.... I would hate to be a 4S battery in the higher power setup!!! |
High Orbit.....
Joined Jun 2009
Hard to.... less or equal thrust to factory for under 3 min flight time ((4/85)*60)??? times 85% so more like 2.5 min. Those ARCs are also 153g ea. which is a plus but the 100amp ESC's have to be heavier to handle the 85amps along with heavier Batteries.....over all the higher heat, battery weight for marginal thrust and shorter run time??? I just wouldn't go down this road.
Especially since you can get the CS70/10 at 65amps on cheaper 6S motors that put out higher thrust/efflux for 4 minutes. Even the 5mm shaft HET motors used for the 10s are only $70 ea. Since the 10 and the 12 demand is not too dissimilar, I'd go with that or a BL32. Another assumption here too is balancing the 12 fan on the 3.17mm ARC shaft...If not perfect your performance is even less than optimal. I'd hold them for another model and start over for this one. But then we'll have to see cause some one has got to try. |
Tube,
I tried searching for a battery that would give you lighter weight and good flight time under 500g, but isn't gonna happen. Like its been said on 6s you can get away with 30,35,40C batteries (I prefer 35C at least) because the load on the batteries isn't as bad as it will be on 4s, due to the fact that your pulling less amps. On a 4s setup 170a is going to punish a lipo below 40C, so ya I think it's in your best interest to do 60C lipo however the weight they add is a draw back. I have to agree with the others on this and I wouldnt do a 4s setup on this jet, just to many issues to work around. Maybe try a stock 5 blade setup...? |
Joined Nov 2006
The TV looks to be pointing downwards to me....
Check the gaps from the TV nozzle front face, to the fuselage face. Check the verticals and the horizontals that way. Hard to see 100% for sure in the pic, but the lower gap is smaller... but also just the 'whole TV outline' look stilted downwards too. Plus you can compare the TV nozzle horizontal mid lines to the tail piece horizontal joint line. The elevator looks to be the same amount downwards too.... reference as the tail piece horizontal join again - and even the table top, which the default AoA Stance of he Su is a negative AoA, thus the elevator would be a bit UPWARDS of parallel to the table, not downwards like the pic. The elevator is only a fraction down, and you would also over-ride that by your control. The TV... unless you have the 'on' all the time, will give down-thrust 'all the time', so you want that one correct right away. |
Joined Nov 2006
Oh yeah... that will be why it is down... because the way the Su has that Negative AoA stance, and you aligned it the ground - which is not the same as the horizontal centreline down the plane - so the plane itself is not a useful reference for 'level to the ground'.
Take all references to the PLANE itself. |
Got it, thanks. One more for ya. How much DR and Expo do you guys fly with on high and low rates? I'm using second hole on elevator servo arm, (from output shaft on servo), and last hole on elevator. Aileron is as the pictured in the manual. I don't mean to bug to much but I'm trying to get set up for maiden on Friday. Thanks once again guys.
I don't want it to twitchy.Max, I have my elevator set up as you described in post #9, green line. Thanks. |
| Thread Tools | |
| New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability | neversommer | Foamy EDFs | 593 | Jan 09, 2012 09:02 PM |
| Discussion LX F-35 Vs Freewing F-35 | Mmarshall | Foamy EDFs | 16 | Dec 27, 2011 03:40 PM |
| For Sale Freewing SU-34 stock battery - Brand New | JGuilty13 | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Nov 29, 2011 02:01 PM |
| For Sale Freewing SU-34 stock battery | JGuilty13 | Aircraft - Electric - Jets (FS/W) | 0 | Nov 29, 2011 10:29 AM |
| Wanted SU-34 Freewing | lw777pilot | Aircraft - Electric - Jets (FS/W) | 0 | Apr 30, 2011 03:29 AM |
