Old Aug 30, 2012, 07:23 AM
urrl is online now
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
Wargassm thanks for sharing. Nice moves; don't see a lot of pilots doing prolonged inverted maneuvers like that. You might think about repositioning the rear view cam though in your second clip though unless the weight effects your balance. Most movies will show the rear vertical stabilizers. Hope to see more
v8truckin thanks for the tip; ordered the cam. They have a version 2 but it's expensive and I like your resolution so I stuck with your cam. Hard to beat for the price. Or do you have the version 2?
urrl is online now Find More Posts by urrl
Old Aug 30, 2012, 08:44 AM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
I've got the v1 720p wing cam . I will get the v2 1080p at some point, concerned about its weight @ 200g. Got enough weight from mods and v1 cam.
v8truckin is online now Find More Posts by v8truckin
Old Aug 30, 2012, 05:32 PM
urrl is online now
urrl's Avatar
Joined Aug 2010
Just another weird thing I'm doing to help protect the finish. It worked well on my EPS Airfield F-15 with no apparent structural weakening and seems to be working well with the SU-35. I would not recommend doing this at least till I am finished with the job. It starts with very light coats of clear acrylic spray purchased at my local auto store. EXTREMELY light first coat so it won't eat the styrofoam and the coats become heavier as time goes on. So far 3 coats. I haven't even started on the top yet. Time and patience are critical.
I'm hoping to get a hard shell after maybe ten or 15 coats.
Old Aug 30, 2012, 05:48 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Wondered when we finally see this....
Eurofighter 90mm - Su35 volo in coppia (5 min 11 sec)
Maxthrottle is offline Find More Posts by Maxthrottle
Old Aug 30, 2012, 05:59 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Did you weight it prior to your 1st coat? That way u know how much weight was added once you get your final coat and so others know what Wright addition to expect. Looks good and shiny! I used WBP instead only difference is brush on, doesn't form a real hard shell, doesn't eat foam. I did it mainly for hangar rash and ease in the cleaning of the foam as the foam without protectant stains over time from fingers and use.
Old Aug 30, 2012, 08:04 PM
SU-4ever is online now
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
ಠ.ಠ
OMG!
A freewing dofight!
SU-4ever is online now Find More Posts by SU-4ever
Old Aug 30, 2012, 10:45 PM
jk671 is offline
Find More Posts by jk671
John
jk671's Avatar
United States, NV, Las Vegas
Joined Mar 2011
Freewing SU-35 Flight #5 Rear FPV Cam (5 min 27 sec)
Freewing SU-35 Crash Caused by Wing Cam (3 min 58 sec)
Here are my last two flights with the SU-35. I was trying to get some good footage, but I didn't balance out the wings like I should have!! I don't really know what exactly happened and i don't know if I can fix her, but it sure looks like this airframe is toast... I HAVE to get another one... but I might have to be patient in getting it.
jk671 is offline Find More Posts by jk671
Old Aug 30, 2012, 11:13 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Sorry to see your plane lost Jk! Nice 1st save! Seemed St. Jandro was there, but left too early.
1st off what camera did you use for your video? If its larger than 150g then the cam weight was a big factor.
2nd when adding a cam to the wing you need to add a lil weight to the opposite wing atleast a qrt. of the weight you added to the cam side.
3rd once in the air with the cam you MUST trim her to compensate for any wing dip that may arise by adding the extra weight of the cam (adding the counter weight help alleviate some of that needed trim). But then you still have to worry about inverted flight.
4th And Dont take this the wrong way, but not sure what you experience is but maybe that also had something to do with it. Since the added weight will cause the plane to turn sharper to the heavier side so reaction should have been expected.
Looks like itll be hard to repair that airframe. Again sorry! Just trying to help u out.
On another note ill be posting pics and vids of my finish repair and flight!!
Old Aug 30, 2012, 11:28 PM
MercerMaggot is offline
Find More Posts by MercerMaggot
Canberra Australia
Joined Jun 2009
Tough luck John. You must have felt like you went 5 rounds in a heavy weight fight. You did really well to recover the first time, but it was always going to be a tough ask with just a narrow street to line up for final approach...and the worry that the battery was going to go if you left it up there too much longer
MercerMaggot is offline Find More Posts by MercerMaggot
Old Aug 30, 2012, 11:34 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Gee, that was interesting about the wingcam 'effect'.....
When they were first being done I was thinking exactly that... some detriment possible. But no one seemed to have any issues, and putting them anywhere without issues.
Maybe it was something else too?
Losing an aileron, depending on how it happens, can have an imbalanced effect too. eg how the pushrod then acts. I have had one fault allow slop one way, and resistance the other, so rolling one way was weird, and just weak the other way.
I assume you didn't use a HD camcorder? LOL
It should be repairable..... most are.
PeterVRC is offline Find More Posts by PeterVRC
Old Aug 30, 2012, 11:49 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Final SU35 repair pics and 2 vids
Heres the Pics & videos of my 1st flight after finishing repairs today.
Pics added silver to resemble the glass on the OLS-UEM tracking system infront of cockpit. Painted cockpit blue to cover up some epoxy. Also after looking things over I felt that the nose area didnt need to be reinforced after all for the nose gear. Landings are soft enough to prevent a major break. Most of the weight on landing is carried on the mains so land her with the nose slightly up and not a high AoA and your fine. If i do brake the nose I would rather it just snap again than break further back, just my opinion.
1st flight since repairs & making sure she flys fine, landing was perfect!!!
Freewing SU35 1st flight after Repair wing cam PICT0001 (7 min 0 sec)
2nd flight Wing cam underneath the wing
Freewing Su35 bottom of wing cam PICT0004 (6 min 4 sec)
God I love this plane!
Finished Results
Old Aug 31, 2012, 12:23 AM
kremecheze is offline
Find More Posts by kremecheze
kremecheze's Avatar
United States, NY, Queens County
Joined Jun 2007
anyone looking to buy one of these, i'm cleaning my hangar out and she's taking up space
kremecheze is offline Find More Posts by kremecheze
Old Aug 31, 2012, 12:42 AM
merlinfan is offline
Find More Posts by merlinfan
Throttle Bender
merlinfan's Avatar
Joined Jun 2008
I should have checked V8's photos before I made my camera mount, I used the bigger size clamp I had and it's as big as the cam. I had quite a left roll on takeoff but was expecting it. It didn't fly as well but no real problem. I wonder if there was another control surface issue or something.
merlinfan is offline Find More Posts by merlinfan
Old Aug 31, 2012, 12:45 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
When I added cam to the vert stab that's what made me almost stall and reason why I landed hot thus causing me to bounce and break nose. Wig hasn't been an issue.
Old Aug 31, 2012, 01:03 AM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
I'm using the v1 wing cam from hobbyking.
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
