Espritmodel.com Heli Air
Old Dec 26, 2011, 07:05 PM
Joined Nov 2007
really need your help
hey guys
I seriously need your help
I'm at critical stage in my quad build.
i need to know what motor and ESC and prop to get.
this is what i'v got so far
frame=400 Grams (square aluminum 25 inches motor to motor)
camera=225 Grams
battery=170 Grams 2200 / 3s / 12c (they're pretty old so i could buy some new ones)
receiver=12 Grams (AR6200) with DX6i
total 800 Grams + or - a few Grams without motors
Any input will be appreciated
Henri
keya is offline Find More Posts by keya
Old Dec 26, 2011, 07:22 PM
Hawaii
Joined Feb 2003
Originally Posted by keya View Post
hey guys
camera=225 Grams
Henri
You can probably use some 180 watts motor with 900 kV and 10" X 4.7" propellers. I will definitely get some new batteries because your frame is really heavy. If you can lighten the frame then you are much better off. Typically for that payload you want your frame to be around 200 grams.
You next best bet is to use more powerful 200 watts motors with 800 kV and 11" X 4.7" props. That is really a waste to haul up just a 225 grams camera. Unfortunately again your frame is taking up a lot of your payload weight.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Dec 26, 2011, 07:33 PM
Mortimer's Avatar
Joined Apr 2010
These topics might help you: showthread.php?t=1388583 - showthread.php?t=1557506
Mortimer is offline Find More Posts by Mortimer
Old Dec 26, 2011, 08:41 PM
Joined Nov 2007
what do you think about these motors http://www.hobbyking.com/hobbyking/s...dProduct=14397
do you think it would have enough power to lift my quad?
Old Dec 26, 2011, 08:52 PM
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
Those motors are a tinny bit on the big side, but you are lifting a LOT of extra weight. What camera are you lifting? 225g is heavier than a gopro.
Your flight times are not going to be exceptionally long.
Old 12C battery's are NOT going to cut it, order some better battery's in the 20-30c range min.
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old Dec 26, 2011, 08:54 PM
Mortimer's Avatar
Joined Apr 2010
I use this motor, it's quite good, cheap and strong (4mm shaft).
WOT it lifts around 950g with a 10x4.7 APC and it uses 2A at 200g.
Largely enough for your project.
Look here: http://www.rcgroups.com/forums/showt...1388583&page=4
Old Dec 26, 2011, 08:58 PM
Joined Nov 2007
lets say i get this motor and some new battery and 10x4.7
what kind of flight time could i expect?
BTW thanks for your help....its greatly appreciated
Henri
Old Dec 26, 2011, 09:10 PM
Mortimer's Avatar
Joined Apr 2010
Flight time depends of your piloting.
I think around 10' for AP hover at 800g with a 2200mAh battery and much less for acro.
Old Dec 26, 2011, 09:23 PM
Joined Nov 2007
is there any other way of increasing my flight time
using my current frame. for ex. bigger battery?
Old Dec 26, 2011, 09:27 PM
Village Idiot!
Joined Apr 2011
He is at 800g without motors 280g, ESC's 60g, props/wire/connectors 40g
Im guessing 1200 flying.
Old Dec 26, 2011, 09:29 PM
Village Idiot!
Joined Apr 2011
Bigger battery is more weight to lift. If you double the battery size, you might get 60-70% more flight time. But it will fly "heavy".
Old Dec 26, 2011, 09:33 PM
Joined Nov 2007
what would you do in my position
i really like my frame so in your honest opinion
what would do?
thanks
Old Dec 26, 2011, 09:40 PM
Village Idiot!
Joined Apr 2011
You could save 130g by using a gopro and shorten the arms a little. Thats about it. Or build a new frame, with thinner wall arms.
Old Dec 26, 2011, 09:42 PM
Joined Nov 2007
what about ESC
would you go with plush 20A or 30A
Old Dec 26, 2011, 10:06 PM
Village Idiot!
Joined Apr 2011
Me? Well, the real weight saving come when you get down below 18a esc's, like 12a or 10a. If I had to chose between 20 or 30, I would take the 30's ONLY because they are only 2g heavier and a $1.50 more.
Discussion 30 Days Left! We REALLY need your help! Kyle Paulson Multi Task F3X 20 Aug 29, 2011 01:17 AM
Discussion REALLY need Help w/throws tomtheman Electric Plane Talk 13 Jul 05, 2011 06:32 AM
Discussion Need Help-Really confused about flap installation eagle1933 Beginner Training Area (Aircraft-Electric) 2 Apr 09, 2011 12:06 PM
Discussion Really need your help, Brushless E savage or Savage X RTR? bzn0941 Off-road Cars 0 Sep 11, 2007 01:22 AM
Really need your help. Motor (Axi) for a 7-8 pound 82" Cub? Zeroaltitude Power Systems 24 Jun 09, 2005 06:02 PM
