Old Aug 29, 2012, 10:44 AM
urrl is offline
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
This mornings flight with tail cam
SU-35 with POV cam on tail (1 min 53 sec)
urrl is offline Find More Posts by urrl
Old Aug 29, 2012, 11:01 AM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Nice vid, again I really enjoy seeing other pilots field. Seems your cam has a lil bit more zoom than mine does. How did you mount your cam?
Glad it didn't effect your flying or landing. My cam is 140g while yours is around 35g so that was definitely a big factor on addding mine to the back (still won't do it again) prefer the wing view.
v8truckin is online now Find More Posts by v8truckin
Old Aug 29, 2012, 11:39 AM
urrl is offline
urrl's Avatar
Joined Aug 2010
Thanks. It's all velcro attached. I was hoping it would not fly off the jet.
Old Aug 29, 2012, 01:43 PM
SU-4ever is offline
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Seems my "karma" is there only for thrust vector assists...
The more energy you have, the worst the outcome potential, just nice you're getting it back toghether so fine! Nice work there!
Cheers!
SU-4ever is offline Find More Posts by SU-4ever
Old Aug 29, 2012, 01:59 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Put to much work into her paint, weathering, mods,, & stuff to just pull everything out start a new fuselage.
Old Aug 29, 2012, 02:37 PM
flylowfast is offline
Find More Posts by flylowfast
Joined Jun 2009
Originally Posted by v8truckin View Post
Wing cam mounted (Jandro patent still pending lol!) on my SU showing the Airbrake functioning. TP90MG servo (metal geared) seems to hold the airbrakes position in flight better than the 9g nylon servo did. Also tested out my New Gforce Elite 5000mah 40C & have got to say for the price and weight 778g its a very good pack and delivers just as much performance as the Gens 5300mah. Dont forget 720p
http://youtu.be/N5-0moYKgbI
Very nice video. What camera did you use on the wing ?
flylowfast is offline Find More Posts by flylowfast
Old Aug 29, 2012, 03:13 PM
jk671 is offline
Find More Posts by jk671
John
jk671's Avatar
United States, NV, Las Vegas
Joined Mar 2011
Originally Posted by SU-4ever View Post
Great vids there JK! The sunset scenes were breath taking!
To me it just seems you fly always WOT or at least very hot, this jet glides amazingly try slow a bit down to get a more comfortable feel of it and to be able to fly safer in a larger flight envelope, start doing it at high altitude if you are not sure.
Now you see, and there is enough video proof, that TV control is a great aircraft saving device and very inteligent to leave it always on (And learn to fly that way) in order to get out of desperate situations!
Thanks V8, you can not imagine how hard I laughed at this
So sorry your Su has crashed, looked so nice... You land very hot too!
Cheers!
Jandro.
Good advice!! Thank you... I WILL start slowing her down a little bit. It'll also give my wife an easier time of keeping track of it.
jk671 is offline Find More Posts by jk671
Old Aug 29, 2012, 03:21 PM
jet-ster is offline
Find More Posts by jet-ster
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
Hell guys I'm about to start on mine I just keep it stock. It's been awhile since I got back to RC. So what are some key issue on this jet? I was skimming back on threads. So the noise gear area is weak and need to be reinforce?
jet-ster is offline Find More Posts by jet-ster
Old Aug 29, 2012, 03:53 PM
urrl is offline
urrl's Avatar
Joined Aug 2010
My nose gear was not that weak; it was the wing gear mostly. The mount for the nose gear IMO is reasonably strong. Nevertheless the back and forth wobble of the gear during take-offs was annoying and I took some advice and made a piece for the nose gear support rod assembly out of a piece of hot glue stick, which I hot glued in of course.
I have no doubt it helps support the landing gear. Others do this with a piece of wood glued in.
Land like you are doing it on egg shells with no quick turns after landing. Very fragile wing landing gear.
Do not use vector thrust on maiden take-off unless you've done it before and if you don't know how to disengage VT on take-off like me, dumb down the VT elevator movement; I did it through my transmitter, down to 40% for maiden. Now I fly all the time with VT, take-offs and landings, at 60% elevator movement and can do flat spins at that setting with ease every time.
I may be going overboard here but if I had those thin rubber disposable gloves I would use them during assembly. The jet attracts fingernail scratches and indentations.
Don't ever guess at how much battery power you have left during a flight.
Don't risk it when the wind picks up or landings may suffer. But then I guess some of these rules apply to most foamy aircraft.
I fly without any fuselage re-inforcement on my stock SU-35 but I obey my own rules.
Oh yeah, stock ESC's may overheat, but my Ram Air mod, which some disapprove of due to esthetic values, does work well and since I've had it there have been no ussues of overheating.
A sign of overheating for me was a slow down accompanied by an oscillating pitch in motor noise; the motor was alternately going fast, then slow during pretty much all of my flights. There is another work around; to open holes from the inside so that the ESC can get air from the fan intakes but I did what was simplest for me. The point that I must be flying in order to cool the ESC's is a moot one for me as I do not have the jet sitting with the engine running for any great length of time anyway; I just put the jet down and fly; so your choice, although it may be you never have to make that choice; your ESC's may work fine without any mods.
There are also other alternate tips that I'm sure others will bring up but I am very happy with my solutions listed here.
Old Aug 29, 2012, 05:16 PM
urrl is offline
urrl's Avatar
Joined Aug 2010
Where did you get your cam? Love the wide angle.
Old Aug 29, 2012, 05:33 PM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
The new (recent) range of oleos at HobbyKing are top quality and hefty items! No leg rotation, and slide as smooth as silk. And.... cheap cost!
This is the one suited to the Su main gear, and if you look at your nose stock gear leg, it is pretty much that exact same construction. Much better than the stock anaemic main gear legs! Only $14 a pair....
They have a 5mm pin, so you either drill out the trunion, or turn down the pin to convert 'half' to 4mm for the stock trunion hole. You can "turn" down the pin fine with a drill and file....
I can't look now, and can't remember, if the stock retract is metal trunion or not - I don't think so. But if not I will change those too. All I remember is that the stock ones have a lot of slop! In the trunion, plus in the leg's rotation.
Oleo leg:
http://www.hobbyking.com/hobbyking/s...Class_1pc.html
Metal trunion retract pair:
http://www.hobbyking.com/hobbyking/s...ount_2pc_.html
PeterVRC is online now Find More Posts by PeterVRC
Old Aug 29, 2012, 09:33 PM
rogerio is offline
Find More Posts by rogerio
Joined May 2004
Anyone know any store in USA to sell smoke canister to use on edf jet?
rogerio is offline Find More Posts by rogerio
Old Aug 29, 2012, 09:42 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Thanks! Love that view, like Jandro said, " Best view ever"
hobbyking 720p wing cam.
Old Aug 30, 2012, 01:16 AM
Wargassm is offline
Find More Posts by Wargassm
Wargassm's Avatar
United States, CA, Lake Forest
Joined Nov 2010
su35 in flight video
Front
SU 35 Trabucco (5 min 29 sec)
Rear
SU 35 Rear Trabucco (5 min 48 sec)
Wargassm is offline Find More Posts by Wargassm
Old Aug 30, 2012, 01:37 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Rebuild is complete. I'll post pics and video tmrw after I take her up for the signature wing cam view (no more vert stab).
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
