Old Jan 03, 2012, 09:57 AM
Quick61 is offline
Find More Posts by Quick61
Just call me crash for short
Quick61's Avatar
United States, OH, The Plains
Joined Jan 2011
Originally Posted by Vernon Hunt View Post
Mark,
I've launched my skinny wings hundreds of times and it goes up like any sailplane. At the glider end of the bungee I use a bridle, that attaches to 2 hooks outboard on the wing just ahead of the CG. Works great.
Vern
Yes, That is like the rolling bobbin. It hooks to 2 hooks on the wing and has a ring or "bobbin" that is in the center that can slide at the Y junction. I first learned about the setup reviewing the plans for the Sparrow, an old timer forward swept flying wing. After a bit of a search I found the attached document on the subject. (just a single page)
Quick61 is offline Find More Posts by Quick61
Old Jan 03, 2012, 03:54 PM
Vernon Hunt is online now
Find More Posts by Vernon Hunt
Vernon Hunt's Avatar
Florida
Joined Mar 2005
Here's what I have on this sunny afternoon. Controls are working, high and low rates. Need to get differential working.One hook is shown. Very beefy setup. multiple bends to sandwich between 3/32" ply. Then set into wing with epoxy.
Vern
Vernon Hunt is online now Find More Posts by Vernon Hunt
Old Jan 03, 2012, 03:57 PM
cpdude is offline
Find More Posts by cpdude
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Very nice Vern! I definitely have a need to build a good (and light) thermal wing at some point.
Brian
cpdude is offline Find More Posts by cpdude
Old Jan 03, 2012, 04:04 PM
Florida
Joined Mar 2005
Brian,
Thanks! Yes, these are great flyers, and pretty easy to build.
Vern
Old Jan 03, 2012, 04:14 PM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Vern,
It looks bigger with you in the shot. Looks like a real floater now!
I've read about the wing mounted dual tow hooks but have not experienced it yet. From the looks of it, you'll get a typical very steep launch with a final release at low line force. I'd think that one hook releasing before the other could be "problematic". From what I read, it is not.
Also, once a line across the wing is established for the hooks, I'd think that you could place the symmetrically laid out hooks at any where along that line. I see that you have placed yours well forward of the spar rather than at the spar. Any reason for this besides personal preference?
thanks,
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Jan 03, 2012, 04:28 PM
cpdude is offline
Joined Jan 2004
...and pretty easy to build.
I'm sure it is with all of that foam.
Old Jan 03, 2012, 04:36 PM
Florida
Joined Mar 2005
Kent,
Yes, it can be slowed very nicely, once in a thermal set the bank and spin yourself up. Even at this light weight it can moveout quickly and seek new hot air. I've had a tow line ring come off during tow and it just kept going up, I couldn't believe it. The hooks should be right up close to the leading edge. The CG is right behind the hook placement. You are correct in saying the hooks aren't connected to the spar. But, I've never had a hook pull out with where they are, sandwitched between 3/32" ply and liberally glued to the top skin. With a block of balsa on top filling the remainder of the space essentially gluing it to the bottom skin.
Vern
Old Jan 03, 2012, 04:44 PM
Quick61 is offline
Quick61's Avatar
Joined Jan 2011
Vern
Great looking wing. Any "rule" you are following on placement of the tow hooks, or is the placement one of those "experience tells me to put it here or else!" kind of things?
Mark
(now waiting on video of the launch. )
Old Jan 03, 2012, 06:26 PM
Florida
Joined Mar 2005
Mark,
I think I explained hook placement in my answer to kent just above your question. the hooks are placed 1/2" ahead of the CG on the leading edge.
Vern
Old Jan 03, 2012, 06:35 PM
Quick61 is offline
Quick61's Avatar
Joined Jan 2011
Mark,
Vern
Yes, I got the where they were placed. I was wondering HOW that place was picked (as opposed to 1/4" forward of CG or 3/4" forward) Sorry for not being more clear about my question.
Mark
Old Jan 03, 2012, 06:51 PM
Florida
Joined Mar 2005
Mark,
Placement depends on how you feel about your tow. Do you like a sensitive tow, then put the hooks very close to the CG. Or, do you like a more easy to control tow, then place the hooks further forward of the CG. I found 1/2" ahead of the CG to be a comfortable tow especially right after launch. Not a severe pitch up so the glider doesn't stall.
Vern
Old Jan 03, 2012, 07:05 PM
nmasters is online now
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Mark
Herk Stokely talked about tow-hook placement in the Tinamou thread .
nmasters is online now Find More Posts by nmasters
Old Jan 03, 2012, 10:17 PM
Quick61 is offline
Quick61's Avatar
Joined Jan 2011
Thanks guys. That helps out allot. Never launched a wing on a high start before so the more info I can gather before I build and try to fly the better my chances of avoiding a rekit. Appreciate your info and patience. This is all new territory for me.
Mark
Old Jan 04, 2012, 03:45 AM
Peter V is offline
Find More Posts by Peter V
Peter V's Avatar
Joined Nov 2008
thermal wing
hello Mark,
I see what you mean now; I have no experience with it.
Maybe you can ask Tailsaw, he has a lot of exp. As far as I understand it, there is a great change of flutter.
http://thermik-board.de/nurfluegel-f...c7eb1cc4536695
Peter
Peter V is offline Find More Posts by Peter V
Old Jan 04, 2012, 09:13 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
but I can't say that I have seen a TD type wing being launched by high start.
Mark
Ooooooooh, you've "never launched a wing on a high start before".
Have you ever used a high start before? If not, then the answer is very different. Things happen very quick when you launch and I'd suggest that you learn it in steps. That is start with a very gentle pull and push the nose down for control. Then work your way up to a steep high force launch. Tow hook placement is of course critical.
Knowing your experience with this would help us give you a more useful answer. Much has been posted about high starts in general in the Sailplane section.
Kent
Discussion 3.2m thermal 'wing miniphase Flying Wings 63 Feb 29, 2012 06:01 AM
Discussion sig Thermal Dart wing covering ? larryg Free Flight 7 Dec 14, 2011 11:16 PM
Question EPP plank or swept wing for thermal sky_surfer_fra Foamies (Scratchbuilt) 1 Nov 10, 2011 02:05 PM
Discussion McClain Wing Cores MWC 48"-Thermal Flying cliffo Flying Wings 0 Nov 02, 2011 02:51 PM
Wanted Speedo Thermal wing cores Twyl Aircraft - Sailplanes (FS/W) 9 Oct 27, 2011 11:26 PM
