Everything is stock except for the esc's which are castle ice 75a and are placed in the stock location. Timing on esc's are set to medium. Motors/fans are stock purple can. My last flight the right motor smoked this time it was the left one. Battery is gens ace 6s 5300mah. Connectors are EC5's.
High Orbit.....
Joined Jun 2009
Australia, VIC, Melbourne
Joined Nov 2006
I was testing the remaining 'good' motor I took out of the Su - the whole fan/motor combo. I think I had tested it on the bench back when I did take them out, but couldn't find records of that. So I ran it up on 6S and it only gives out 600g thrust !! Pretty well exactly what the 'faulty' motor/fan had done!
I think it is 4 pole, but maybe not, so the RPM readout is not trustworthy, but the sound was 'high RPM' to me. I threw in another fan/motor (same ESC) and it worked fine, so the scales and every other test setup aspect were fine still. But it is very weird that BOTH the gold Su fan/motors ended up at that same output result - drawing 32Amps for that. But both had been fine in the initial in-plane tests, until that first one floundered and had me remove it to test on the bench - for that initial approx 600g result. I tried every combo of ESC timing/PWM and it was 600g at low timing (1deg) and just got a bit weaker and weaker as the timing was moved upwards (7,15,30). It seems to run perfectly smooth, but the result seems like what I would think if a winding 'died'. Though both motors look fine when checking in through the ends - I will have to open them to check properly soon. So either both are now faulty.... or something else is causing it. But I can't see what that could be. It would be nice if it was some quirk that meant they are both really ok. This test came about as I was working out what to change into my Dynam Meteor... the remaining good Su fan/motor combo on 6S. But not to be. And I have a Lander 70mm 2550kv "6S" combo, that I never even tried or used in 6 months since buying it (!!), and that gives all but 2.0Kg thrust for 51Amps!!! (1.98Kg recorded). That is an awesome output for 51Amps!! If the stupid thing was not so heavy - and costly at $82 - it would be good for in the Su !! I have never even looked at it in detail but it is just fantastic design and construction, with a very good 60mm can Inrunner - it looks like an ARC (due to the holes in its ends), and is not a Leopard/Tacon/TurnigyXK, but is basically of HET level of ability by the looks - in power and efficiency. And being alloy and running at 55k RPM (5 blade) it actually sounds far better than a plastic housed (eg stock Su) low blade count fan. Something like half way to a CS10 sound. But at 51A X 2 = 104Amps at WOT, for 4.0Kg out of plane(!!!) that should be over 3.0Kg in-plane total still. |
| Thread Tools | |
| New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability | neversommer | Foamy EDFs | 593 | Jan 09, 2012 09:02 PM |
| Discussion LX F-35 Vs Freewing F-35 | Mmarshall | Foamy EDFs | 16 | Dec 27, 2011 03:40 PM |
| For Sale Freewing SU-34 stock battery - Brand New | JGuilty13 | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Nov 29, 2011 02:01 PM |
| For Sale Freewing SU-34 stock battery | JGuilty13 | Aircraft - Electric - Jets (FS/W) | 0 | Nov 29, 2011 10:29 AM |
| Wanted SU-34 Freewing | lw777pilot | Aircraft - Electric - Jets (FS/W) | 0 | Apr 30, 2011 03:29 AM |
