Old Sep 01, 2012, 03:04 PM
urrl is offline
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
I repaired the front gear door hinge with epoxy, then layered on another coat to reinforce the break. Hope it works. Looks good.
urrl is offline Find More Posts by urrl
Old Sep 01, 2012, 10:53 PM
jk671 is offline
Find More Posts by jk671
John
jk671's Avatar
United States, NV, Las Vegas
Joined Mar 2011
Hey guys,
Sorry I haven't responded to anyone since I had my misfortune on thursday. Honestly, I've been so irritated with myself for making such a rookie mistake I didn't want to talk to anyone... I was actually just going to count my losses and ditch this airframe and buy another one from bananahobby or hobbyking... but today I was just sitting down depressed in my livingroom. then i just said, screw this I'm gonna fix that dang plane.... so i grabbed all my broken pieces from the trunk of my car and just started trying to put this mangled jigsaw puzzle together... little by little she started taking shape again! she's finished for tonight... tomorrow I just need to sand down the foam putty and then I am going to paint the nose cone... here's my progress so far.
Thanks for everyone's encouraging words and for encouragin me to rebuild this plane...
jk671 is offline Find More Posts by jk671
Old Sep 01, 2012, 11:28 PM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Looking good. Sometimes you just gotta sit back wait a few days and assess the damage. Makes putting the pieces back together easier and willing.
v8truckin is online now Find More Posts by v8truckin
Old Sep 02, 2012, 12:35 AM
Sockrat is offline
Find More Posts by Sockrat
Canada, AB, Calgary
Joined Oct 2010
Cg
Anyone feels CG on this plane is too high? Amount of counter-aileron I have to give to get into a leveled flight after a sharp turn concerns me. The plane feels a bit like bicycle - it tries to bank left or right (especially at WOT) all the time. I'm using 5000mAh battery and stock cg.
Sockrat is offline Find More Posts by Sockrat
Old Sep 02, 2012, 04:21 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
The vertical position of the CoG doesn't affect lateral stability (roll). Lift is always acting through the same point, regardless of the angle of bank, and therefore has no restorative moment.
Dihedral is what you're after. Not scale, but can be easily added to the aircraft. A degree or two should make the plane noticeably more stable.
Odysis is offline Find More Posts by Odysis
Old Sep 02, 2012, 08:06 AM
SU-4ever is offline
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Well, it actually does.
Dihedral is more important but a high CoG will also make an airplane more Roll-unstable.
Specially a jet because of short wings and low inertia.
SU-4ever is offline Find More Posts by SU-4ever
Old Sep 02, 2012, 08:20 AM
Odysis is offline
Joined May 2007
How does a high CoG affect lateral stability? I can't see a way it can generate a moment?
Old Sep 02, 2012, 08:21 AM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Sockrat; try a roll with the gear down and see if it differs. It is slightly but no enough to impede judging by the displayed roll rates.
I assume you have the ailerons Y'd so that it wouldn't be dif or servo arm isn't positioned to induce uneven throws top or bottom.
Beyond that the only other route is change to functioning tailerons for a greater roll moment. TV in roll helps when thrust is engaged but there are a lot of times that you'd be off the throttle so....
Oh and are your Ail servos working fine?
Maxthrottle is offline Find More Posts by Maxthrottle
Old Sep 02, 2012, 10:58 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Sitting on 22's
An Su aint an Su without its signature green wheels Pitot Tubes next for the Final detail!
Old Sep 02, 2012, 12:24 PM
High Orbit.....
Joined Jun 2009
Depends on your meaning but short moment vs long moment; skaters spin rate arm in vs out.
If I put a weight on a pole and stuck it on top, it would balance at level, but as you roll, the ail deflection force is less as the roll starts as the weight naturally speeds the roll to invert, and greater to pull that weight back around top.
Dihed moves the CG to a lower position rel to AC and as SU said it forces aerodynamic stability like that of a trainer. So with velocity you get an induced effect that's generally not desired for a 3D model.
The battery sits above the EDFs, the landing gear and the rest of the fuse so it is expected to some degree. The tailerons position gives it a better moment in roll but induces the offset corkscrew effect being aft and lower.
It also varies with neutral to nose heavy with the shift of the battery.
All small effects but creating what Sockrat may be observing.
V8 love the green wheels.
Old Sep 02, 2012, 02:21 PM
Sockrat is offline
Canada, AB, Calgary
Joined Oct 2010
All servos working fine, throws up to manual. Might be the altitude that causes it - 1200m (4000ft)?
If I compare SU 34 and 35 - the first one has battery at the very bottom, this one at roof. And 34 is way more stable in turns. On the other hand EF has a high battery too but no such tendency. In MIG-29 they placed one battery low in nose for that purpose I think (don't believe guy didn't have an idea to place it like in 35 - there's a perfect spot behind retracts there)
High CG makes plane non-flyable - I once mounted FPV camera with battery and transmitter on Supercub above the cabin (right at CG but like 15cm above). The plane was constantly trying to flip upside-down even in leveled flight.
To summarize what differs SU-35 is If I make a turn with wings 45 degrees to horizon and then put ailerons to neutral: trainer will level, most edf's I have will continue turn and maybe slightly level up, SU-35 will either stay in turn or stall by making wings 90 degrees. So, pilot has to do a little of counter-aileron to keep it in turn and like 70% opposite to level.
Anyone has the same feeling?
Old Sep 02, 2012, 04:01 PM
merlinfan is offline
Find More Posts by merlinfan
Throttle Bender
merlinfan's Avatar
Joined Jun 2008
I weighed my camera mount and cam and it was 2.5 oz, one of the big clips weighed 1 oz and I used it as a counterbalance on the other wing. I moved my 5000 all the way forward to keep cg the same and used high rates. It flew like crap! The weight on the wingtips made easier to over control. I was so busy trying to smooth it out that I didn't think to try low rates.
merlinfan is offline Find More Posts by merlinfan
Old Sep 02, 2012, 06:06 PM
SU-4ever is offline
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
I actually don't have to.
You could be also experiencing the effects of a very NOSE HEAVY plane effect. If you have your CG too much forward for a stable setup, on th turns, the airplane will tend to bank deeper because of the moment created by the pair of forces weight vs lift. (Think of CG being ahead of center of pressure).
Cheers!
Jandro.
Old Sep 02, 2012, 06:10 PM
Throttle Bender
merlinfan's Avatar
Joined Jun 2008
I thought the flat spin was better on low rates. I'll have to try an inverted flat spin on low rates.
Flanker2 001 (5 min 6 sec)
Old Sep 02, 2012, 06:58 PM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
http://m.youtube.com/watch?v=2C-YcScLV8I]
Very Nice Flight... I especially liked the landing, very soft very gentle!
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
