Oh is that what is called?
Its possible to do that as I've done without any need for wind. Just slow down like your going into a cobra and when speed is getting to almost to a hover give full elevator and throttle. Bam! Kulbit! I've been able to do 2 consecutive flips but the last flip ends with a slight stall. |
High Orbit.....
Joined Jun 2009
But this discussion was started with comments about SU-35s history... pedigree and that the current version was run of the mill and this being because of a lack of canards and air brake? You're learning the dynamics so you know there have been many many approaches that a great many designers have used like; taking mass off or making fuel distribution more managable at the outer points of the aircraft making the system more agile... So as many remain in a love affair with canards, which the US makes fun of because it makes a military aircraft more visible, they and Sukhoi used other measures to maximize agility at less cost and can and can't do a kulbit for various reasons. Over on the F-16 forum they've said the F-16 theoretically could even do the Kulbit but the air force restricts pilots even attempting it because as we know Russian aircraft are made like tanks. Having said this Sukhoi brought them back the aerodynamic feature with the use of LERX on the T-50. Only they made them conformal to the strake/fuse for LO. The entire super manueverabilty was both a promotional political tactic but in certain scenario's it increases a threat window. So they added the features to the F-22 just in case. For us its all just pure performance entertainment for the craft we love. |
Well I already said (And won't quote myself
) that I wouldn't completely rely on Sukhoi's firm statment as I wouldn't on any other aeronautical firm, so no worries about that. I'm pretty anxious to see the PAK-FA starting to do a bit more of a show on the displays and see what the russian new generation aircraft can do! Now back to the Su-35 lovely model-thing (Before the other modelist start throwing us stones... or broken fans, maybe old planes...) today there wasn't clouds so we took pictures instead of vids and here is the outcome! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Yeah that was a big bunch of pics but I initially had over 300 shots so it's not that much after all, it was dificult to choose just a few, this plane has a horrible tendency to be awesome in ALL the pics ^^ 20 flights so far! Cheers! Jandro. |
Joined Jan 2011
I started assembling mine today to find that one of the elevators servos did not work. i replaced it with a Hitect HS-85MG and then found that both elevator servos are on a Y cable and the elevators end up working as ailerons. Going to separate the elevator servos so I can reverse the direction of one of the servos.
Joined Aug 2010
Joined Jan 2011
High Orbit.....
Joined Jun 2009
SU-4Ever, what did you finally settle into for CG and what's your stab angle at for level? Did you go a little more tail heavy just for the Kulbit?
What roll rate did you set your tailerons at? I noticed you're not cork screwing much on roll. Did you mix that out or is it just not that pronounced? |
Max, I haven't measured it but I use stock setup (Save for three gyros and main gears) with a gens ace 5300mAh farthest back allowed by the battery tray so you can guess.
But I know I'm not actually flying tail heavy as I said I would, because I have the stabs correcting for a pitching down tendency. I may measure it one of these days to give more accurate numbers ^^ So no, the kulbit wasn't done tailheavy ^^ I'm not sure I completeley understand your question about the roll rates. I fly with full travel for the tailerons in pitch axis all the flight (Unless I need to land in windy conditions), I have the low rates enabled for most of the flight for the rudders and ailerons+ tailerons for yaw and roll axis. Y only set full rudder deflection for 'drifted' snap rolls and flat spins, and I use full aileron deflection only for quick rolls. The roll movements I have very limited deflection as I found this airplane was very responsive in that axis. When performing the backflips or kulbit attempts I slow down and aggressively pitch up for the closed drifting tail loop, and then I correct lateral unstability with RUDDER, I often leave the aileron stick untouched or just a very little correction, hope that answers your question, I don't have any mixing to help that ^^ Cheers! |
| Thread Tools | |
| New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability | neversommer | Foamy EDFs | 593 | Jan 09, 2012 09:02 PM |
| Discussion LX F-35 Vs Freewing F-35 | Mmarshall | Foamy EDFs | 16 | Dec 27, 2011 03:40 PM |
| For Sale Freewing SU-34 stock battery - Brand New | JGuilty13 | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Nov 29, 2011 02:01 PM |
| For Sale Freewing SU-34 stock battery | JGuilty13 | Aircraft - Electric - Jets (FS/W) | 0 | Nov 29, 2011 10:29 AM |
| Wanted SU-34 Freewing | lw777pilot | Aircraft - Electric - Jets (FS/W) | 0 | Apr 30, 2011 03:29 AM |
