Old Jan 04, 2012, 12:45 PM
Quick61 is offline
Find More Posts by Quick61
Just call me crash for short
Quick61's Avatar
United States, OH, The Plains
Joined Jan 2011
Yes, I have and use a high start. I just know that a wing can be a bit more tricky than a conventional tailed sailplane. Just as CG can be a bit more touchy on a wing, in my mind tow hook placement could also be a bit more critical. I have several foamie wings (not to be posted here other than brief mention ) including a finless one of my own design. Just never built or flown a thermal type wing yet.
Mark
Quick61 is offline Find More Posts by Quick61
Old Jan 04, 2012, 02:27 PM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Bungee launch
Got it Mark.
Since we're on the subject of launching, do any of you skinny wing guys favor the bungee launch? Currently my favorite due to the small space requirements is the bungee. It is a good test for flutter.
Kent
Horti parachute landing with just elevons (0 min 48 sec)
Knoll53 is offline Find More Posts by Knoll53
Old Jan 04, 2012, 02:59 PM
biber is offline
Find More Posts by biber
Needs brain lubrication
biber's Avatar
Aachen, very western Germany
Joined Dec 2004
The first rc winglet wing glider I built myself has never seen anything other than slope and bungee.
It was constant chord (160 mm), 27° sweep, 116 cm span and 2° of linear washout.
It had hotwired XPS cores (Selig airfoil S5010) with one layer of bias cut 200 g/m² carbon cloth as skin.
No shear web, no spar caps.
I was terribly afraid it could be prone to flutter and that was why I made it torsionally stiff like hell.
I also made very stiff linkages between the servos and elevons.
It never had even the slightest flutter issues, but killed quite some servo gears during landings
(linkages to stiff, elevons to heavy, wingtip hits ground, elevons inertia beats teeth out of servo gear, et voila).
The hook was located way in front of CG on the nose of what once had been a HLG fuselage cut 10 cm behind the wing saddle.
biber
biber is offline Find More Posts by biber
Old Jan 04, 2012, 03:44 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
biber
Wow, that sounds like a lot of carbon for such a little wing. I assume that this was a bagged wing. Yes, I believe you when you say it did not flutter. Even though it did not have longitudinal fibers along the span, I'll bet that it did not bend either.
Good to know that it bungee launched well. My guess is that you have developed a more economical, yet still stiff, reinforcing method since those early days. Of course you can't beat the look of all that carbon.
thanks,
Kent
Old Jan 04, 2012, 06:07 PM
biber is offline
biber's Avatar
Joined Dec 2004
The cost of the carbon cloth was not all that much, as the rather heavy stuff is the most cheap type available and the wing was small.
I guess it was about 15 euros worth of carbon.
And I liked the look very much at that time.
It weighed about a pound and hasn't been thermaled ever, it just didn't seem to lend itself to floating.
However, back then my own experience with thermals was also close to zero.
Today I'd be tempted to apply the Mubu scheme to a 2 m thermal wing and see what happens.
I think a bungee would be the appropriate launching method for that, if not the classic javlin launch like in old HLG days.
I hate the hassle of lengthy highstart equipment.
biber
Old Jan 05, 2012, 12:32 AM
nmasters is offline
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Great build log, biber
The spar layup schedule shown in post #236 is the best I've seen in a model.
--Norm
nmasters is offline Find More Posts by nmasters
Old Jan 05, 2012, 07:44 AM
biber is offline
biber's Avatar
Joined Dec 2004
Thanks Norm.
Maybe at last some of the stuff we are getting told in university was of use there.
biber, waiting for a video of Verns thermal wing to drool over *hint*
Old Jan 05, 2012, 07:49 AM
Vernon Hunt is offline
Find More Posts by Vernon Hunt
Vernon Hunt's Avatar
Florida
Joined Mar 2005
biber,
I'm waiting as well. The weather in Florida has turned very cold and windy, so it may be suitable to fly this weekend. I have my son and his camera on stand by to video the test.
Vern
Vernon Hunt is offline Find More Posts by Vernon Hunt
Old Jan 07, 2012, 05:06 PM
Florida
Joined Mar 2005
OK, Here is the vid of the test flight. It went well. Very first flight was great, went up pretty good. I need to bend my hooks flater for better tow.
Vern
Untitled (1 min 23 sec)
Old Jan 07, 2012, 05:10 PM
cpdude is offline
Find More Posts by cpdude
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Nice Vern. Great job!!! We may need to design one of those with a built up structure. We should talk.
Brian
cpdude is offline Find More Posts by cpdude
Old Jan 07, 2012, 05:13 PM
Quick61 is offline
Quick61's Avatar
Joined Jan 2011
Very nice and smooth. Congratulations on such a nice and smooth first flight.
Mark
Old Jan 07, 2012, 05:17 PM
quaxi is offline
Find More Posts by quaxi
quaxi's Avatar
Germany, Nordrhein-Westfalen, Nettetal
Joined Jun 2003
Great maiden flight,
Wolfgang
quaxi is offline Find More Posts by quaxi
Old Jan 07, 2012, 05:25 PM
miniphase is offline
Find More Posts by miniphase
miniphase's Avatar
United Kingdom, Kent
Joined Nov 2004
lovely job Vern, liking the 'power-lines limbo' too!
miniphase is offline Find More Posts by miniphase
Old Jan 07, 2012, 05:34 PM
Florida
Joined Mar 2005
Hey! I knew it would be successful, but the power lines did cause a bit of intimidation. Thanks miniphase,cpdude, Quick61,quaxi, I'm enjoying after test multiple beers and ribs for dinner. It doesn't get any better than this. It's a tight spot to fly but close to home and nobody bothers you. More flights soon while the thermals are booming.
Vern
Old Jan 07, 2012, 06:05 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Wow, that thing really FLOATS ! and no bad habits.
I would think that a skinny wing would move a little faster.
What was your final flying weight?
Kent
Discussion 3.2m thermal 'wing miniphase Flying Wings 63 Feb 29, 2012 07:01 AM
Discussion sig Thermal Dart wing covering ? larryg Free Flight 7 Dec 15, 2011 12:16 AM
Question EPP plank or swept wing for thermal sky_surfer_fra Foamies (Scratchbuilt) 1 Nov 10, 2011 03:05 PM
Discussion McClain Wing Cores MWC 48"-Thermal Flying cliffo Flying Wings 0 Nov 02, 2011 03:51 PM
Wanted Speedo Thermal wing cores Twyl Aircraft - Sailplanes (FS/W) 9 Oct 28, 2011 12:26 AM
