Latest blog entry: My Favorite of Favorites
Australia, WA, Perth
Joined May 2007
Cool - that's what I was worried about, but having a 500' tarmac strip, I thought I'd be fine.
Of course, I decided to start the takeoff roll in front of the pilot box. That extra distance could have made things go just a little sweeter! Now I know what 'flying speed' looks like, I'm sure I can get it up a bit smoother. |
High Orbit.....
Joined Jun 2009
Odysis; you mention wanting to move the mains forward. This was posted early.
![]() They are fairly close to scale and CG so unless you have yours nose heavy, you risk getting it too close it falling back on its tail with a little bouce. Convention has the mains 10-15* aft of CG. |
High Orbit.....
Joined Jun 2009
Odysis, not that I'm arguing but what would change the CG for the model from scale? The provided symmetrical foil still maxes around 35% to the full scales 40% and the wing area and sweep are the same. So little change to reposition MAC or CG. The CG doesn't really reach neutral unstable till you pass 165mm-167mm.
Not sure if it being a fighter changes minds that fighters are only tail heavy. Fighters go tail heavy by a load shift after takeoff during engagement. If they were tail heavy static they would flop back on their tails! Even while being loaded with ordnance, they don't fall back on the tail. The flip side is its important not to make it too nose heavy to exacerbate the problem. |
After my first two flights yesterday, I put her on the bench to have a better look at the ESC cooling setup.
What initially looks like a fancy grilled scoop to direct air over the stock ESCs with their cooling fins, I noticed that there was nowhere for that scooped air to flow to (except a couple of small slots where some servo leads come down into the cable run). That scooped air would pretty much stagnate and provide very little cooling mass flow. An easy fix would be to remove the rear portion of the cable run cover to provide some flow through, but that will only work when there's forward airspeed. The fancy TV moves are usually high power but low forward speed. I thought about relocating the ESCs into the intake ducts, but that would have required major surgery and I'm a lazy modeller. So I drilled some new ducts from the main exhaust ducts back into the cable run cavity - the theory being that the efflux will create a venturi effect that will suck air through the cable run and past the ESCs, especially during high power phases. Might be a waste of time. Will report if it makes any difference when I fly next. Cheers, Dan. |
Joined May 2007
The Su35 is fly by wire, therefore I assume statically unstable.
So I'd like to move the mains back a bit, the nose back a fair bit. Keep the 15deg CoG-main wheel contact point relationship, and 10:1 main:nose wheel weight. As for jets re-arranging their CoG inflight - not any I've seen! I know a 747 can do it, but an F111 was the only jet I'm familiar with that had anything even remotely like trim tanks. A hornet for example, the fin tanks are mostly as vents... either way - I'm sure once I figure out my personal CoG preference, and what a decent amount of elevator is, I'll be able to get a much nicer takeoff. |
What's true for the real plane does not necessarily hold for the RC version. Design compromises are made for materials (foam vs metal) and stability.
Shifts in real plane CG usually happen because of fuel consumption. One solution has been to sip fuel from different tanks over time. |
I agree with V8. Max's mod is by far the best method with the least butchering. I fly at high altitude and heat in the high desert and have not had any overheating problems at all. Regards CG... I started with mine set in the middle of factory suggestion. I have moved my 5000 battery pack further back in increments of 1/4" until I'm now about 1 1/12" to the rear and the aircraft flies perfect for the entire flight envelope.
| Thread Tools | |
| New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability | neversommer | Foamy EDFs | 593 | Jan 09, 2012 09:02 PM |
| Discussion LX F-35 Vs Freewing F-35 | Mmarshall | Foamy EDFs | 16 | Dec 27, 2011 03:40 PM |
| For Sale Freewing SU-34 stock battery - Brand New | JGuilty13 | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Nov 29, 2011 02:01 PM |
| For Sale Freewing SU-34 stock battery | JGuilty13 | Aircraft - Electric - Jets (FS/W) | 0 | Nov 29, 2011 10:29 AM |
| Wanted SU-34 Freewing | lw777pilot | Aircraft - Electric - Jets (FS/W) | 0 | Apr 30, 2011 03:29 AM |
