Old Oct 28, 2012, 02:45 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
is he wearing a halp mask??
Odysis is offline Find More Posts by Odysis
Old Oct 28, 2012, 03:30 AM
dro56595@bigpo is offline
Find More Posts by dro56595@bigpo
dro56595@bigpo's Avatar
Australia, ACT, Symonston
Joined Aug 2008
Not sure. The hose on this one is central. Don't the HALP masks mount on one side?
dro56595@bigpo is offline Find More Posts by dro56595@bigpo
Old Oct 28, 2012, 03:37 AM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Not quite an Su-35..... but I will set up the Benedini in the Su-35....
I will probably have to use a pair of 2" speakers, instead of a single, or pair, of 4".
But I am not sure WHERE yet! Maybe in the underbelly wiring channel area.
The sound set needs a new one made up. For a start, there is not enough 'roar' in the 'flight mode' section sound file. Ideally you would go and personally record the required sound of a turbine - or real jet - from startup to, taxiing, through takeoff, and then shutdown. A bit hard to get done! Could go and record a real Su..... LOL
Me 262 Benedini Turbine soundset (1 min 29 sec)
PeterVRC is online now Find More Posts by PeterVRC
Old Oct 28, 2012, 03:46 AM
Odysis is offline
Joined May 2007
Yup, RHS. Should have looked closer! Quite embarrassing that...
Old Oct 28, 2012, 03:59 AM
Joined Aug 2008
Crikey, I'm no expert. So long as it's recognisable as a jet pilot rooster by most people, I'm happy
A mate of mine saw a pic of mu Su, and for a brief moment, thought it was a real one - until he saw the zip ties holding the 'great white hope' Alamo onto the wing. And this guy is a recently retired USAF (Colonel) F-16 'Wild Weasel' driver!
(Maybe he wasn't wearing his glasses)
Cheers,
Dan.
Old Oct 28, 2012, 04:14 AM
Joined Aug 2008
Very interested in your progress with that.
Old Oct 28, 2012, 04:27 AM
hklagges is offline
Find More Posts by hklagges
hklagges's Avatar
Munich
Joined Dec 2008
Re: Upgrade Package
Originally Posted by Davidhalljet View Post
Accept pre-order.
FYI I emailed David and he wrote that he only sells to hobby shops, not to individuals (why then the sentence about "pre-ordering"?).
Apparently, the package will be available via a U.S. hobby shop eventually.
Cheers,
Henrik
hklagges is offline Find More Posts by hklagges
Old Oct 28, 2012, 07:32 AM
urrl is online now
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
http://www.youtube.com/watch?v=xVtrJ4fk6do
Sounds great. How much was it?
urrl is online now Find More Posts by urrl
Old Oct 28, 2012, 08:53 AM
Joined Nov 2006
Look here:
http://www.benedini.de/Home_E/Produc...roducts_e.html
Typically you would want:
- The TBS mini - that is the sound module
- The USB programming cable - not essential, but is if you want to make full use of all the TBS can do.
- The 2x40W Amp - but you can use any Amp from an electronics store or online
- Speakers - Prob 1x R10S 4" - basically any speaker suited to the Amps power - 1x4" is loud. 2x 2" (BF45) is still ok but not as loud.
I would get an Amp online. 1x 40W sort of thing would be fine. 30W.... 25W....
Speakers are tricky to buy as whether you see them or not, you don't really know how suited they will be until you try them, so you might end up with some that are useless for anything. It is safer to buy those above listed ones - costly, but at least you know they will work with it well.
It is not hard to set it up so you can shift the module/s from plane to plane. But if they need different sound sets you will need to reflash the required ones (minutes), via a PC - notebook at the field if you need to do that then.
I spent A$400 total, with 3x 4" R10S, 2X 2" BF45 (or was it 4 of them?), 1x 2x40W amp, 1x USB programming cable, 1x TBSmini (dont get a micro!).
I have 4 planes to use it in so far.
A cheaper option is the MrRCsound, which I have one for some other planes ($150 total), BUT it cannot do what the Benedini can so I am pretty sure it will never be able to do all the sounds required for a proper sounding turbine set. You need numerous sounds, and a few BIG ones (startup and shutdown), so it needs a lot of on-board memory to have decent samples.
But maybe Andrew (MrRCsound) knows more detail on how well any of his versions can do turbine....
Old Oct 28, 2012, 02:16 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
Su-35 upgrade package is available at Flashing that you had never seen!
Special design for Freewing Su-35, Very easy to install, modification no need!
Accept pre-order. Available at mid Nov
davidhalljetpilot@yahoo.com.cn
917-4366-780(David)
Include:
2pc Flashing alloy 70mm 12 blade EDF set
Power by TP Motor (include)
Trust up to 2.5kg/pc, total up to 5kg
Trust/Weight ratio over 1.6! amazing!!!
3pc Alloy electronic retract system
8 seconds operation
Much more durable
1 set main wheel with electronic break
Including 2 main wheels and a control board
optional addition:
2pc hobbywing 100A ESC
What happened to the pictures and video? Looked good and sounded good.
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Oct 28, 2012, 09:36 PM
Sessholvlaru is offline
Find More Posts by Sessholvlaru
United States, NJ, Caldwell
Joined Apr 2007
BH bumped up the ARF price from 275 to 320. Shame, I was going to order one.
Sessholvlaru is offline Find More Posts by Sessholvlaru
Old Oct 28, 2012, 10:00 PM
fredmdbud is offline
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Just wait for the Black Friday sales
fredmdbud is offline Find More Posts by fredmdbud
Old Oct 29, 2012, 02:34 AM
urrl is online now
urrl's Avatar
Joined Aug 2010
Looks like Mr. RCSOUND is working on a jet sound system.
http://www.youtube.com/watch?feature...&v=c7QsXyG25uQ
HobbyKing still has theirs available for $274
http://www.hobbyking.com/hobbyking/s...80mm_PNF_.html
Old Oct 29, 2012, 10:01 AM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Originally Posted by v8truckin View Post
Max,
Lol, Ya me to! After watching that via I noticed the same thing. Looks like it's up in about 25-30 yds.
she's actually RoG between 35-40yrds (measured yesterday). She could easily get off sooner as my previous 25-30yrds statement, but it would be from me inducing more elevator on takeoff. 35-45yrds is perfect.
v8truckin is offline Find More Posts by v8truckin
Old Oct 29, 2012, 11:39 AM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
That's probably closer to my avg roll out but to the originl convo where, I don't even remember who, wasn't able to take off at all even with a length grass field.
All the talk about ROG TV or no TV, I've held my model by the mains and had the wife pitch either way at full throttle to see how much they can contribute to the pitch moment. They do have lot of authority which is likely whysome say don't take off with TV active.
But if they are and you still can't get the nose up I start thinking something more may be holdingit down.
There are a lot more 30E size models at the club this year, cause we may be losing our field, so they made extra effort at rolling and gulf greens quality runway. Will have to see how its in the spring.
Maxthrottle is offline Find More Posts by Maxthrottle
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
