Old May 07, 2012, 10:02 AM
CSpaced is offline
Find More Posts by CSpaced
Team Futaba
CSpaced's Avatar
Oak Ridge, NC
Joined Jun 2006
Originally Posted by ruff1 View Post
Sounds like it to me, whenever I plug in the Deans connector it beeps and the display turns on. If it is working fine with the balancing connector there might be a problem with the power leads. I would e-mail Electrifly, or if you got it at the LHS see if they'll swap it (mine would). I got an answer back in a day when I sent in a suggestion for the manual.
I'd give Hobbico a call, I'm sure they will sort it out for you.
You can call them at 217-398-0007, they are open 8am-5pm US Central Time.
www.hobbyservices.com
CSpaced is offline Find More Posts by CSpaced
Old May 19, 2012, 04:26 AM
bob_nj is offline
Find More Posts by bob_nj
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
Subscribed
I'm primarily looking for a watt meter for my small electrics and this sounds like the ticket. I'll see if the local shop has any in stock.
bob_nj is offline Find More Posts by bob_nj
Old May 19, 2012, 01:53 PM
ruff1 is offline
Find More Posts by ruff1
A Day @ a Time - Matt. 6:25-34
ruff1's Avatar
North AL, USA
Joined Nov 2009
I think you'll like it, it works good on the small stuff, but a guy with a $1000+ heli checked his 6S battery packs and he really liked it - he didn't have a good way to check his battery level at the field. This one will check up to 7S.
ruff1 is offline Find More Posts by ruff1
Old May 20, 2012, 03:52 AM
bob_nj is offline
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
Big Power Lead?
When I plug a pack into the big power lead, I can't change the cell count for LiFe?
What am I doing wrong?
4S is the default...
Old May 29, 2012, 10:37 AM
Skaluf is offline
Find More Posts by Skaluf
Skaluf's Avatar
Sadorus, IL
Joined Mar 2004
You'll need to use the balance connector to see each cell/change the cell count.
Steve
Skaluf is offline Find More Posts by Skaluf
Site Sponsor
Old May 30, 2012, 02:13 AM
bob_nj is offline
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
Pack Voltage
I just want to use the meter as a voltmeter at this point and check pack voltage.
So, the item isn't a voltmeter then?
Old Jan 29, 2014, 10:10 AM
bob_nj is offline
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
A new question?
I'm using the Power Checker function on small 2S packs.
There is no "AVG", "MIN", "MAX" values on the screens.
The main screen works, but that's it.
It may have something to do with this statement in the manual which I am not sure of -->
"The meter will display and track current, power, and energy data once 500mA has passed through for 3 seconds"
Any thoughts, ideas?
Bob
Old Mar 30, 2015, 07:43 PM
arbtmn is offline
Find More Posts by arbtmn
Marty, Louisiana USA
Joined Jan 2015
Does anyone know about which way to plug the balancer plug into the unit? it has one red wire and all the rest are black. Is the red wire the ground?
arbtmn is offline Find More Posts by arbtmn
Old Mar 31, 2015, 01:01 PM
arbtmn is offline
Joined Jan 2015
Anybody?
Old Mar 31, 2015, 02:16 PM
Mike Dubovsky is online now
Find More Posts by Mike Dubovsky
I am a nice guy! Really!
Joined Aug 2013
Just looking at the photos in the review, it looks like the most negative point goes on the pin with the triangle label on it, then the others are the first, second,third etc cell of the battery. If you want to be sure which pin is most negative on your battery, you can use a voltmeter from the negative power lead of your battery to each of the balancing leads. The one that shows no voltage would be the negative lead. The others should show increasing voltage levels in about 3.7 volt steps. You can use a fine pin as a probe to insert into the balancing plug for these tests. just be careful not to short any of the points together while testing.
Mike Dubovsky is online now Find More Posts by Mike Dubovsky
Old Apr 02, 2015, 07:48 AM
arbtmn is offline
Joined Jan 2015
great idea. I will do just that. Thanks a bunch
For Sale NEW Great Planes Electrifly Brushless Power System Propnutz Aircraft - Electric - Power Systems (FS/W) 5 Jan 09, 2012 11:38 PM
Sold Power Meter/Watt Meter + Balancer jgalexander Aircraft - Electric - Power Systems (FS/W) 2 Dec 20, 2011 05:22 PM
Wanted Great Planes ElectriFly Equinox LiPo Balancer So Cal Flyer Aircraft - Electric - Batteries & Chargers (FS/W) 2 Nov 22, 2011 11:40 PM
Sold Great Planes ElectriFly Equinox LiPo Balancer Blue Note Aircraft - Electric - Batteries & Chargers (FS/W) 2 Nov 11, 2011 07:47 PM
Sold Great Planes C.G. Machine- Top Flite Power Point Balancer- Great Planes AccuThrow Def 55jer Aircraft - General - Miscellaneous (FS/W) 3 Sep 27, 2006 05:10 PM
