Espritmodel.com Heli Air
Old Oct 22, 2012, 10:23 PM
United States, CA, Woodland
Joined Dec 2008
Thank you v8truckin. Now to get my ears tuned to that sound.
P.S. I like your brake and drone chute
R. Mike Neely is offline Find More Posts by R. Mike Neely
Old Oct 23, 2012, 12:23 AM
United States, AR, Jacksonville
Joined Jul 2004
Acesimmer
Were your batteries that cold too? I've had some lipos perform poorly when they were cold soaked. Maybe it got warmed up during the recharge?
Whiskey Whiskey is offline Find More Posts by Whiskey Whiskey
Old Oct 23, 2012, 08:01 AM
acesimmer's Avatar
Joined Oct 2011
Yeah.... probably cold bats but after landing they where the normal warm to touch so I expected the latter half of the flight to have normal performance that did not happen. I'm thinking denser colder air not being pulled through the fans. I also have FOD screens on mine so the denser air could make a difference with those attached. Maybe Max can throw some light on this?
acesimmer is online now Find More Posts by acesimmer
Old Oct 25, 2012, 04:41 PM
Australia, VIC, Melbourne
Joined Nov 2006
Yeeha!!!!
Real Sound Turbine Sound - Replica Car and Rc Airplane Sound System (1 min 40 sec)
PeterVRC is offline Find More Posts by PeterVRC
Old Oct 25, 2012, 04:56 PM
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Freaking awesome!!!
v8truckin is online now Find More Posts by v8truckin
Old Oct 25, 2012, 05:07 PM
Joined Nov 2006
It would be a struggle to fit one into the Su-35, as the speakers required for good sound are 4".
Or even 2x 2" would be difficult. Plus the Amp, which is about the same area as that module almost.
Though..... probably could fits bits here or there, somewhere....
I am putting a Benedini into my Me-262, but will check the Su-35 suitability then too.
Old Oct 25, 2012, 05:15 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
I would drop it into a Euro. I think it could handle the weight better than the SU as its easier to land also since it floats right in. Although the ducts may limit the room to add the speakers.
Old Oct 25, 2012, 07:19 PM
Joined Aug 2012
Can I get some opinions on these RC Lander Fan set.
http://parkrcmodels.com/product_info...oducts_id=1103
I have a SU-35 Kit and I dont want to use the stock setup. also what servos are a good match for this plane? thanks for helping
JTAnimal is offline Find More Posts by JTAnimal
Old Oct 25, 2012, 09:56 PM
Joined Nov 2006
They are a good performing fan - they do what the specs say.
You don't have to have contra-rotating, but it can't hurt.
They sound half way from plain 'leaf blower' fans (eg stock Su-35) to CS10 'more jet-like whoosh' sound.
$80 each at HobbyKing
http://www.hobbyking.com/hobbyking/s..._1280watt.html
BUT... they also have the CS10 based versions = much better sound!! Plus they are more powerful - IF you use good batteries, otherwise still great on lower C.
And even CHEAPER! $72 each.
http://www.hobbyking.com/hobbyking/s...0watt_6s_.html
Shipping at about $30 for the pair, EMS.
PS: I have one 3S and one 6S version of these. (5 blade - but am just now converting the 6S to CS10 rotor for use on 5S)
Old Oct 25, 2012, 11:11 PM
dro56595@bigpo's Avatar
Australia, NSW, Williamtown RAAF
Joined Aug 2008
I've got a couple of missiles left over from a Starmax F-16 that I might mod to look something like AA-10/R-27s. I wonder if magnets would hold them on?
Anyone done that before?
dro56595@bigpo is offline Find More Posts by dro56595@bigpo
Old Oct 25, 2012, 11:16 PM
Joined Nov 2006
Would prob want LOTS of magnets! 4 to 6 each.
Old Oct 25, 2012, 11:40 PM
Joined Aug 2008
That's what I thought. Maybe a little CA would tack them on well enough for a trial, without causing too much damage if I wanted to remove them ...
Old Oct 26, 2012, 01:39 AM
Life begins at transition
Australia, WA, Perth
Joined May 2007
Depends on the mags. I've used some with more than 10kg lift each (large motor rebuilds )
No great harm if one falls off in flight, so don't feel you need to go insane with them. If the missile's produce more than 1kg of drag, you're better off with them falling off!
Odysis is offline Find More Posts by Odysis
Old Oct 26, 2012, 01:45 AM
Joined Nov 2006
I cut off my F-16 ones and left the rails on the wing, with intention to make some form of clips for them. Same for the drop tanks (or whatever they are), by adding mounts for clips/pins.
But I only had initial ideas and never got around to implementing any.
All methods have trade-offs between damage in a crash or knocking etc... or otherwise possibly coming off in flight.
Old Oct 26, 2012, 03:09 AM
Joined Aug 2008
A half hour of foam hacking and a bit of balsa later ... a couple of things that look a little bit like AA-10s
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 16 Dec 27, 2011 03:40 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
Wanted SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 0 Apr 30, 2011 03:29 AM
