Old Oct 02, 2012, 01:37 AM
andrecillo76 is offline
Find More Posts by andrecillo76
andrecillo76's Avatar
Germany, BW, Stuttgart
Joined Oct 2009
Kent,
the 30° position is from tailed airplanes. It should work, but be careful. I would try first the 45° position and move backwards if possible. If the arm between the CG and hook is too long, the wing pitches strongly when releasing (like in your video) . This can have two downsides. First, the wing pitches so strong, that the hook might lose the rubber straight after releasing. Not good for the pilot, but great for spectators . Second, the wing pitches up so strongly without loosing the rubber, that the wing goes over to a stalled condition. You can imagine what this means: no control at all and the wing behaves like a kite on a string. Not good for the pilot and believe me, not good for spectators
Cheers,
Andrés
andrecillo76 is offline Find More Posts by andrecillo76
Old Oct 02, 2012, 09:12 AM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Thanks Andres. We are on the same page. I have personally experienced all of those scenarios with tailed planes. Just as you describe, a tow hook that is too far back can be disastrous in a variety of ways.
I'll start with the 45 degree position, which I consider to be very conservative. If the launch angle is too shallow, I'll pull back on the elevator while on launch. If I am able to do so without problem, then I'll add another towhook back further and repeat. When I get to the point where down elevator is needed on launch to recover from problems, then I'll know that I've found the limit. This is all based on dead air launches.
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Oct 03, 2012, 07:21 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
High Start Launch
­Tried the high start launch today with a single strand of rubber. Pulled it way back to the back of the sand dune. The line force was about half of that of the bungee. A long slow pull.
Worked well. Very stable with the tow hook at 345mm. No where near a pop-off.
­Kent
Manatee High Start at Beach (1 min 4 sec)
Old Mar 09, 2013, 08:48 PM
rusty case is offline
Find More Posts by rusty case
KlonWarz
Joined Dec 2012
Originally Posted by Knoll53 View Post
After a 4 month build for the wood version, a quick foam version is beginning to look attractive. With it's segmented wing twist, it may not fly as well, but the difference may not be noticeable. A suggested panel layout is shown below.
Trust me, a 2m Manatee would be a big plane.
Kent
is there a planform posted somewhere that would show the rib forms which could be used to cut these wing sections from foam?
would be very nice!
tnk u
rc
rusty case is offline Find More Posts by rusty case
Old Mar 09, 2013, 08:51 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Yes, posted somewhere in this thread Andres has a link to his website which has plans. This airfoil is 22% thick!!....Do you really want to fly that slow? It's kinda of a specialty glider.
Kent
Old Mar 09, 2013, 09:41 PM
KlonWarz
Joined Dec 2012
[QUOTE=Knoll53;22870162]
The Masters at work
More Air Junkies
Yup, they're lookin' fer lunch!
Masters, nah... the condors excel at low energy soaring.
More than three flaps of the wing, it's NOT a condor! Well, except for takeoff from flatground... and a really juicy rabbit! lol
Old Mar 09, 2013, 09:51 PM
KlonWarz
Joined Dec 2012
Originally Posted by andrecillo76 View Post
be careful, the airfoil you mentioned is a base airfoil and not the root airfoil! The airfoils at the root differ in thickness and camber. If you really want to re-cook the wing in Ranis, you'll have to export each rib from the DXF to a DAT file.
Aw gosh, can't someone just post a pdf file we could scale with adobe and print it out?
I can appreciate you fellows are hi-tech and enjoy the best tools, but I'd just like to build a wing!
tnx
rc
Old Mar 10, 2013, 04:54 AM
Joined Oct 2009
RC,
sure, I attached a PDF in a scale 1:20.
Andrés
Old Mar 10, 2013, 08:31 AM
KlonWarz
Joined Dec 2012
Thanks, Andres !
The simple pdf will be helpful.
I don't think I've had a real drafting program since autocad 2.5 and that was ages ago! lol
It seems all the limited capability programs available now all seem to come with software packages that seem to overwhelm my computers, so it's necessary to nuke them.
It is my intent to build in foam, so I need templates for a wire cutter.
Yes, Kent. A 22% slow airfoil would be dandy for me!
I have little interest in speed demons, which is good, since my vision and reaction time are waning. :-) I shall be self-taught, which is also high on the list of perils !
This Alpine Sled/Manatee/Horten is quite aesthetically pleasing to the eye and the videos taken at our Kalifornia Coast are wonderful... as are the videos from gebirge settings!
I hope to begin a mockup soon.
Thank you
rc
Old Mar 10, 2013, 10:26 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Thank you
rc
Feel free to post your build log here in this thread.
Kent
Old Jan 05, 2015, 03:53 PM
girinl is offline
Find More Posts by girinl
Joined Nov 2014
Good morning,
I would like to build the Horten wing designed by Lothar & Andrès.
Is it possible to send me last dxf file ?
Best regards and thank you in advance
Lionel
girinl is offline Find More Posts by girinl
Old May 22, 2015, 06:56 AM
martinwh99 is offline
Find More Posts by martinwh99
Switzerland, ZH, Zurich
Joined Jun 2013
Here are the quotes from Switzlerland......
...being looking at this thread since mid 2003 i decided to build Lothars version.The problem i have is time In 2.5 weeks we (the boys and i) are going to Tessin, here in Switzerland, for soaring in the hills. So i will start to day and get the wood from my friendly local do it yours self shop. Depending what i get i might do some modification concerning material. And because i want to build it fast and cheap i will use balsa for covering maybe with resin underneath and i might do a full covering of the wing. I had to do some changing on Lothar's cad files because my cnc mill don't like these tiny lines, it's like stop and go so i changed them to arcs which will make the cutting 10 to 20 times faster at least on my machine . I might probably include or change some other stuff of the drawing, but as soon as i finish i will publish them here. So for all of you still watching this thread watch out for the pics which will come the next 14 days.
And hopefully i will manage to finish the project with in the next fortnight.
regards
Martin
martinwh99 is offline Find More Posts by martinwh99
Old May 22, 2015, 09:19 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
That's great news Martin.
Due to the Manatee's very thick airfoil, structural concerns are minimal. Even with balsa skins, it will never flutter during normal flight.
I would suggest that you wrap the joiner box around the somewhat short joiners.
Also my spoilers were located too far inboard.
You have a lot of building ahead of you. Good luck.
Kent
Old May 23, 2015, 02:35 AM
HortenI is offline
Find More Posts by HortenI
Tailless Happy
HortenI's Avatar
Germany
Joined Jan 2009
Good Luck !
HortenI is offline Find More Posts by HortenI
Old May 26, 2015, 09:34 AM
Joined Jun 2013
Let's start
The wood has arrived and went strait ahead to my milling machine. I still have to make some changes in the drawing so that it fits for me. Hopefully building will start tomorrow.
By the way if someone is interested in my milling machine. I designed it my self and you find the plan here: https://github.com/martinwh99/-myMill
regards
Martin
Build Log My First Ever Build code name "NABS" diymuppet Flying Wings 11 Dec 24, 2011 07:33 AM
Build Log Code Name: BRT18 70" Flat wing foamy Photon Foamies (Scratchbuilt) 27 Sep 13, 2007 03:05 AM
Sukhoi Su-32FN Platypus (NATO Code name FULLBACK) Sluf7 Electric Ducted Fan Jet Talk 44 Aug 10, 2006 01:25 AM
Idea Frankenstein Bio-Tech (project code name required) DuncanRigby Ornithopters 8 Apr 25, 2004 10:35 AM
