High Orbit.....
Joined Jun 2009
OK. I guess you tried it and it fits cause that was your earlier concern. The Tamjet struts sit like a straight post with no weight but articulate like the trailing link under load. So that why I mentioned those in particular. Still looking for a source for everyones reference.
High Orbit.....
Joined Jun 2009
Regarding various batteries it could be... while the motor only demands what it can use, they can use themselves to self destructive burn up. So those extra amps from the battery is only limited by the ESC. The Sky lipo may have a greater Volt sag or other that is just not giving the motor as much as the next battery. If the connector is a fault and more current passes the more it shows itself to be the problem child. Now that all being speculation, you could tell by adding a watt meter and see the through put for each battery. We know that some who have flown 4500 55C have available 247.5 amps. None that I know of have said the ESC cut out so either they are not red lining it for long or the motor is not demanding much over ~55amps for any length of time. Either way I'd have a good look at the connectors like V8 described. |
High Orbit.....
Joined Jun 2009
Hey the big wheel sticking out as is, is an eyesore that I have to live with. I am so tempted to try a Russian rotating retract.
Anyways, actually Jandro you may be interested in these; Tam Jets Strut Trailing Offset Right 100mm. This is just a sample from a vendor and in not way is to support or promote said vendor. If the SU-35 is; Strut: Nose Gear Strut and Wheel Height_155mm_, Wheel Dia. _45mm_ Main Gear Strut and Wheel Height_120mm_, Wheel Dia._65mm_ The Tamjets will accommodate Wheel Dimensions: Offset strut : 2" - 2 1/4" (50 - 57mm) Straight strut: 2 1/2" - 3" (63 - 75mm) So the offset strut with a 57mm wheel would bring you to 157mm on the nose. The Mains would be 150mm which is 30mm longer but you could replace the spring so that its softer and thus sits lower when on the ground but goes straight when retracted... ah but then the wheel would be 30mm further forward.... which isn't so bad since it still would tuck in the well. |
Wow, thanks Max!
Didn't knew them, I think you just hit the sweet spot! Apart from nice looking and well-finished they seem pretty affordable! Now that I've installed the Eurofighter struts (Which I had as spare when I acquired my second Euro) I will leave them installed on The SU but keep an eye on these for future EDF's to come (I've yet to build a Hobby Topgun L-39 for FPV purposes and didn't like the stock struts...) Cheers! |
United States, CA, Lancaster
Joined Feb 2012
High Orbit.....
Joined Jun 2009
But not certain if I'm seeing the entire selection from the vendors and interwebs. The tall narrow wheel is an advantage on grass so if while your there you could beg them to do a special order for the SU-35 like they did for the Habu ![]() Ed since these are straight legs but may be a little long it would be like have what is there stock with a longer strut. The offset struts might recess these closer up against the duct but till someone has them in hand, its hard to say. I'm not sure of the dimension options at this time. |
| Thread Tools | |
| New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability | neversommer | Foamy EDFs | 593 | Jan 09, 2012 09:02 PM |
| Discussion LX F-35 Vs Freewing F-35 | Mmarshall | Foamy EDFs | 16 | Dec 27, 2011 03:40 PM |
| For Sale Freewing SU-34 stock battery - Brand New | JGuilty13 | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Nov 29, 2011 02:01 PM |
| For Sale Freewing SU-34 stock battery | JGuilty13 | Aircraft - Electric - Jets (FS/W) | 0 | Nov 29, 2011 10:29 AM |
| Wanted SU-34 Freewing | lw777pilot | Aircraft - Electric - Jets (FS/W) | 0 | Apr 30, 2011 03:29 AM |
