I think they actually said 4,6 kg but that would be a really hardcore setup, maybe he just messed it up when they recorded the video.
a 68mm should fit the freewing, maybe with a little work but you wouldn't have counter rotating fans. Not that it is absolutely necessary but definitely a nice feature! And finally, here goes the controversial su-rapping vid:
Enjoy it! Cheers! Jandro. |
here's a flight I recorded of it last sunday playing with my new camera
High Orbit.....
Joined Jun 2009
There actually is footage of the SU-35 on DPS 68s
They don't say which motors they are using but here's the flight vid. Believe it was posted here before. |
Here's a little update on my progress so far... also hope my new method for holding down the motors work...
For more of my progress and more videos that I didn't post here... you can find them here... http://www.rcgroups.com/forums/showthread.php?t=1715426 |
Australia, VIC, Melbourne
Joined Nov 2006
Oh yeah you NEED those intake lips!!!
You will lose power for nothing otherwise. Unfortunately the straight fit onto an ERC fan is a Wemo lip. Those can't be used in the Su viably. BUT.... you can make the CS10 inlet lips fit fine. Run layers of tape around the front area, to the lip, to build it up so the CS10 lip then fits nicely. Then tape the lip on in the usual way people do. I forget if the stock lips can be done the same..... I think they can, but just can't remember what I found with those. (I used CS10 lips) But if you use the CS10 lips, then they either need to be ground down to have a smaller outer diameter, or cut out foam so they fit in their original size. I 'hand spun' mine on a bench grinding wheel, so they were close enough to 'round' still. Because they seat into foam slots, that is not a critical accuracy to need. |
Might try those 4800mah for my euro w/ cs12. |
| Thread Tools | |
| New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability | neversommer | Foamy EDFs | 593 | Jan 09, 2012 09:02 PM |
| Discussion LX F-35 Vs Freewing F-35 | Mmarshall | Foamy EDFs | 16 | Dec 27, 2011 03:40 PM |
| For Sale Freewing SU-34 stock battery - Brand New | JGuilty13 | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Nov 29, 2011 02:01 PM |
| For Sale Freewing SU-34 stock battery | JGuilty13 | Aircraft - Electric - Jets (FS/W) | 0 | Nov 29, 2011 10:29 AM |
| Wanted SU-34 Freewing | lw777pilot | Aircraft - Electric - Jets (FS/W) | 0 | Apr 30, 2011 03:29 AM |
